Question about RIM BlackBerry Bold 9000 Smartphone
My blackberry is not working. I have charge it
I was on internet. and it frozen and was show charge cross with a line. when I charge it. to switch it on . it goes back to
  • bna0012 Mar 09, 2009
    now is flasking red light
My blackberry is not switching on. it is fully charged
Posted on Apr 20, 2010
Unable to Charge
Hey there,
This symbol generally appears when you are connected with a charger not suited specifically to your blackberry. the connector may fit the socket on the phone but does not work at the level the blackberry requires to charge. Try another cord made for the blackberry.
Also remove the battery from the device and ensure all the connection points are dust free. I don't think this relates to your problem, but a good idea to do from time to time anyway.
Good luck.
Mar 05, 2014 | RIM BLACKBERRY TORCH 9800 TOUCH SCREEN...
Does not turn
solutions of red cross battery for blackberry 9320
Nov 05, 2013 | RIM BlackBerry Bold 9700 Smartphone
Bb 8520 comes up with charging sign with a red cross across on the screen. help!!!! Options
it happens when ur bb battery is damaged if u change ur battery u will not face that problem
Feb 13, 2013 | RIM BlackBerry Curve 8520 Smartphone
My blackberry curve 8520 is at low battery and wont charge or show the charge lightning bolt
King, many times this happen, don't worry, put your device on charge 2 to 5hours it will solved, if problem persist, change battery, because this sounds me a only battery problem. there is one another way (if you are not sure don't try this) we call that direct charging
first take one charger who has light on head and then cut the charging connector of charger and then you will see two colours of wires separate the black and red wires (red wire is positive line and black is negative line) and then connect to current supply but make sure there wire are separated otherwise it will have a short circuit and then take battery and search + and - connector and then red wire connect on battery positive connector and black on negative connector if you connect properly you will see the charging light are getting dim. that mean it is charging, do direct charge for 10 min and then switch on your device with battery and put in charge normally. this will solve your problem. if my sugetion was helpful please rate it.
Jul 02, 2012 | RIM BlackBerry Curve 8520 Smartphone
I hv a blackberry 9000 phone and the red light blinks but I cant switch on the phone even thouh its connected to a power adapter for charging
Take the phone off charge and take off the battery on the phone, you can now put the battery back into the phone. Press and hold the red power button on your phone. If the problem persist then go ahead and download the blackberry desktop manager unto your computer. Connect your blackberry to the computer and initiate the blackberry desktop manager. Once it shows connected as status between the phone and your BDM (blackberry Desktop Manager). Reinstall the software on your blackberry. Make sure the computer is connected to the internet.
Regards
Jan 24, 2010 | RIM BlackBerry Bold 9000 Smartphone
All it does is show a battery with a red line through it?
The battery is drain.
DO NOT use the USB cable to charge your Blackberry.
When the PC/Laptop/Mac go to power saving/SLEEP mode it will cut off the charge to the Blackberry.
Use the official AC charger to charge the Blackberry.
Make sure the AC power is not switch off to the power pack at night.
Oct 31, 2009 | RIM BlackBerry Pearl 8100
My blackberry pearl has a battery showing with a red line through it. I have charged the battery and put a brand new battery that is charged in it but the same signal keeps showing up.
In this case you need to take out the Battery of your Handheld and check with the other handheld, If it is working fine then there is a problem with your USB cable you need to walk into the service center for this.
Oct 18, 2009 | RIM BlackBerry Pearl 8100
Blackberry wont turn on just shows red line through battery
just put a piece of paper on the top of the battery (the part where u push it down) it shows the battery with a red line slashed across because its too loose...
it worked for me!
Nov 24, 2008 | RIM BlackBerry Pearl Smartphone
RIM BlackBerry Bold 9000 Smartphone Logo
1,003 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
