Question about Epson Stylus CX4800 All-In-One InkJet Printer
REPLACED ALL INK CARTRIDGES AND RED INK LIGHT REMINE ON EPSONSTYLUS CX7400 SERIES
  • 728 Answers
Make sure that you replaced them with the right cartridge or the printer will not be able to communicate with the cartridge correctly and it will assume the the red ink is low. Try printing something in red and see if it works.
Posted on Mar 08, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Please turn off your printer and reinsert the Ink Catridges.
  • Rylee Smith
    Rylee Smith Mar 09, 2009
    Red light means cartridge hasn't been recognized, access the Epson status monitor through printer properties and check which is the failing cartridge.
    Please see this link for your refrence---
    Epson printer red light
    Thanks
    Rylee
Change cartridge before its finished on epson stylus sx100
  1. Do one of the following:
    • Windows: Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Printer Settings. Then click the Maintenance tab.
    • Macintosh: Open the Applications folder, open the EPSON Printer Utility 2, select CX7400 Series, and click OK
  2. Click the Ink Cartridge Replacement utility icon and follow the on-screen instructions to replace your ink cartridges as necessary.
Sep 08, 2014 | Epson Stylus Office Equipment & Supplies
I have forgotten how to move the ink cartridges into a position where they can be changed.
Turn on the printer. Open the top of the printer to expose the ink cartridge compartment. Hit the "Stop" button. This will cause the printer head to move so that one of the two ink cartridges move above the "No Ink" icon. Hit the "Stop" button again. It will move the other ink cartridge above the "No Ink" icon if it needs to be replaced. The printer head will move to the original position to the right.
Aug 29, 2011 | Epson Stylus CX7400 AllinOne InkJet...
I replaced all of the cartridges with Epson, but the black won't print. After some nozzle checks, black is getting low and STILL no black printing occurring... what going on? Now the other colors are...
Nozzle cleaning uses a lot of ink, that's probably why the other ink cartridges are registering low on ink. Are you using refilled cartridges or brand new? Also, have you had the cartridges for awhile? I've found that the nozzles can become clogged either from not using the printer for awhile or because it's a recycled cartridge that didn't have the nozzles cleaned before it was refilled. When that happens, unfortunately, sometimes it takes a lot of cleaning cycles before the printing comes back. Let me know more about the cartridges you have.
Mar 03, 2011 | Epson Stylus CX7400 AllinOne InkJet...
I have an CX7400 epson printer. I want to change my ink cartridges but the cartridge doesn't line up with the opening. I can't get to the entire cartridge.
Here is the Quick Reference guide for the Epson CX7400 printer:
http://files.support.epson.com/pdf/cx74__/cx74__qr.pdf
In this guide, under Bookmarks (in Adobe Reader), select Maintaining Your All-in-One, then select Replacing Ink Cartridges. Follow the instructions from there.
Jun 25, 2010 | Office Equipment & Supplies
Will not print with print alligment continuous scroll with red light on. Says to remove tape from cartridge which did. Carteidge is new but remanufactured. Prints unrelated web pages not known
Are you using Dell Series 9 ink cartridges? Dell Series 9 ink cartridges have a sensor that cannot be reset. Article on refilling Dell ink cartridges
If these are Dell Series 9 ink cartridges, take them to the place of purchase for a replacement.
Rick
May 21, 2010 | Dell 926 All-In-One InkJet Printer
Epson stylus DX4450 i have changed the ink and the ink button the red light is still on and it will not let me print?
Did you use Epson Genuine Cartridges?
Epson Requires Genuine Epson Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 23, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Epson R265, new ink cartridges fitted correctly but red light stays on
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
Jan 21, 2010 | Epson Stylus R265 InkJet Photo Printer
Epsonstylus CX7800- when printing color
well you must use the correct ink, you use a very thin ink, that´s way it´s bleeds, the ink is very metal corrosive, and destoy al mec. parts and bunsout the print head. NOTE:you have ruined your printer, the repair is very expensive.
Jan 13, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
EPSON RX425 RED INK LIGHT STAYING ON
Try to find "EPSON RX425 Resetter Software" at google
Sep 06, 2009 | Epson Stylus RX425 Multifunction...
Epson Stylus CX4800 All-In-One InkJet Printer Logo
22 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
