A message displayed"A problem has been detected with this unit" and all the buttons are INOP. Turned unit off more than 5 minutes and turned on again. Same mesaage appeared and all buttons are still INOP
  • 1 more comment
  • tranhtb Mar 08, 2009
    the model is the washer GE profile WPGT9350. It has the message displayed " A problem has been detected with this unit" and all icon buttons are INOP. Reset power afyter 5 minutes but didn't help. same message appeared and bottons are still INOP
    I'd like to have another expert opinion.
    I actually unplugged more than 30minutes and plugged back in. Same message appeared
  • 423 Answers
What were you doing with it when the message appeared? Were you pushing buttons, or did it happen automatically when no one was around?
Posted on Mar 08, 2009
  • Rob
    Rob Mar 08, 2009
    If you are handy, you can try this.
    Get a philips screwdriver
    Unplug the unit.
    Remove the backsplash cover.
    Under the cover you will see the control board. It has a ribbon cable that attaches to the board.
    Unplug the ribbon cable for 30 seconds and then reconnect it. Remember, the board has pins on it where the ribbon cable plugs in. Don't pull it off with any twisting motion. Pull the cable straight off and when you put it on, push it straight on. Careful!
    Replace the backsplash cover and plug it in.
    Let me know if you still get the message and if the board still doesn't operate.
    Rob
  • Rob
    Rob Mar 09, 2009
    I would try my solution before you make a service call.
  • 6,784 Answers
Unplugging this unit will not matter at all. this is a control board issue. I recommend a service call. this issue is not an easy task. the entire control panel board has failed. Say in this code manual that the circuit's have been separated. may be a factory default of some sort.
  • 728 Answers
Leave it unplugged for around twenty minutes and see if it resets itself when it is plugged back in. If it still doesn't work, see if you can find the code in your manual and see what it says. It will usually tell you what the possible problems could be.
  • 101 Answers
You should apply to nearest service centre on repair of the washing machines.
    Brigadier General:
  • 8,619 Answers
Hi
Please tell me the model no and the manufacturers name . Also try to Press Cancel/Stop button for 30seconds to reset it.
  • Rylee Smith
    Rylee Smith Mar 08, 2009
    Have you tried Service Mode Diagnostics. Please try this :
    Go to Home Screen , If the home screen is not displayed then press home then help. After that press my cycles and back together for 3 seconds. Read what its says and then turn the power off then back on. It should be ready to go!
    Please revert for any clarifications.
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
Error message HF
o water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Check/Repair:
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
  • 1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
If this is intermittent, it would be very hard to determine the cause.
I myself have rarely run into this issue, and when I did, it was mainly caused by low water pressure into the water from the customers water supply, or clogged inlet water valve screens.
Make sure you don't have any duct tape or something around your drain pipe, it needs that air gap to prevent siphoning.
Oct 20, 2012 | Kenmore HE2 Plus Front Load Washer
My washer starts then stops, it flashes H F, please help, my e-mail is edithdowns@att.net
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. - or -
  • if you have any further questions please message me back and please remember to rank this opinion thanks again Rick
Dec 11, 2010 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
I keep getting the HF error message even though I have removed the hoses and cleaned the screens. Is there anything else I can do? The water will run for about a minute then the error message will come on.
Hi There
i just want to say Merry X-mas and a Happy New Year. i found this for you and i hope this will get you in the write direction.
Or
Thank you for writing to fix ya.
Best regards Richard
Dec 14, 2009 | Whirlpool GHW9100L Front Load Washer
I have a STOP message on the oven display. The user manual refers me to the product description sheet or the electronic programmer description, neither of which I have. The oven is not working at all while...
HI. This is a control fault, that may be corrected by simply shutting down the appropriate circuit breaker for 5 minutes. This will DE-energize the control board. Once the 5 minutes have passed, simply re-introduce power to the unit. If the unit continues to produce the error, this will confirm that the main control board has failed. it should be replaced asap.
Nov 04, 2009 | Whirlpool RBS275PD Electric Single Oven
Hf is showing as an error message. what does it mean?
Details of HF error message and procedure to check and solve the issue is given below:
Or
thanks,keep updated and please do accept and rate the solution.
Sep 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error message :fh
(((fh)))
Or
Potential Causes
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Replace failed component.((usually the pressure switch and corresponding hoses will need to be replaced))
Jul 30, 2009 | Whirlpool Washing Machines
F H error message
Or
Potential Causes
Jul 13, 2009 | Washing Machines
Error message F - H
Or
Potential Causes
Jul 11, 2009 | Whirlpool Washing Machines
Fh error
Not familiar with your model, re flow meter, but.....
If after 30 seconds the control does not detect water entering machine the valves will be turned off and the error code will be displayed.
Or
Press "pause + cancel" twice to clear the display.
1. Make sure that both valves at the water source are turned on full.
2. Check for plugged or kinked inlet hoses or blocked screens in the inlet valves
3. Verify inlet valve operation if there is water in the unit:
4 Verify Drain pump operation
5. Pressure Switch Hose is in good condition and properly
connected to tub & pressure switch (which is below the
control unit)
6.Verify there is not a siphon problem
7 Verify wire harness connections to:Inlet Valves, Pressure
(CCU)
Nov 28, 2007 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
