Question about Sewing Machines
Lost manual What size needle & what tension should I use for 60%cotton/40%polyester? It's very soft, stretchy material. The threads keep tangling in the bobbin cavity. I don't think it's the machine. I've misplaced my manual and can't look up needle sizes vs. materials.
  • heidikitty Mar 10, 2009
    Thanks. Your suggestion helped some but didn't fix the problem entirely. The threads aren't catching in the bobbin anymore but the bobbin stitch isn't right. Don't know how to describe it other than there's a "glob" of thread on the underneath side of the material. The needle also acts like it's pulling to one side. I'm afraid it may break. What am I doing wrong?
  • 374 Answers
  • I'd satisfied to sew cotton/polyester than silk fabric, match more commonly use needle for cotton is no. 14 and stich no.3
Posted on Mar 09, 2009
Tension setting for sewing denim on brother LS 2125
Refer to 'Manuals Online', Brother sewing machine user manual. There is an excellent guide to tension settings for all fabric types. Also remember to check upper and lower thread has been wound through correctly and are using the same thread top and bottom. Ensure you have the correct needle size for denim ie 100/16 and the correct thread size ie 40-50 cotton or heavy duty polyester.
Nov 09, 2016 | Brother Sewing Machines
Sewing machine is out of sycn
If the needle/hook is out of time, you will probably need to take it for service. There are web sites and videos on the internet that show how to correct timing if you want to try it yourself.
Apr 26, 2016 | Sewing Machines
Why is my brother ls2160 is sewing fine on cotton but not on the material I am using. Its a stretchy silky kind of material. What am i doing wrong?
You may need to use a walking foot with your machine as stretchy fabrics are hard for the feed dogs to 'grip' and pull the material through under the needle.... you will probably need to change needle as well... there should be a helpful video on YouTube that will tell u all about sewing with stretchy fabrics and how a 'walking foot' works... hope that helps.
Jul 20, 2014 | Brother LS 2160 Sewing Machine
How do I get the stitch length to be consistent? It changes with speed
consistent stitch length depends primarily on tension settings. there are 2 different tension settings on all machines. 1. upper thread tension. 2. bobbin thread tension. since these work together to create the correct stitch length+width, having either of these adjusted inappropriately can significantly impair stitch quality. "knowing' your machine has a lot to do with knowing how tight or loose the tension should be for BOTH settings. the settings will be different for each type of stitch, for each type of needle used, and for each type of thread used, meaning tensions will need to be re-adjusted after each change. in other words, the setting for a medium-width zig-zag with a size 10 needle using mercerized cotton thread to sew light-weight canvas will be completely different than the settings for a regular straight stitch using a size 8 ball tip needle using polyester thread to sew silky lingerie material.
Jun 14, 2014 | Brother PC-420
How do I adjust the bottom thread tension on the 2 needle cover stitch?
Go back to the tension adjustments that were doing well with other fabrics.
You may need to go to a smaller size needle, and a finer thread. Sometimes I use a wooly nylon in my looper because it is very stretchy, but be careful when you pull it through as you are threading it because it will also break easily if you don't have your tensions full open as you are pulling it through.
Start out by buying a sheet or roll of Solvy. You can either cut it into strips to lay on top of the material as you sew or under it if you prefer. It should make the material lay flat as it sews. I have used tissue paper before under it to make it lay flat and keep it flat to make the looper thread stretch itself out as it sews.
If your looper thread tension was too tight on other fabrics too, that is a whole other problem.
Sep 04, 2017 | Juki MO-735 Mechanical Sewing Machine
I would like to know how to set the machine up for polyester/spandex material
You need a ball point size 70 or a jersey 70 if you can get it. Stitch length 2.3 to 2.5. Re tension, just normal tension setting. If the machine is sewing an evenly balanced zigzag on regular cotton fabric, then tension is fine. If you find the straight stitch on your fabric pops under stretch, then try using a very small zigzag to put some flexability into the seam.
Mar 28, 2013 | Bernina Activa 140
The top thread is not picking up the bobbin thread. Singer Model 7422
Check your needle and make sure it is not bent, needles should be replaced after about 8 hours of sewing and that they are the right size for your project. Also use the same weight of thread, do not mix ie. cotton or polyester. Then check your threading, did some thread get tangled? Or sneak out of a guide? Hope this helps.
Oct 03, 2010 | Singer 7422
I keep having problems with the stitching on my machine. 1) when you sew the stitches looks normal from the top but when you turn the material over it looks like one big tangled mess. 2)When it does...
It is usually in your top threading, make sure that your thread match in bobbin and top threads. Mixing sometimes causes a problem. Also make sure that nothing is tangled. Also, check your needle and put a new one in just to be sure, then check your manual for size of needle and what kind of project you are doing. Hope this helps.
Sep 26, 2010 | SINGER 7470 Sewing Machine
Sewing machine tension?
Hi! This might be a tension issue, but it also could be caused by the needle. For stretchy fabric you need to use a stretch needle or at the least, a ballpoint needle. (see my tip about which needle to use).
Let me know if this solves the problem, ok?
Happy Sewing!
Robbie
Mar 03, 2010 | Brother XL-6562 Mechanical Sewing Machine
Singer Futura CE100 Embroidery
check to be sure machine is being threaded correctly first, then when pressure foot is lowered pull thread and see if you are getting tension, if not assembly is bad
Jan 21, 2008 | Singer 7422
Sewing Machines Logo
116 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
