Creative Labs Creative Technology Zen MP3 Player Logo
Posted on Mar 08, 2009
How do you add songs to a playlist on the ZEN Mozaic?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 11, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1934
Points
Don't really know, but this works
Browse music library adding tracks to 'add to selected'
go back tomusic lib and goto playlists
select the playlist you want, add to selected
save selected as playlist, give it the same name as the playlist youeant to add the tracks to andchoose overwritewhen prompted
I'm sure there is a quicker way way, but hey, it works
2helpful
2answers
Download music.Drag it into Zen file but no go
open zen folder from my computer, Make sure file is put in MP3 file or DHCM file. Manually drag it to a specific file and not just drive alone. Make sure all your drivers are downloaded. You can also create a playlist in media player and sync device and add playlist to zen from media player
1helpful
My 8gb mozaIC WILL NOT REGISTER WITH MY COMOP
Support for Zen Mozaic on the site of Creative:
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=17897&prodName=ZEN+Mozaic
1. Firmware [for your player]
Get a download from the support site and install:
this will put maps onto the device. Communication with the software
on the computer is available after getting the next item (2.) is done.
2. Application software [for the computer]
2.1 Creative Centrale (+ User Guide) is usefull to get songs on your Mozaic.
2.2 Windows Media Player 11 can be used as well. Note: You'll first have to make a playlist: Save the playlist: Next Synchronize it onto
the Zen.
3. Drag and drop
Once firmware is installed you can also use the drag and drop method. Move music, pictures, video inside maps on the computer into the corresponding map onto the player.
Don't hesitate to post a comment
when this will not get your Zen to play.
Creative Central reads that mozaic is there, but wont transfer anything to player.
Creative support for Zen Mozaic on this site, showing how to
transfer audio and video in the Knowledge Base Solutions:
http://support.creative.com/kb/ShowArticle.aspx?sid=54748
The ZEN X-Fi supports the following Video and Audio Formats:
  • Video: MJPEG, WMV9, MPEG4-SP3, DivX3 4/5 and XviD3
  • Audio: MP3, WMA, AAC4 (.m4a), WAV (ADPCM), Audible 4
You can also use Windows Media Player 11 for music transfers.
1. Make a "new playlist" (left side) in the Library or Sync modus
When you enter the name the listname moves to the right side.
2. Putting music in the list
2.1 method 1: right click in the top of the WMP11
screen: File > Open...
2.2 method 2: Reduce your WMP11 screen: right click in the top of WMP11 screen:
Tools > Options... : select "Keep the player on top..." and
<apply>. Now you can explore your maps in Windows having
the player always on top.
Drag and drop files into the new playlist on the right side.
3. Save playlist
4. select Sync in top of the WMP11 and "Start Sync" on the right of the screen; the transfer is executed.
Software gone and can't find songs on file in MP3
Support for Zen mozaic on this site:
See the bar "All Downloads".
The "Application" should be reinstalled on your computer.
The software on the computer is required to get access
to your data on the player.
There is also a "Software AutoUpdate" available
on the bottom right side.
Need a manual or instructions how to operate it
experimental status
ZEN mozaic player 2 GB
firmware 1.03
ZEN attached to USB 2.0
Windows XP SP2
Message "do not disconnect"
ZEN is not being recognized
Check ZEN memory setting
Memory ZEN is set to 0 in MENU>Etras>removable disk
Memory ZEN should be changed to maximum 1.5 GB
ZEN is recognized now
ZEN is ready to do the format command
ZEN can be written to for a maximum of 0.5 GB [internal memory !]
ALERT ! This 0.5 GB is the internal memory
The files written to the internal memory will be erased after
disconnecting !
access status
NO ACCES TO MY ZEN ?
1) Get access to ZEN by setting disk memory to maximum
2) ZEN should be recognized now
format status
1) FORMAT the disk
After formatting !
SET BACK YOUR disk memory capacity to zero [ 0 ]
for fully recovering the disk capacity
files presence status
FILES NOT PRESENT AFTER DISCONNECTING ?
- When set to zero you can use the full memory for
writing files to the player !
