Question about Microsoft Xbox Console
Dns failed when i tried to setup xbox live. i have a belkin router set up and my console is set up next to the xbox. what do i need to do?
  • Dominic
    Dominic May 11, 2010
    You need to setup your router to allow the Xbox Live data to pass through the firewall.
    • You can setup port forwarding on your router or set a Static IP Address for a Demilitarized Zone (DMZ).
    • What model is your Belkin Router?
Hi hi
Posted on Mar 23, 2009
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 167 Answers
Information on setting up port forwarding can be found at:
http://portforward.com/
If you want to go with a static setting this is what you need to do:
  • Login to the Router/Gateway by entering it's IP address in your web browser. (http://192.168.2.1)
  • On the left panel of the firmware page, under "Firewall," you should see a link "DMZ" for the Static IP configuration.
  • Your router should generate 25-50 Dynamic IP addresses for, choose a Static IP outside that range. (192.168.x.200)
  • Then go into your Xbox network configuration and set the IP address to the newly defined DMZ.
  • IP: 192.168.x.200 Subnet: 255.255.255.0 Gateway: 192.168.2.1 (Primary DNS is the same as the gateway)
If you need more information about your router follow this link:
http://www.belkin.com/support/product/?lid=en&pid=F5D7230-4&scid=221
Posted on Mar 09, 2009
My son's new Xbox Live cannot / will not connect with our wireless router, even though it recognizes it. I have a Belkin 802.11b
1) Get connected to belkin's wireless network or wired network
2) Once you get connected, it may not be able to go online on XBox Live
3) Go to any computer that is going online with the router
4) Type in 192.168.2.1 in the address bar of your Internet explorer
5) This will open up router interface(here we have to do some settings)
6) In the left hand side column, click on FIREWALL.
7) Leave the password blank in login page and disable the FIREWALL. Click on Apply Changes.
8) Under FIREWALL(in the left hand side column), click on DMZ
9) Make a "check" on enable and under Private IP: 192.168.2.25. Click on Apply Changes.
10) Now go to Xbox, under network settings, choose IP settings, and select manual configuration
IP: 192.168.2.25
Router: 192.168.2.1
11) Now select manual configuration for DNS settings.
Primary DNS: 4.2.2.2
Secondary DNS: 4.2.2.1
12) Restart both Belkin and Xbox
13) It should connect to XBox Live now...
Jan 17, 2010 | Belkin (F5D8231-4) Wireless Router...
I am trying to connect to xbox live through a router but it says the dns has failed can anyone help
Here is support from Microsoft about the 360 and DNS FAILED error with xbox live. Hope this helps you out.
http://support.microsoft.com/kb/908884
Please don't forget to rate. :)
Apr 08, 2009 | Microsoft Xbox 360 Console
MTU setting
Browse to the router's setup page, should be 192.168.1.1 or 192.168.1.0 and log into it. You just have to change the MTU. Put it to 1500.
Once logged in to the router, go to :
Setup
Basic Setup
Wireless Setup
Internet Connection Type
Connection Type = Static IP
Internet IP Address = 192.168.0.1
Subnet Mask = 255.255.255.0
Gateway = 192.168.0.1
Static DNS 1 = 192.168.0.1
Static DNS 2 = 192.168.0.1
Static DNS 3 = 192.168.0.1
STP = Enable
Optional Settings (required by some ISPs)
Router Name = client-mode
Host Name = 2WIRE383
Domain Name = [empty]
MTU = Auto
Please remember to rate all users who assist you for free :)
Sep 29, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Xbox live
You should have no problem w/ comcast.
First make sure your computer can connect to the web with the same connection. If it does then you should be good to go. My guess is that you are not able to from your set up the way it is configured. Make sure your signal is split with a router. Your IP and DSN should set automatically from within the Xbox. Don't try to manually set up the IP address or the DNS.
Make sure you run your test setup though the Xbox and pay attention to what it says. Read the solutions that are offered for every fail test. Be patient. I am confident you can do this. But to repeat. Make sure you can log onto the web with a computer from the very same TCIP plug that you will use on the 360.
Sep 11, 2008 | Microsoft Xbox 360 Console
Xbox 360 live DNS test failed
if you are connecting directly to the modem, then you are going to need to get the dns info from your ISP. If you have a router just put the router address or let it find it automatically. Also check that the router has the right dns settings from the ISP.
Jun 09, 2008 | Microsoft Xbox 360 Console
DNS during connection of router
Go to your xbox 360's dashboard go to the far right, the system panel, and click netowkr settings. Then click edit network, then click DNS settings make sure it is set to automatic.
Mar 20, 2008 | Microsoft Xbox 360 Console
CAN"T SIGN IN TO XBOX LIVE
You might not have been banned. Not being able to connect to the DNS or having it fail can be caused by a few things:
The DNS address serves couldn't be reached
The info on the DNS server couldn't be snagged from your ISP or the DHCP server
The DNS values in the dashboard are wrong.
I don't want to come off like I am insulting your intelligence, but check your internet connection to make sure you have the ability to connect. I'm sure it is all in proper order. So the next thing you need to do is check to see if you IP is set and passes all the tests. If it isn't then you can click the more link on the test page to follow the directions on how to fix it.
You may also want to check out if you are using a XBOX live compatible ISP. Click on Learn More to see if you are using the right ISP or to adjust your settings. You can also check out the connectivity wizard to find out if there are some other issues revolving around this.
Still running into problems!?!?!? try running the modem directly into your XBOX. This has helped me in a few time of need.
Here are some helpful links on what you can do when your DNS fails:
http://xbox360help.blogspot.com/2007/03/dns-failed-on-xbox-360-live-test.html
And a link to a forum discussion regarding failed DNS
http://forum.teamxbox.com/archive/index.php/t-411837.html
Mar 04, 2008 | Microsoft Xbox 360 Console
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
Ip address
try resetting your router & modem.unplug modem,unplug router....plug up your modem wait 4 all the little lights 2 light up & then plug up your router.if that doesn't work i don't know ;)
Feb 16, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
112 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
