Question about Canon BubbleJet i560 InkJet Printer
When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
  • 1 more comment
  • Derkster Mar 26, 2009
    same problem -green light -5 orange flashes and unresponsive printer. message: "Operator error.
    Press the printer's RESUME button.
    If this doesn't clear the error, cancel printing and turn the printer off and then on again."
    tried all this, but happens again
  • Anonymous Mar 30, 2009
    when i turn my printer on the light flashes green
  • Anonymous Apr 20, 2009
    orange flashes 5 times
    Problem Solver:
  • 6 Answers
Here are all the flashing explanations:
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
Posted on Mar 08, 2009
We have tried to turn off the printer overnight to no avail. It continues to show an orange flashing light 5 times and then once green. We re-added more paper and the inks are full. What else can we do?
Posted on Apr 19, 2009
2 Suggested Answers
envision507
  • 30 Answers
SOURCE: The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Posted on Sep 07, 2009
Orange light flashes 5 times then green flashes once then repeat Can't get printer to do anything else. Have unpluged it for ten minutes no luck Have removed print head and replaced it, no luck....
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.For printer
Mar 22, 2011 | Canon BubbleJet i560 InkJet Printer
When i switch on the canon ip4300 printer orange light flashing 5 times
5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
1. Turn off printer
Feb 28, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
My canon i 560 does not respond at all. when i turn it on the light flashes 5 times orange and once green. and it repeats this
Generally speaking the Orange light flashes 5 times to indicate a print head error.
Did you recently remove and install the printhead? It may just need to be reseated. The printer may also need a service repair.
Don
Dec 12, 2009 | Canon BubbleJet i560 InkJet Printer
3. Release RESUME
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
My printer flash green then oranfe and again and
5 times says the feed roller is not turning properly, sometimes the gears break and other times something falls in the back and stops the roller from turning. It's a different error if the orange flashes 5 times, or if it flashes orange and green 5 times.
Sep 01, 2009 | Canon BubbleJet i560 InkJet Printer
Cannon pixma ip1700 not printing
1. Turn off printer
Feb 13, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon IP2000 printer. The power switch is flashing intermittantly green and orange and as a result it seems to be stuck as anything I do has any effect - any ideas?? Many thanks in advance for your...
this may work for you
1. Turn off printer
Nov 29, 2008 | Office Equipment & Supplies
Blinking orange 5 times and 1 green
Try this:
Most of the time when a printer used for a certain period the ink would dry out and caused an error message. What you do is to replace with a new inks pad inside the printer and reset that error message. Once it is done, your printer will work again!
For Printer Model: Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000:
1. Turn off printer
Please remember to rate all Techs who assist you for free :)
Oct 04, 2008 | Canon BubbleJet i560 InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
1,150 people viewed this question
old marine
old marine
