Question about Black & Decker Black And Decker Cyclone 4 In 1 Multi-sander, Ms1000
How to remove round sander for iron shaped one
I want to remove the round sander and use the sander that is shaped like an iron. I can't get the round one off and have lost the manuel
  • Anonymous Mar 31, 2014
    Remove bottom plat from orbital sander.
    There is a white plastic cap in center plate. How do I get this off to get to the bearing that is jammed.
    President:
  • 1,996 Answers
You need to remove the allen head cap screw in the center of the base, then remove the washer, and pull the base straight down off the sander. If you can't get it to pull off, try gently rocking it a little as you exert pressure to pull it off.
Random orbit sanding base
With this sanding base, you can use the tool as a random orbit sander.
Fitting and removing the sanding base (fig. B)
- Place the sanding base (3) onto the spindle (10).
- Place the washer (7) onto the spindle.
- Insert the Allen screw (8) into the screw hole in the spindle.
- Tighten the Allen screw using the Allen key (9) supplied.
- To remove the sanding base, remove the Allen screw (8) and washer (7).
Fitting sanding sheets (fig. C)
- Hold the tool with the sanding base (3) facing upwards.
- Place the sanding sheet (11) onto the sanding base (3). The holes in the sheet do not need
to line up with the holes in the base.
Large detail sanding base
With this sanding base, you can use the tool as a detail sander or an orbital sander.
Fitting and removing the sanding base (fig. D & E)
For detail sanding, the pointed end should face forward as in fig. D. For sanding large areas,
the pointed end should face to the back as in fig. E.
- Place the sanding base (12) onto the spindle (10). Make sure that the legs of the base
locate into the tool.
You can also view the factory manual here: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/479727-00,MS1000%20SANDER.pdf
Be patient, and good luck! Let me know if this doesn't solve your problem and you still need help!
Posted on Mar 24, 2009
Durabuilt 3"X21" Belts Sander Brushes. Question: Should I replace brushes or buy new sander?
If the sander is otherwise in good shape, and hasn't been abused, I'd replace the brushes.
Jul 11, 2014 | Greenfield Industries Measuring Tools &...
Tip
How To Re-Wax a Wood Deck for a Trotter Treadmill
Following are instructions on how to re-wax a wood deck for a Trotter treadmill and a list of materials needed for this procedure
Materials Needed for Re-Wax
  • 1 lb. of Trotter deck wax
  • Clothes iron (never to be used on clothing again)
  • Belt sander with 120 grit sanding belt
  • Vibrating sander with 250 and 400 grit paper
Pre-Existing condition: If your wood Trotter treadmill deck is worn down through the first ply, it cannot be re-waxed.
  1. Using a belt sander and 120-grit belt, gently sand in the same direction as the grain the glazed layer off the top of the deck until you have reached porous wood. If, while sanding, the first layer of ply has been sanded off, the deck can no longer be re-waxed
  2. Using a vibrating sander with 250-grit paper, sand the entire top surface of the deck until it is smooth and soft.
  3. After sanding with the 250-grit paper, continue sanding with 400-grit paper until completely smooth.
  4. Heat the clothes iron to its maximum temperature. Put a handful of Trotter deck wax on the center surface of the deck and place the preheated iron on top of it until the wax melts.
  5. Work the wax into the deck surface by pushing the melted wax across the deck with the iron. Add more wax as needed until the entire top surface of the deck is impregnated with wax.
  6. Apply just enough wax until the wood is saturated with wax.
Do NOT leave wax pooling on the surface of the deck.
How To Re Wax Wood Trotter Treadmill Deck
on Mar 11, 2015 | Exercise & Fitness
Towel caught in front roller
Well, it sounds like you have a belt sander. I would start by sacrificing the towel and the belt. Even if you tried all day and were able to save them they would probably look like they got caught in a sander. Get a utility knife and change the blade, you will want a brand new sharp blade for this. Start by cutting as much of the exposed towel off as you can. Remember, at this point the only thing you might be able to save is the sander. Cutting off the belt will relieve the tension. When you cut the belt give yourself enough belt on ether side to get a good grip. You might need to pull the belt back and forth as you remove small pieces of the towel. A good pair of pliers might help grip the towel fragments. When you finally do remove all the towel and the belt, take some time to look around the drum for fibers that might be stuck in the bearings and pull them out. You may need needle knows pliers for this. Keep the towel shreds for sating rags to finish the project you're working on so it will not be a total waist.
