Question about HP Pavilion zd8000 Notebook
My cd/dvd drive wont play
When i go into my device manager and click on dvd/cd drvies then it shows matshita UJ-840D when i click propeties in the general box it shows a message in device status stating "windows cannot load the device driver for this hardware. The driver may be corrupted or missing.code 39" i tried to uninstall and reinstall but it still shows the same message.
  • 193 Answers
Perhaps your device is pooped, needs to be replaced
Posted on Mar 08, 2009
Matshita uj-840d
Hi, usually and error code in device manager means a sofware conflict with the device. You can try deleting the lower and upper filters in the registry if you feel comfortable. Here are the steps:
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
Regards,
Purito
Oct 20, 2009 | Computers & Internet
My matshita uj-840d is not recognized by my hp pavilion laptop. the software is loaded but my computer does not see the hardware
I think you have to run this Microsoft tool
http://support.microsoft.com/gp/cd_dvd_drive_problems
At the HP site you will also find information and a patch to solve the problem.
Oct 20, 2009 | Panasonic Matshita- | UJ-845-B | USB 2.0 |...
My Matshita UJ-840D DVD/CD-ROM Drive Stopped working
i,m assuming this is A laptop Computer ?
The only thing you can try is this:-
go to My Computer/Control Panel/ System/Device Manager.
see if there are any yellow triangles or exclamation marks by your problem device. if so click un-install. then at the top of that page, there is a refresh icon or similar. which will rescan the systems bus.
failing this try add new hardware wizard, in control panel.
finally ensure the device is connected correctly, unlock/remove and re-insert. update any device drivers for this.
Mike @ Compurepair.
Sep 04, 2009 | Panasonic Matshita- | UJ-845-B | USB 2.0 |...
Matshita UJ-840D cannot be connected/found
Tried this on my Sony Vaio VGN-SZ650N after completely reinstalling Windows Vista on it and losing access to my this drive. It worked. :)
http://support.microsoft.com/kb/929461
Good luck hope this helps,
ArcheantusAlive
Mar 14, 2009 | Panasonic Matshita- | UJ-845-B | USB 2.0 |...
Matshita dvd-ram uj-831s driver missing
please go in bios check the drive is shown there.
if shown and not showing in my computer then might be the os issue.
Go to the device manager and check any yellow question mark on the dvd/cd rom drive and if not then try following
Right click and uninstall the drive.
Go to IDE ATAPI controllers in device manager and uninstall secondary controllers or ata channel 1 from there.
Go to run option>type regedit and enter then>H_KEY_LOCAL_MACHINE>SYSTEM>CURRENT CONTROL SET>CONTROL>CLASS>first entry starting with the 4D36 and single click on entry>on the right hand pane check for any lower or upper filter and if there delete both.
Restart the system twice then check if then also not working might be OS or drive faulty
Thanks.
Feb 22, 2009 | Toshiba Satellite A205-S4617 Notebook
MATSHITA UJ-840D, has disappeared and I can't play cd's/dvd's.
Before you do this though export your current registry to the desktop by selecting export from the file menu. If this doesn’t work just double click on the exported on to restore it.
1. Start Registry Editor by typing regedit into the start search box in the bottom left hand corner of the start menu.
2. In Registry Editor, expand Computer, and then expand HKEY_LOCAL_MACHINE.
3. Expand SYSTEM, and then expand CurrentControlSet.
4. Expand Control, and then expand Class.
5. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
6. In the details pane of Registry Editor, on the right side, click UpperFilters.
7. Right click and select delete
8. Click Yes when you receive the following message: Are you sure you want to delete this value?
9. Now look for LowerFilters in the right hand panel.
10. Right click and select delete
11. Click Yes when you receive the following message: Are you sure you want to delete this value?
12. Exit Registry Editor
13. Restart the machine
It wit worked for me on Acer with UJ845D XP Good luck
Feb 09, 2009 | Panasonic Matshita- | UJ-845-B | USB 2.0 |...
Cd rom drive not able read data cd
First Go to control panel- System icon- Hardware Tab- Device manager
Expand the CD/DVD roms- Right click on your CD/DVD drive and Uninstall it.
Now download the utility from the following link and just run it on your system.
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
It will take a quick minute to run this utility.
After this restart your computer. It should work fine
Feb 04, 2009 | Sony VAIO VGN-FS640W Notebook
Matshita UJ-840D CD-Rom Drive
it seems that the best firmware for your drive is here:
http://www.techzilla.info/uploads/MatshitaOEM.rar
read the nfo inside.
Mar 08, 2008 | Computers & Internet
HP Pavilion zd8000 Notebook Logo
211 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
