Question about FrancisFrancis! X1 Espresso Machine
Francis francis X1 the water supply seems to be lacking pressure
When the coffee is brewed it comes out very slow.  it takes a long time and the pump seems like it struggling.
  • Anonymous Mar 15, 2014
    Hi! I have problem with the pressure with my x7. Coffee is just driping out. In the manual there is nothing in troubleshouting section. What it could be and what should I do?
  • 8,596 Answers
I would go ahead and run a solution of 50% distilled white vinegar and 50% water through the machine. If the machine still runs slow after that, pour another 50/50 vinegar/water solution into there - let it run just enough so that the vinegar water starts to drip out, then cut the machine off. Let the vinegar/water sit in the machine for about 20 minutes. Then cut the machine on and let the rest of the solution run through. Then run plain water through the machine to clear out the vinegar. Try brewing a batch and see if the machine behaves normally.
If the above fails to resolve the issue, the FrancisFrancis machines are now owned by illy, so would need to contact them for further TS.
-Tha Mp3 Doctor
Posted on Mar 09, 2009
"francis francis" x1 blocked - Fix Suggestions?
You can tell if the pump is working by the noise it makes. Mine got blocked with scale and I took it apart and cleaned out the boiler. It's possible; the boiler is bolted together with standard bolts (metric size). If you've got the interest the Francis Francis is easy to service; you will find a way into each part of it and clean it, and if you do it will work like new.
Jun 22, 2014 | FrancisFrancis! Coffee Makers & Espresso...
Ground Coffee Kit/Holder
There were two versions of the Francis Francis X1; one without the logo (older) and one with. I guess your only chance is ebay; but why would someone sell the holder without the machine?
May 27, 2014 | FrancisFrancis! X1 Espresso Machine
Francis francis espresso wont pump water but steamer works?
The main problem with coffee machines is they get furred up with limescale. If you let it go too long they can stop working like this. It's not difficult to take the machine apart if you're mechanically inclined and then you can clean each part.
Jan 02, 2014 | FrancisFrancis! X1 Espresso Machine
My francis francis x1 has started running very slowly, it takes about 2x longer for the shot to finish coming out than it used to.
Hi
You might need a new pump or relief valve on the pressure end of the pump. There is a hose the goes back to the water tank in the back from the relief valve. See if water is going back into the tank when you are brewing?
Dec 31, 2009 | FrancisFrancis! X1 - Stainless Steel...
Francis Francis X1 pump replacement.
http://www.craystone.com/francis/francisfrancisfaq.html
for spares Espresso Parts, Tel: 0870 3851531
Oct 20, 2009 | FrancisFrancis! X1 - Stainless Steel...
Francis Francis X1 - Cleaning lime from tank
CLR rinse followed by a vinegar brew then a clear water brew cycle
May 21, 2009 | FrancisFrancis! X1 - Stainless Steel...
Francis francis x5-espresso splatters all over
1) The coffee you are using may not be ground finely enough to provide a proper extraction time, resulting in water rushing through the ground coffee much too quickly. Think of it like water running through a handful of pebbles as opposed to a handful of sand. You want "sandier" coffee.
2) Your gasket (the rubber part that seals the portafilter to the group head) may be worn/damaged and is leaking water when you are brewing. Attempt to contact FF! or Saeco to secure a replacement gasket. When you are not using the machine, don't tighten the portafilter all the way in to the head, either leave it completely disengaged or only loosely attached. This saves wear on the gasket.
3) Your brew water may be too hot. Purge your boiler right before brewing by running water into a bowl without the portafilter locked in. After a few seconds the superheated water will be run out and you're ready to brew.
Mar 13, 2009 | FrancisFrancis! X5 Espresso Machine
Francis Francis! x1 leaking
Well, to state the obvious, you should call Francis! Francis! at 1-877-854-4141 and ship it to them for repair. It's unlikely you can perform a fix yourself. Have you tried opening the machine up? I got PDFs of diagrams and part lists, which I obtained by calling them at the number quoted above. Good luck! Stephen
Dec 13, 2007 | FrancisFrancis! X1 - Stainless Steel...
FrancisFrancis! X1 Espresso Machine Logo
771 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Joe Lalumia aka...
Joe Lalumia aka...
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
