Question about Philips 170S6FB/27 17" LCD Monitor
I have a Philips 17 inch flat screen lcd monitor. Within the past couple of weeks it has started to flicker and now has gotten darker almost purple in color. Monitor is about 5yrs old. Anyone with a solution or is it the end of my monitor?
I have a problem with a 170s philips computer screen,thats only showing a white blank screen when i turn it on,what could be the broblem?
Posted on Mar 29, 2009
I believe this is the end of your monitor. Maybe it bit the dust by the time you read this.
Posted on Mar 08, 2009
Flickering screen and lining-out on top inch at first
This sounds like tiling. are you using a cable box?
May 07, 2010 | Vizio GV42L 42 in. LCD Television
My hp vf15 monitor flickers on and off when it is plugged
17-inch CRT?
Ask your friends -- one of them probably has a "surplus" 17-inch CRT that they will _love_ to give-away to you, to replace yours.
Or, look on CRAIGS LIST for a used 17" LCD screen, for $30 to $40.
Jan 14, 2010 | HP Pavilion MX75 17" CRT Monitor
Monitor flickering
Monitor flickering can be one or several problems.
Depending upon the age of the unit and value, you should decide weather to repair it or replace it.!
More than likely, it is a problem in your power supply.
The capacitors in the supply will leak and most often crown.
If when you start unit after sitting for a while, it shows good and then after a few minutes it starts flickering, you can bet it is one or several capacitors in the supply.
This monitor is a 17 inch and not really worth the time and investment to repair, unless you have the technical skills to remove and replace electronic components.
Nov 05, 2009 | AOC 177Sa 17" LCD Monitor
Strobe-like flickering in upper half of Dell monitor
The problem is the inverter on your dell monitor this is very comon.
Jun 15, 2009 | Gateway XHD3000 LCD TV
17" Philips LCD TV has sound, faint blue flashes and blinking pwr
GP151001, Typically these cable/wire connectors fall into a catagory called HIGH DENSITY INTERCONNECT connectors or similar type. I should think that the whole assembly should be available somewhere ****!!! It's just this kind of thing that really gets me P.O.ed louie12fix
Apr 15, 2009 | Philips Epic 17PF9936-37 17" Flat Panel...
Philips 17 inch 170s4fg lcd monitor,display flickering
I have Got one philips 170S lcd monitor. Iam having flicker peoblem and my display not stable. pls, give me ur best solution for the above problems.
Jan 10, 2009 | Philips 170S4FG 17" LCD Monitor
Flickering then off
Problem is with Invertor Board maybe defective 2SC5707 transistors.
Jul 28, 2008 | BenQ FP71E 17" LCD Monitor
The bottom of the screen has become darker!
The symptom you are telling is similar to FL inverter problem but with that case usually entire screen goes dim. You may try to reset the settings (Usually AUTO button). Unplug and plug in the electrical connection+Computer connection. Also make sure your Display setting in computer side has not been modified. If issue persist take to the qualified service center. FL inverter is the illuminator part of LCD works like fluorescent tube. FL inverter issue rather lower cost compare to other LCD issues.
Good Luck Happy New Year
Dec 28, 2007 | Samsung SyncMaster 171S 17" Flat Panel LCD...
Dark Vertical Stripe on Right Edge of Screen
I experienced the same approx. 1/2" vertical stripe on a Viewsonic vx1945 and ATI Radeon x1050 video adapter on Vista Business SP1, but the stripe appeared along the left edge of the screen, instead of right edge. I then temporarily decreased the monitor resolution, and the stripe went away. I then increased the monitor resolution back to its original setting, and the stripe did not re-appear. So, that was the 'fix' in my situation, hope this helps.
Dec 11, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Monitor shuts off after initial start-up
My 17 inch Norcent LCD was doing the same thing. Then after a couple of weeks the AC adapter failed. I got a new ac adapter now LCD is working.
Nov 21, 2007 | Norcent Technologies LM730 17" Flat Panel...
Philips 170S6FB/27 17" LCD Monitor Logo
509 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
