Question about Whirlpool Duet GHW9150P Front Load Washer
Washer showing f-21 code pump not pumping water
I took the pump off and the fan has a hole wore in it could this be the problem?
  • 163 Answers
Yes you will need to replace your pump.
Posted on Mar 09, 2009
  • 40 Answers
Yes I would change your pump that is a drain fault code
Posted on Mar 08, 2009
F-21 CODE on maytag 4000 series washer
F21--Long drain
long drain means it is taking to long to drain the water out of the drum.
the pump might be on its way out. running slow faulting.
or it is still is blocked further back.
Nov 14, 2013 | Maytag Washing Machines
I hav error 21
I had the same issue with Out of Service 21. The pump was making noise during Self-test, then the error. I took the entire thing apart. I removed the pump, cleaned all the plastic/rubber parts, and reassembled. All seems to work now. The final piece that I cleaned was a tiny black washer inside the bottom portion of the plastic assembly that inserts into the pump solenoid. In the bottom of that piece (about 1/2 threaded) you'll see a star-shaped piece of plastic threaded INSIDE the barrel. I turned that out, cleaned the tiny black washer that blocks the hole, cleaned the spring, and turned the star piece back in. That seems to be what fixed it for me. However, error 21 in the manual indicates ANY issue with water flow.
Apr 24, 2011 | Lavazza LB2210 Aluminum
Washer pouring water out the bottom of the bottom of the washer.
sounds like the discharge pump got some coins in it and wore a hole in the pump housing. you can either buy a new pump or try to repair the pump you have. i repaired my pump by dismantling it and then i bought a flat head nylon bolt and a nut and some epoxy putty and i plugged the hole with the putty and the bolt. but you will need to get all of the coins out of the tub. it takes a while.
Feb 08, 2011 | Maytag Bravos MTW6600T Top Load Washer
CODE F-21 NOT SPINNING THE WATER OUT when it comes to the rinse cycle . IT MAKES A CLICK SOUND AND STOPS . THEN IT SHOWS CODE F-21
The machine is not spinning the water out because there's a problem with the drain system as the error code indicates. Either the drain hose is clogged or kinked, the pump filter is blocked, the pump impeller is blocked or damaged or the pump itself is not working at all. The click sound may due to a blocked pump impeller.
Disconnect power and the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter from the pump housing by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02/F21 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Dec 31, 2010 | Kenmore HE2 Plus Front Load Washer
I cleaned the pump filter after getting sud error. now i get F 21 code.
Press the pause cancel button 2 times this should clear it. If it does not and the filter and drain hose are clear you will need to replace the pump.
F21 Fault Code Repair
LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
LONG DRAIN
NOTES:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
LONG DRAIN
NOTES:
Nov 03, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Code F 21 is showing and the washer door is locked
if there is water in the unit the you can use a wet dry shop vac and attach it to the end of the drain hose.
once all the water is removed then you should be able to open the door. after all the water is gone check the drain pump for something that may be obstructiong the pump.
if your water is coming out slow then this is a good indication of a blockage.
Feb 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-21 error means What?
F-21=LONG DRAIN If the drain time exceeds 8 minutes the water valves shut down. After 4 mins the Sd(slow drain) error will be displayed, 4 mins later the F/21 error code will be displayed.
Press PAUSE/CANCEL 2 times to clear display
Probable cause/Proceedure
Drain hose plugged/kinked
unplug washer/disconnect power
check electrical connections to pump
and make sure pump runs
check drain pump filter for strings,sand etc
plug in washer If this dont work
replace pump.
Dec 31, 2009 | Kenmore HE2 Plus Front Load Washer
Problem with F21 code on whirlpool duet sport
i had the same problem. take the bottom cover off of the front of the washer. on the right you will see a round white screw off cover, it is very tight, it unscrews counter clock-wise. pull this out and see if there is any debris in it. if you look into the hole on the right side there is a hole about 1 inch round, this is the pump opening. you may have to take the gray drain hose off of the back of the pump housing and feel if anything is stuck in there, in my case there was a penny stuck side ways blocking the flow of water. after i took it out the washer has been running great again. this is obviously a design flaw, that something that large could manage to get that far, lucky for me it didn't damage the pump impeller. hope this helps. this should take care of the SD and the F21 error codes.
Aug 04, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washer is leaking from the bottom.
Hi, Was the noise a whining sound? It is possible something was in the pump amd it wore a hole in the pump. After the washer shuts off, tip the washer against the wall and look at the pump located behind the front panel in the center. It is attached to the motor. Check and see if it is dripping water.
Just an idia to start with.
Please let me know what you find and if I can assist you further.
Vic
Jun 28, 2009 | Kenmore 22422 Top Load Washer
Error code F 21? washer stops
Hi
The error code F21 means LONG DRAIN
NOTES: After 4 minutes the “Sd” error will be displayed, and then 4 minutes later the “F/21” error code will be displayed. Press PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De GO PATS
