Question about Electric Intermatic 7 Day Digital Timer 500 Watt 120 Volt Heavy Duty
Intermatic Timer display reads NO OP SEE INSTRUCTIONS
When I changed to DST this morning the timer would not shut out the light. This is a wall mounted timer and controls a ceiling light fixture.
  • 37 Answers
SOURCE: remove Intermatic 60 min. wall timer face plate only from wall
That knob should just pull straight off. Check to make sure there isn't a tiny set screw on the side, but otherwise you can pull it off and remove the cover plate.
Posted on Jan 24, 2009
  • 363 Answers
SOURCE: ceiling fan controled by intermatic e1010/e102 doesn't come on
If you are getting heat on the timer it is time to replace it
Posted on Jul 28, 2009
SOURCE: Need instructions to program Intermatic
Do you mean Intermatic E104C box-type timer? Intermatic does not make E140C
Manual says "refer to programming instructions on time switch door"
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et104c%20-%20english.ashx
Manual says timer has 8 events per 24-hour day ... 4 'on' events and 4 'off' events. Normal operations, selectors are set to AUTO and RUN.
Using sketchy info from manual about programming:
Set sliders to MANUAL & TIME/SET
Press EVENT for event 1 ... set hour and minute using HOUR & MIN buttons ... this will be 'on' time
Press EVENT for event 2 ... set hour and minute ... this will be 'off' time
Set all 8 events ... 4 'on' and 4 'off'
Move sliders to AUTO & RUN for timer operation
Posted on Sep 17, 2010
  • 760 Answers
SOURCE: I have an Intermatic Model
Go to www.intermatic.com Notice there is a recall for this model timer with codes 40z to 52z. Contact Intermatic for replacement. Here is link to the DT-17C probably same instructions.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt17c%20-%20english.ashx
Posted on Oct 04, 2010
SOURCE: Utilitech 7 day in-wall digital timer #LW60418
Need programing instructions
Posted on Nov 13, 2010
Hunter ceiling fan/light unit install with 3 pole switches. there are 2 white, 2 black and one orange wires coming out of the electrical box. How do i handle the installation?
Not understanding, three pole switch is a wrong switch, wires in the ceiling or wall electric box.
Needed: What switch is existing and what wires are in the switch box and runs or groups in each run coming in as wire groups. Same for ceiling box, colors and wires in each run coming in.
Basically, remove the existing ceiling fixture and connect the ceiling fan replacing the fixture to the same wires the fixture was connected to. White to white, green or bare to green or bare, colored wire to fan's blue and black. Wired like this one switch controls both fan and light, on and off at same time. Use fan pull chain switch for individual fan or light control.
Oct 22, 2017 | Hunter Dryers
Why does fan no longer respond to remote?
Remote controlled ceiling fans do not respond favorably to wall switches. To restore order, you will have to start over. Shut down fan power at the source. Set the wall switch to ON and promise to never, ever use it again. Turn on power at the source. Try remote fan and light control functions. If either does not work, there could be pull-chain switches on the fixture that are interfering. Troubleshoot to get both fan and lights controlled only by the remote.
Mar 30, 2016 | Dryers
We have Lithonia 2 bulb fixtures in a recessed ceiling. We currently have 2 (25) watt bulbs in them. What wattage can I upgrade to ??
The ballast inside the fixture is rated to operate 2 25w bulbs. You can't put higher wattage bulbs in this fixture, unless you change the ballast. Sorry.
Sep 22, 2014 | Lithonia Lighting Fluorescent Flush Mount...
I want to replace a ceiling light fixture with a ceiling fan/light combo. the existing fixture is about 32 inches from a wall. what size fan can I put there?
I have replaced a couple ceiling light fixtures with ceiling fan/light combos in bedrooms where the light was basically in the center of the room. This was fairly straight forward and for me required replacing the electrical box that the light fixture was using with a heavier duty fan mounting box which you should make sure you use (that way the fan/light combo won't fall on your head later on -- literally). As far as the size of fan you can put there depends on whether the fan mounting electrical box can be mounted in the "exact" position of your original ceiling light fixture. I say this because the new box MUST be anchored to the ceiling joist structure in some way as a ceiling fan (usually) weighs more than a light fixture and tends to vibrate lending to more stress on the electrical box it's mounted to. Have someone who is an electrician or at the very least has a clear understanding of the importance of proper electrical work do the work or at least clearly explain what you need in your specific situation.
It is generally accepted that you should have at least 18" of space between a wall and the tip of your fan blade. In order to do this with the 32" figure you gave, ideally you should have a (32" - 18") x 2 = 28" fan. A fan in the 28" to 30" range is probably about as big as you should go in this area. You could technically place a 60" fan in that location and leave only about 2" of space between the fan blade and the wall, but that's asking for trouble and should NOT be done in my opinion. The smaller the fan, the less air you will be able to move, therefore you need to balance size, air flow requirements, and the restrictions of your particular location with what you can put there.