Good Luck
Ray
Apr 28, 2014 | Makita Tools & Hardware - Others
HOW DO I REPLACE A TIMING BELT ON A 3" X 18" BELT SANDER
On the side of the sander there is a black triangle shaped cover with 3 screws holding it in place. Remove the screws and you will see the drive belt and 2 pullies or gears. The belt will be attached to the gears. Remove and replace the belt. Typically the belt is broken so the only thing you will need is to locate a new belt and slip in over the gears with the side with the teeth facing the gears. This keeps the belt from slipping. Reinstall the cover and you are ready to go back to work. The hardest part may be finding a supplier for the belt.
Aug 06, 2011 | Black & Decker BR300 3''x18'' Belt Sander
Need motor brushes for a stanley heavy duty 4'x24' belt sander. type: 497, model A, amps: hi-8.5, lo-7.0, volts 115, serial # 457244. thanks, tom
Hiya
I had the same problem, cannot find spares. I went to a local tool hire company and purchased two brushes (Part No. L41F10). You will need to shorten them by approx.1/4"", swap the springs and cut down the metal terminal to same shape as the original. A small 1/2 round file, junior hacksaw and about 15 minutes should get you going.
I am looking for a trigger (on/off) switch to suit my sander, if anyone can help I would appreciate it. Only other option seems to fit an inline switch to supply cable.
Jun 15, 2011 | Garden
I am looking for some information on how to interchange the sander heads for my B&D sander. It says on the box that it is a 4 in 1. I am suppose to be able to change the sander head from round to the...
if you misplaced the operator manual you can download it from Dewaltservicenet.com it is 36 pages long but from what I just read there is a release button on the front UNPLUG TOOL FIRST holding the tool upside down push the release button and pull the attachment off and install whatever other one you want to use. As to the bag it just says to pull the canister off the dust port and empty over a garbage can, and push it back on. I would recommend looking at the manual as I did the info you neeed is around page 7-10 let me know if you need more help. The model number I used was MS2000
Feb 24, 2011 | Black & Decker Tools & Hardware - Others
I have a MS1000 Black and Decker Cyclone round sander..looking for replacement sanding disc
Hello, W/D here.
Most sanding disc types are available at the larger box hardware stores. They are (sometimes) generic or exact replacements.
I use the "Gator" brand on my B7D sander, and the discs work just fine.
Best regards, --W/D--
Feb 23, 2011 | Black & Decker Black And Decker Cyclone 4...
My beloved sander dosn't get up to speed and is starting to make a grinding noise; is there maintenance I should be doing? Possibly replace motor bushings? Bearings???
I just had the same problem with mine. I replaced the motor start capacitor with one from Grainger and it starts like a champ now. I found one that had the same specs as the stock one and it also fits inside the cover perfectly. Here are my notes:
Grainger Item 2MDR5
MFD Rating: 189-227
Voltage: 110-125
Hz: 60/50
Shape: Round
Dia. (In.): 1-7/16
Case Height (In.): 2-3/4
Overall Height (In.): 2-3/4
Original start capacitor was:
CD60
125/156V AV
200 UF
Blue shrink wrapped can with pigtails.
Length: 81mm (3.19")
Diameter: 34mm (1.34")
Feb 02, 2011 | Delta 31 - 120 12" Disc Sander
The belts on my Makita 9304 belt sander are wearing unevenly
check the wear plate on the bottom and also check the front roller for being out of round is where I would start. Let me know if doesnt help
Feb 17, 2009 | Makita 9404 4'' x 24'' Belt Sander
Black & Decker Black And Decker Cyclone 4 In 1 Multi-sander, Ms1000 Logo
538 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
