Question about Dell 0Y3740 Keyboard
Log in issue with one of three computers.
Hi its idowell again thanks for letting me know where the num.lock key was but that didn't help with my problem do you have any suggestions for why two computers will let me log on to a web sight but the inspiron 1545 will not?
  • idowell Mar 09, 2009
    wouldn't it just say this web site blocked? I will check though because I am ready to hop on one foot and tap my head with one hand and wave my other hand if someone told me it would work.thanks for and idea I will check it tommorrow.Thanks in advance if that fixxes my problem.
  • 3 Answers
Have you checked if that website is blocked in your internet explorer or firewall settings, or maybe your anti-virus...
Posted on Mar 09, 2009
When I turn my laptop on it won't. Let me log in
Hello
With any password issues, be sure you do not have your CAPS LOCK on and, because this is a laptop, be sure the NUM LOCK is not on either. NUM LOCK activates the number pad on the letters of the keyboard and can easily cause login issues.
With both off, type your password in the USER NAME field and make sure it appears correctly (this will show you what you are typing and how the laptop "sees" what you typed). If this is correct, delete this, enter your user name and then re-type the password and see if you can get logged in.
If this fails, you may need to use a "password reset boot disk" to boot your computer up and reset your password. Let us know if you need help with that step.
Oct 30, 2013 | Packard Bell Computers & Internet
Power up but no signal on monitor(hp paviliona6430f)
First check the num lock status on key board after power up the computer press num lock key then check the num lock led status if it is on and off when you press num lock then cpu is working fine only issue with screen resolution for that when you power up the computer press F8 key 5 to 6 times untill you can see safe mode and other menu enter in "enable vgamode " then if you are able to enter then go to display property and change screen resolution to 1024*768 then apply and check.but if you are not able to enter then open cpu cabinet cover then reconnect RAM memory pull cmos cell from motherboard for 10 minutes then put it back also try with another RAM memory make sure motherboard is not ground with cabinet cover.Let me know if you need further assistance.Thanks for using FixYa.
Dec 13, 2011 | HP Pavilion A6430F Desktop PC
I need to know how to use the numpad keys on my dell inspiron 1545 laptop with windows 7. its urgent
You have to press Fn and Num Lock keys to activate numeric keyboard, rembember deactivated when you wish to use the letters that share the physical keys with numpad, this is done in the same way that you activated it ( Fn + Num Lock).
Feb 16, 2011 | Dell 0Y3740 Keyboard
Hi I wonder if you can help me. I have the flatron L1918S monitor and it was working fine yesterday, however today when i turned on the pc, the monitor flashed the green light on and then goes into power...
When after power up the computer press num lock key if num lock led is flash on and off when you press num lock key then your cpu is working fine.But if it stay constant then open cpu cabinet cover then reconnect RAM memory and processor and it's fan pull cmos cell from motherboard for 10 minutes then reconnect it then check.Make sure motherboard is not ground with cabinet. If num lock led is on and off then when you power up the computer press F8 key 5 to 6 times so you can see safe mode and other menu then enter in "Enable vga mode" then go to display property ->settings change screen resolution to 1024*768 then apply and ok. then check. If everything are fine in cpu then your monitor need repairing. Let me know if you need further assistance. Thanks for using FixYa.
Aug 25, 2010 | LG Flatron L1919S LCD Monitor
My fujitsu siemens amilo notebook screen black.
Check num lock key of laptop press num lock if numlock key is on and off when you press it then dispaly working fine only issue with screen resolution .
For that when you power up the computer press F8 key then enter in enable vga mode.
Then go to start menu ->control panel->display->settings.
Change screen resolution to 1024*768 then apply and ok.
But if num lock is constant when you press numlock key then you need to refix RAM memory.Open back cover of laptop then refix RAM memory.
Then check if still same issue then pull cmos cell from motherboard then check again if still same then try with another RAM .
When you power up the computer press F1 or F2 or "del" key if you are able to see bios screen then you not need to open back cover of laptop only make sure SATA is disabled and your harddrive is detected in bios.
Dec 19, 2009 | Fujitsu Siemens Computers & Internet
Num lock key will not turn off
Hi there.
Hold down the Fn key and hit the Num Lock key.
Please post back with the results and more help if needed, good luck and thanks for using FixYa!!
May 20, 2009 | Compaq Keyboard
Change from letters to numbers
Press the "alt" key and the number you want.
to turn on "num lock" press the "alt " key and the "left shift" key .
to turn off "num lock" press the shift key.
http://www.vodafone.in/documents/pdfs/blackberry_curve.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 06, 2009 | AT&T Blackberry Curve 8300 Smartphone
Window starts up but it dosent let me log in please help
Can you specify at what point it doesn't let you log in? Does it get to the log in screen? Make sure you have your Caps Lock button turned off, and your Num Lock key turned on, then try to log in again. Will need a little more clarification if the problem still exists after trying this. Hope this helps!!
Dec 27, 2008 | Microsoft Windows XP Home Edition
Website wont let me login from my computer but it lets me log in through my phone
Carefully check the typing of your username and password. Make sure the caps lock and num lock keys are not on. You might want to open a text editor and type into the window. Are the characters displaying properly? If not, and the num lock and cap lock keys are not enabled, try re-booting your computer. Sometimes the keyboard driver becomes corrupt and reloading solves the problem.
Nov 30, 2008 | Computers & Internet
Dell 0Y3740 Keyboard Logo
44 people viewed this question
Alun Cox
