Question about Mitsubishi CS-35707 35" TV
My 1995 36" TV screen sometimes collaspes to a vertical line and the screen is black with that verical line. It will go back to a regular full screen and work okay. Do I need some vertical part replaced? Otherwise it works good - just very seldom this happens. Thanks Jan
  • 39 Answers
Resolder vertical ic chip. that would be ic-401 on that mitsubishi. mch
Posted on Mar 09, 2009
HI When I start my ALBA TV, there are horizontal lines across the screen with high noisy sound. I bought this TV just few months ago. thank you
The horizontal line in the screen is the problem cause by vertical output driver.The vertical output is located at the verical section.Maybe theres a loose connection in vertical section or leaked capacitor.It also the cause of deffective vertical ic.So its better to repair and trouble shoot by the authorized technician.If you have knowledge in Tv.Try to replace the leaked capacitor.
Jul 17, 2011 | Televison & Video
TV MODEL :SANSUI HARD ROCK 21'' PROBLEM : TIME TO TIME ONE HORIZONTAL LINE COMING WITH BLACK SCREEN
Hi The problem of your teevision is what we called the vertical line problem.The problem is in the vertical section of the board.There are many of cause of that problem.First is either loose connection,the circuit at the vertical section have cold solder so its need to resolder using soldering iron.Second,it maybe no vertical supply,its better to check the 12 volts dc supply of vertical ic output.if thers no supply in the ic,there a open resistor near the flyback.try to replace.Third if theres no loose connection and have a voltage supply the problem is either leaked capacitor or deffective vertical ic output. Commonly in that problem is the loose connection,try to resolder the verical section.
Jul 12, 2011 | Sansui DTV2760 27" TV
The unit is only vertical line appearing in the screen,i check all the component around the vertical ic but no component defective
Tapping all around PCB for coldsolers?U resolder the vertical the IC and all the components around the IC?Still have the same reseult.Replacded the verical IC.
Sep 21, 2010 | Sanyo DS19310 19" TV
Verical lines on half of the screen
I have the same prob. Please help my *** out here!
May 25, 2010 | Toshiba REGZA 52RV530U LCD TV
Mitsubishi #35401 has only a white horizontal line across the middle of a dark screen. Please tell me the likeliest few parts to suspect. Thanks, RenThelp@aol.com, or 1 800 662 6231
Sounds like Vertical collaspe, Problem is in your Verical circuit
I need you to look on back of TV for correct Model number WD?
Thank You.
Feb 17, 2010 | Mitsubishi Televison & Video
Have ilo lct32ha36 and powers on and hear sound, but black screen
you have a bad master and slave inverter board these are the skinny boards that go verical on the back of the unit
take you unit apart remove back and look at the back of the tv face down on a blanket remove all the screens take the back off remove those two board going vertical look up both parts on google or call or go to shopjimmys.com
Oct 19, 2009 | iLO LCT32HA36 Television
On a Samsung HL-R5087W TV i have 10 rows with 8 lines per row going across the screen vertically. These lines are Black. Please HELP!!!
Single Pixel width Verical Lines in all video inputs including OSD
This is caused by a defective DMD Board
Jul 22, 2009 | Televison & Video
Black screen with colored vertical lines
YPU HAVE A BAD PANEL. THE COST OF REPAIR WILL PROBABLY EXCEED THE VALUE OF THE SET.
Mar 20, 2009 | Panasonic TC-26LX20 26 in. HD-Ready LCD...
Televison & Video Logo
114 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