- When keeping the memory set to maximum you're using
the internal memory and written files are not saved
after disconnecting
updating + files presence status
UPDATING FIRMWARE ZEN MOZAIC = MAKING STANDARD MAPS
1) download the firmware that is suited for your computer
Operating System and your type of player from "CREATIVE"
2) Connect player to USB 2.0
and update with the firmware-update
3) Wait until the update is fully completed
4) After the update disconnect the player
5) Connect to USB 2.0 again
6) Check for the presence of the STANDARD MAPS for Music,
Pictures and Video
7) Files can be written into the STANDARD MAPS
8) Written files should be present after disconnecting
9) Files ready for mobile playing on ZEN mozaic now
CREATIVE support site for fimware / software / userguide
SUPPORT FOR ZEN MOZAIC ON THE INTERNET
Hi!i cannot put a songs to my zen v plus...what will i do?
What you should do is to go to all tracks and play one so that it is in the 'now playing' section. Then, hold the return buttontil the menu appears. go on remove (this only removes from the playlist, not delete the file! trust me). then remove all. next, go back to the all tracks and hole return on the track you want to add to the playlist. Go down to 'add to selected'and it is in. (it will automatically select the next song so dont keep pressing it...you should see the selection in the background move down). Do this for all the tracks u want. Go to now playing and hold return, then 'save playlist as', and save as the file. Then it can be accessed through the playlists menu. Hope this helps poeple!
1helpful
2answers
Instruction for zen mosaic by creative
did it come with software
do a google on your model and download the convert software
it probally has the format as cell phone videos but yours is probally easier.. you could just try a usb cable and port over to the folder where the videos and music is on,
rate me please
erika
Can't transfer my current itunes list to my new Zen Mozaic
every song you buy from iTunes is protected, therefor you will not be allowed to put it onto another device. a good idea if you have a CD burner in your computer is if you make a CD in iTunes (by making a playlist and burning it to a CD)m and put it into another player. if you have windows you can use windows media center to get the songs. if you have something else it is just as well. when the songs go onto the disk most likely they will not have any protective code on them and you can easily use them. also a downfall is that you might lose all the names...yet you can just look back on iTunes. make sure to label the CDs.
84helpful
8answers
Can't create playlists on my zen x fi
I tried some suggestions posted here, and after some testing, I can now give you step-by-step instructions to create a playlist on your Creative Zen.
First, you need to think of the NOW PLAYING list as the "selected songs to be added to a playlist".
So, to start clean, let's empty out the NOW PLAYING list as follows:
1) from the MUSIC menu, select NOW PLAYING
2) when a song is shown on-screen, click the context menu
3) select REMOVE ...
4) select REMOVE ALL
Now, the NOW PLAYING list is empty.
Now, you need to select (mark) the songs you want to add to your new playlist:
1) go to an individual song
2) click the context menu, and select ADD TO SELECTED
3) go to another desired song, and do step 2) again
4) repeat until done
Now, to create a NEW playlist, go to the MUSIC menu, then:
1) select NOW PLAYING
2) it will show you the first song that you selected
3) press the Right button, to scroll through all of the other songs you selected
4) when any song is shown on-screen, click the context menu
5) select SAVE AS PLAYLIST (this refers to ALL songs in your NOW PLAYING list)
6) type the name for your new playlist, and click checkmark
ALL of the songs in the NOW PLAYING list are now saved as your New playlist.
From the MUSIC menu, select PLAYLISTS. You will see the name of the playlist that you just created. When you select that playlist, you will see the list of songs you had selected.
Please note that these songs are still in your NOW PLAYING list also. To create a another New playlist, you will first need to empty out the NOW PLAYING list as you did above.
I hope that helps.
Enjoy!
Trouble Filing Songs into Playlists
ok, sounds like a problem I had when I was working out the software! The easiest way to create a playlist with the Zen, is doing it over your PC, if you don't have the software it is available for FREE download at the official creative Zen site, just choose your model and region then hit download- simple! (You won't need Zencast with sleek photo model) ok! install your software blah blah blah, once it's gone through that process, restart your pc and then plug in your zen. the software should instantly recognise that your player is connected, so now, you can open up the software via desktop shortcut or start menu. From here, you've got a whole ton of options, whether to add to your library, create playlists etc etc. Choose create playlist and the process is easy. Left side of the screen is navigation of your Library, right side is navigation of current playlists. Create a new list, then name it. From the top left of the screen, select a folder on your library to open, the lower left displays what's in the folder you are viewing. move tracks over accordingly, holding down ctrl while you click is a fast and easy way to select more than one track at a time. hit add in the center of the screen to move stuff over to your new list. when you're done, save it. when you exit the software and unplug your zen, it should take a minute to update itself, sometimes you may need to restart Zen also to get the playlists updated. I hope this helps!
Top Creative Labs Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