Do a quick internet search on "what size ceiling fan do I need" for more information on this topic.
May 26, 2014 | Computers & Internet
Hampton Bay Sidewinder ceiling fan. For ten years, wall mounted control functioned until it 'blew' when electrician was working on a remodel of another room. Installed another control (Progressive...
You called customer care about a Hampton Bay & they sent you Minka Aire??? Hampton Bay is a store brand for Home Depot. If The fan came with a remote, you probably need the one for your fan.
Aug 24, 2013 | Hampton Bay Sidewinder 04890 Ceiling Fan
I have a Intermatic self-adjusting wall switch timer and I can't program it even though I have followed the instructions 3 times.
Program 1 is ON, and program 2 is OFF, 3 is ON, and 4 is OFF, etc
Copy following link for EZ step-by-step programming for ST01C timer:
http://waterheatertimer.org/ST01C-program.html
Jun 05, 2012 | Intermatic Inc. ST01C Digital In-Wall...
Hello, I have a ceiling light fixture however there is nowhere I can install it on my ceiling. I have decided to run a wire from the light fixture along the ceiling to the wall and down to an electrical...
What you want to do is against the National
Electrical Code & unsafe
Install a proper box in the ceiling for the
light fixture
Never use exposed cords
Jun 29, 2011 | Hammering
Intermatic in wall timer , will not switch off. "no Op" shows on screen. I replaced battery.
You posted under Intermatic battery-operated in-wall timer.
That means you have EJ500, ST01C, EI600 timer or EI400.
http://waterheatertimer.org/Flipdown.html
1) No-op means fatal operation error, and timer needs to be replaced.
2) Since fixya customers only like good news:
Intermatic has 1 year limited warranty on these timers if you can demonstrate proof of purchase.
As of right now, April 2011 Intermatic website is closed weekends.
https://parts.intermatic.com/
3) You can try re-seting timer by holding down on-off and then pushing reset button momentarily. Keep holding on-off button until display changes, then release on-off. Then reprogram timer.
Instructions show that resetting timer is last-resort troubleshoot, and if timer does not function afterward, then timer has fatal malfunction.
4) I read where no-op can be fixed by opening timer and adding oil to a gear, but I cannot confirm this and am not going to take apart my test timers.
Since your timer is not working, please take it apart and then add a comment to this thread to confirm or repeal the oil-gear suggestion. I would very much like to know this information, and you can add a photo to your comment showing others how to do it.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment for more free help
5) Pay: Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 30, 2011 | Intermatic Programmable 24 Wall Switch...
How to wire this fan
The wiring on most paddle / ceiling fans id such:
White = Fan and Light neutral or "common"
Black = Fan line voltage or "hot"
Blue = Light line voltage or "hot"
Green = safety ground
If you are replacing an existing light fixture - be sure to replace the ceiling box with one designed for use with a fan - as per electrical code. If the existing box had only 2 wires (or 3 counting the ground) that connected to the old light fixture and it was controlled from a wall switch, the wiring would be fixture white to ceiling white, fixture black and fixture blue to ceiling black (or red) and fixture green to ceiling bare ground or connected to the metal box. This would power both the fan and light whenever the wall switch was on and the pull chains for each were also on. This is also the preferred wiring for replacement of a pull chain type light fixture (no wall switch present).
If there are other wires in the box that previously were not connected to the old light fixture, using a meter or tester - determine if there is constant power between the ceiling white wire and any of the these other wires (test with the wall switch on and off to be sure). If you do have constant power available, you might consider using the wall switch to control only the light, and using the pull chain to operate the fan (or vice-versa). Simply connect the black (for fan) or the blue (for light) to the "constant power on" wire and that part of the fixture will work by pull chain only - regardless of the wall switch position. If the fan can be shut off by the wall switch, it is very important that the wall switch remain a toggle (or on / off switch), do NOT replace with a dimmer type switch.
If you'd prefer to operate the fan and light completely independently of each other - you can purchase a 3rd party fan & light remote control device for between $30 - $50.
I hope this helps and good luck! Please rate my reply. Thanks!
Apr 22, 2011 | Aloha Housewares (93645) Ceiling Fan
Electric Intermatic 7 Day Digital Timer 500 Watt 120 Volt Heavy Duty Logo
1,506 people viewed this question
Top Electric Hardware & Accessories Experts
pawnpower
ray gallant
Are you an Electric Hardware and Accessory Expert? Answer questions, earn points and help others
