Question about Samsung WF448AAW 4.5 cu. ft. Front Load Steam Washer
I just bought the samsung SF448 steam washer. There is one problem. The ''preset'' wash cycles are supposed to be just that. If I choose the normal cycle but add another feature such as steam or silvercare or different water temp. the next load I do will retain the last wash cycle. I called Samsung and one guy there said it might be a ''short in the memory board'' and I called again and was told that if you change something on a cycle then it stays that way. What is the point of preset cycles. You don't need them if you have to set everything every wash. Is the memory board the problem and can this be easily fixed?
Why not do the special cycle and set it as "My Cycle". that way you can keep that one special setting under this cycle and use it every time you wish to use that particular setting
Posted on Apr 06, 2009
I get the nf halfway through the cycle. ALWAYS with 26 minutes remaining after opening and shutting the door several times and can get it to resume the cycle.
SAMSUNG WF331ANW/XAA TROUBLE SHOOTING GUIDE ...
www.manualslib.com > ... > Washer > WF331ANW/XAA
View and Download Samsung WF331ANW/XAA Trouble Shooting Guide technical information online. 3.7 cu. ft. High Efficiency VRT Steam Front Load Washer (Neat White). ... DC68-02834A-03_EN. 2011-09-28. 4:00:29. Previous page ... SamsungWF337AAG · Samsung WF338AAB · Samsung WF331ANR/XAA · Samsung ...
Support - Washers WF431ABP/XAA ' Samsung Washers ...
www.samsung.com > ... > Washers
Samsung Electronics
Dec 08, 2015 | Samsung WF338AAB 4.0 cu. ft. Front Load...
Flashing light
If the cycle completes and your clothes are clean this is no issue. If the former does not happen. Then return to the store and get another machine.
Jan 24, 2014 | Samsung Washing Machines
My whirlpool steam duet washer won't pour water in the wash cycle
There is no output from the control panel to switch on the inlet valve, so check the inlet valve at this time of the cycle. Also check the water level pressure sensor switch.
Choose another program to confirm if not the controller seems to be suspect.
Jan 24, 2013 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
When I bought my Samsung steam washer, the drain hose was missing
Yes, you can put a new drain hose on yourself. You can buy one from Home Depot, Lowes, or probably even Walmart.
Jun 24, 2012 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
My samsung frontload washer stopped steaming at the end of cycle
Is your hot water valve open all the way? If you run the washer on a hot cycle only, does it fill up?
Nov 17, 2011 | Washing Machines
Not enough water in the drum during the washing cycle
If its a High efficiency washer it doesn't use much water. Usually the front load washers are HE washers
Aug 30, 2009 | Samsung WF203ANW Front Load Washer
How do I wash a down comforter on the LG steam washer?
I have done it before using the hand wash cycle. I don't know if that is the way you are supposed to do it, but it seemed to be ok and didn't ruin my down comforter.
Jul 20, 2009 | LG Washing Machines
Should the washer be hot after the rinse cycle?
Try cycling a cold/cold wash and see how that comes out.. if it comes out hot then your water inlet valve is letting hot water in when it shouldn't.. conversely, try cycling a hot/hot wash and see that it does indeed come out hot... ( quick tests to verify performance)..hope this helps.
Sep 18, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Steam cycle runs on every setting
The steam will only run on certain cycles. If you look at your dial you will see a pink line which indicates which one. Your unit does have a recirculatting pump, maybe you are confusing the two. One way to check is to run a delicate cycle. During the operation press the wash/rinse and soil level buttons together. Hold them, a display will pop up with readings in the second coloumn, and second row it will display the tempurature of the steam generator in ceilsus. This will confirm whether or not it is on.
Sgt. 48
May 29, 2008 | LG WM2688H Front Load Washer
Samsung WF448AAW 4.5 cu. ft. Front Load Steam Washer Logo
750 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
