My domain air 2.65kw portable ac unit - E4
My domain air 2.65kw portable ac unit is turning itself off and displaying E4 fault. Can some body please explain
  • shelleystone Mar 09, 2009
    Filter(s) all clean. Pump is working. Any other ideas?????
  • shelleystone Mar 10, 2009
    Thanks, I will investigate.
  • 400 Answers
Make sure the filter is clean and the pump is operating.
Posted on Mar 09, 2009
  • Shane Seaman Mar 10, 2009
    I think it has a faulty water sensor and is switching off because it thinks that the water has run out?
Did you work out what it was because mine is now doing the same thing - i accidentally had the outlet stuffed with foam to stop bugs getting in (long story) and ran it on a hot day and it went POP E4 - and works fine but now it blows fan only its not cold at all - im shattered i just paid 55o for it :(
Posted on Nov 08, 2009
Eurodib Portable AC E4 Error code
Make sure the condenser and evaporator fins are clean, and that there are the condensate drain hole or hose is not clogged. Also, check the blower or fan bearings to make sure they turn freely without grinding or noticeable sideways slop.
Jul 03, 2017 | Heating & Cooling
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
E4 error on Yamatsu S-24H air conditioner ?
E4Fault indoor coil sensor (open or closed). Replace it.
Dec 14, 2010 | DeLonghi PAC85 Portable Air Conditioner
Error code E2 A.C. AUX
Disply E2 error Coming
Jul 23, 2010 | Heating & Cooling
E4 ERROR MESSAGE ON SCREEN OF GE PORTABLE AC MODEL APE08AJM1
WATER BUCKET IS THE FAULT
the switch is more likely the cause try removing bucket and pressing lever manualy by hand then start it up again if it works you know the prob as this was mine the plastic connection aint the best
Sep 26, 2008 | GE APN10AA Portable Air Conditioner
WRAC has E4 on display
E4 means return air sensor error, if the error cannot reset may be the return air sensor is out of range or defective. But if the sensor is ok you need to replace the control board itself. The reading of return air sensor is 8k to 10k ohms @ 25deg. C temperature.
Jan 13, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Kenwood KW85 Portable Air Conditioner
Using remote control "on" the unit, then push the C button of remote control, if the C display at the unit "off" the unit using also the remote control. Unplug the power supply then plug again and start the unit using the remote control.
It the instruction above don't solve the problem, the return air sensor is out of range or the main board of the unit itself is defective. You need a qualified tech with this problem.
Oct 15, 2007 | Kenwood KW85 Air Conditioner
E4 Error Message
ok sir! are you sure is the sensor are cleaned? your unit need to general cleaning specially the sensors!
Oct 16, 2007 | Kenwood KW85 Air Conditioner
Start the unit and press the remote control at C if the display in the unit displays C, then turn off the unit using the remote control and plug out the ac supply. Plug the unit again and using the remote control turn on the unit. If the E4 still display there is something wrong with your air in sensor or the main board itself. Replacement of this parts needs a qualified technician.
Aug 30, 2007 | Kenwood KW85 Air Conditioner
Heating & Cooling Logo
522 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
