Question about Dishwashers
Only one function works on my main panel
On my main function panel only the normal function works, other the others don't work and nothing lights up either. Please let me know what the problem could be?
    Novelist:
  • 108 Answers
If the problem is that only one button (normal cycle) works when you press it and none of the others do, then you have most likely a bad keypad, but possibly a bad circuit board. It's difficult to say without knowing which model of dishwasher you have.
The repair is not really that difficult, but you should probably order both from someplace with a good return policy, then change the keypad first and see if that works. If it works, return the circuit board. If it doesn't work, put the new circuit board in.
Posted on Mar 09, 2009
We were listening to music , cd , & a buzzing sound came over sound system then nothing. no functions work at all. Main board lights up but that is it.
If the screen lights up then shuts down this could mean it's going into safe mode the other option is that part of the power supply could of failed this is normally only a capacitor or resistor
Aug 03, 2013 | Denon AVR-2307Ci Receiver
Lights don't work
test the following steps and fix it.use the VOM3eb53373-1eb1-4bb3-9641-1a202781b5bf.gif God bless you
1. No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
3. Open thermal protector or thermal fuse.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models).
Jun 17, 2013 | Sharp R-1480 Microwave Oven
My leisure dwlt65 dishwasher keeps switching its self off when going till wash
see this causes and fix it. God bless you
Touchpad and Control Panel If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been have ruled out, the main control board might need to be replaced.
Sep 28, 2012 | Leisure DWLT65 Dishwasher
Dashboard lights not working and brake light also not working but all the other lights work
Check the fuse, the fuse must be in the main fuse box. The position and function of the fuses is normally marked on the inside of the fuse box cover and also in the owner's handbook. If you don't come right with these, work your way through the fuses looking for a blown one. To ease your search for the required, fuse it should be around 20 amps.
Apr 24, 2011 | 1998 Ford Taurus
My panel light is out. is it a fuse? what number?
If it only the panel light it would not be a fuse, There are normally other curcuits on the panel light fuse, like the tail lights. If those are out check the fuses. The fuse must be in the main fuse box. The position and function of the fuses is normally marked on the inside of the fuse box cover and also in the owner's handbook. If you don't come right with these, work your way through the fuses looking for a blown one. To ease your search the panel/tail light fuse it should be around 15 to 20 amps.
Feb 21, 2011 | 2003 Mercury Sable
Exact same problem - Needlenose slipped and spark in the socket
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You have a short in one of the door safety switches
There function is prevent the oven to work whit the door open
some are normally close and some normally open when one of then don’t work properly causes a short and blow the main fuse check the all and replace the faulty one but be careful and don’t test the microwave
Whit the cover removed.
Note:
if you have a blown fuse buy several emplacement fuses because my take several trays to fix the problem and you will need more than one fuse.
Jun 08, 2009 | Whirlpool MH1150XMQ Microwave Oven
Washer not working
Okay...try unplugging the washer for AT LEAST 30 minutes. This will often cure momentary glitches with the washer computer. After the washer has been reset, attempt the start a load and let me know if it functions normally. If it doesn't, let me know what the front panel display reads.
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Panasonic ag-dv2500 dv-tape recorder
check the "remote" switch on the front panel; make sure it is in the "off" position. if it is in any other position, the function buttons are disabled.
Jun 23, 2008 | Panasonic Proline AG-DV2500
Normal Light Blinking - Dishwasher not working
I HAD THIS SAME PROBLEM. TRY PUSHING THIS SEQUENCE OF BUTTONS: HEATED DRY, NORMAL, HEATED DRY, NORMAL. THIS RESET MY PANEL AND IT IS WORKING NORMALLY NOW. I FOUND THIS SUGGESTION ON ANOTHER SITE.
Sep 14, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
102 people viewed this question
Top Dishwashers Experts
