Question about Remington Polesaw Wizard
How to change polarity on remington elect.chain saw
I instaled new brushs in my 14"remington chain saw and now it runs backward. how do i reverse the polarity?
model no lnt 1
serial no c278579
thank you
dontbother10
  • 2220 Answers
SOURCE: where can I get parts
Your model is LNT-2 you can find an IPL here:
http://www.desaparts.com/remington-chainsaw.html
I recommend you print it. Click the part number you need. HTH
Lou
Posted on Sep 26, 2009
dontbother10
  • 2220 Answers
SOURCE: repair parts for LNT-2 remington chainsaw
I went here:
Remington.com
http://www.desaparts.com/index.htm
  • Typed "LNT-2" into the "Model #:" window, then clicked search.
  • Click the LNT-2 12 - Remington Electric Chain Saw "View Model" link.
  • Click "View Illustrated Parts Breakdown" I think you want item 12, 107713-01, Internal Gear
  • On the original view in the "Search for your parts by Part #:" type "107713-01" and click "Search"
  • Click the 107713-01 - USE REPLACEMENT PART # 122511-01 "View Part" link.
Results follow:
Part #: 122511-01 Price: $16.99
SPROCKET DRIVE GEAR BEARING KIT 747
3 piece replacement kit.
If this is what you need I suggest you order it soon.
RemingtonPower has stopped production and replacement pars are almost exhausted. Sooner or later a part you need will be NLA. HTH
Lou
Posted on Nov 10, 2009
dontbother10
  • 2220 Answers
SOURCE: 14" Remington chain replacement
I input "Remington; EL-1; 14"; All; All; All" here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
It returned "91VG050G, 91VX050G or 91VXL050G". Please read the triangular warning placards. The original chain is most likely green.
Column 4 says a 14" chain has 50 drive links (the part in the bar groove". Please count them, if you get a different number try a different length bar. The Oregon part number can be ordered on line or if given to a local merchant fabricated in their facility.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Apr 11, 2010
wentlanv
  • 710 Answers
SOURCE: Need replacement chain for remington
Hi jvaltha,
Here is a website that carries the chain for your EL-1 saw: http://shoppingcart.msservicecompany.com/default.aspx?ext=true&itemid=091374S&size=small The part number is a replacement for the original chain, which Remington must not offer any more.
That same site also carries a chain for your LNT 8 saw, but there are different subcategores, LNT1, LNT2, and 8A and B. I'll paste the address for the page where you have to choose your option: http://www.desaparts.com/remington-chainsaw.html
FYI, You don't need to buy a remington chain to fit your saws. Just buy a chain that is the right length and matches the rest of the specs on your chain, the pitch etc. .050,.025, and so many teeth per inch and so forth. Then you can buy locally.
Hope this helps. If it does, I'd appreciate a 4 thumbs up...keeps me working. Thanks,
Handie Andie
Posted on May 09, 2011
wesleydoan
SOURCE: I just bought a replacement chain saw blade for my
well im haveing the same problem with a remington 14 in chainsaw the reg blades i find are to big so far all i can find online is that it takes a PN#14sc or M14SC
Posted on Apr 02, 2012
Need brushes for a 111409-01 branch wizard
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
May 03, 2014 | Remington Electric Chain Saw
Trouble starting
If you're Remington Pole Saw is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Apr 19, 2014 | Remington Electric Chain Saw
Are brushes available for remington 106890-02
Nov 06, 2013 | Remington Electric Chain Saw
Electric chain saw pole wouldn't cut branches
Check to make sure the blade is not installed backwards. It's an easy mistake to make, everything will work OK, but the saw won't cut if the blade is on backwards.
Mar 15, 2012 | Remington Electric Chain Saw
THE CHAIN SAW RUNS. THE CHAIN XS NEW. IT DOESN'T CUT THE SMALLEST OF BRANCHES
I don't mean to sound offensive, but is the chain on the right way? I've put 'em on backwards, even started the saw before I noticed. And is the chain running when the motor runs?
If the chain is right then you may have gotten a chain with a bad grind. Never heard of it but it could sure happen. Get back with me if the chain is right and it's turning- we'll get it to cut.
lp
Jan 10, 2011 | Remington 111409 - 01 6" Branch Wizard...
The switch of the saw is not working 00
You need an AC voltmeter to trace the problem with the switch. It can also be a bad motor brush/spring--these saws are great for killing motor brushes, and there are virtually no replacements available as Remington has ceased saw operations. If it is a bad brush, visit an electrical tool shop to see if they have something that will work from a different brand of tool. Good luck!
Jun 28, 2010 | Remington 16" Electric Chain Saw
Saw overheated and the brushes burnt up. Need a
Your only hope is to find similar brushes made for some other tool. Remington saw has gone out of business. This seems to be a common problem with this brand of saw. Good luck!
May 30, 2010 | Remington 16" Electric Chain Saw
How to repair chain on saw? need picture on how to re-install chain
You can download a very Remington OM here:
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
A few minutes spent reading will doubtless answer all questions.
I think this is what you requested.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
Please look carefully at the orientation of the expanded chain. It is possible to install a chain backward. Good Luck. HTH.
Lou
Feb 26, 2010 | Remington Electric Pole Saw
I have a Remington Electric Chain Saw and have lost the manual. Where can I get one? Model No. M15014US 14'' Bar 114731-01S Chain 114735-01S I have tried searching the Web for one and can't get a...
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
Enter M15014US (your saw) in the “Search for your unit by Model” window. You can find both an Operator's Manual and IPL. I recommend you download both.
Item 4 lists available bars for your saw, a 14" bar for your saw is pn 114731-01S, $17.85 if available.
Item 5 lists available chains for your saw, a 14" chain for your saw is pn 114735-01S updates to M14SC
, $12.95 if available. You can probably take your chain to a neighborhood chainsaw shop and have a replacement made cheaper.
Remington has ceased production and replacement parts are limited to what is on hand. HTH
Lou
Oct 29, 2009 | Remington Electric Chain Saw
Remington electric chain saw 3.5 -14''
I just had my Rem. EL-8 (Mod#107624-02, 3 HP 11.5Amp) quit, too. It was less than 2yrs old, had very low hours and no abuse. I pulled it apart and found that a motor brush was burned out (at the brush electrical lead; the braided wire connecting to the winding). Unfortunately, I checked with Master Distributors (http://www.nbmc.com/ ) and the brush assembly is no longer available. (For a less than 2-year old saw!!) They do have some parts for Remington saws, however.
Premature burnout seems to be a function of some combination of:
- using a too-light gauge extension cord for the amperage of your tool / length of extension. You can find recommendations for proper minimum gauge on the web. (This shouldn't have been the problem in my case because I used a 12-ga. 25' extension.) See: http://www.askthebuilder.com/B174_Extension_Cord_Size_Chart.shtml
- running too hard (big wood) for too long. I admit this seems pretty subjective; if the saw is cutting, why quit, right? But it's probably important to ease up and not let it get too hot.
- poor saw design. (internal parts don't match the power/amperage involved.)
~Roger
Nov 17, 2008 | Remington Electric Chain Saw
Remington Polesaw Wizard Logo
94 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
