Question about Toshiba Satellite A105-S4004 Notebook
Laptop hi,i was working away on my packard bell laptop when the screen suddenly went very dark,i have tried the brightness keys but it will not brighten up,i can still see the images on my screen but it is very hard,any suggestions please.thank you
I had the same problem! replaced both the inverter board and the lcd panel ! Unfortunaly the problems is still there..
has somebody any solutions ??
Posted on Feb 25, 2010
I have a toshiba satellite laptop. the mouse pad on it used to light up but stopped before i got it. is there a driver or something i can get to remedy this problems? the mouse pad still works it just doesn't light up. My sister says it happened when she loaded a program and deleted a couple of things.
Posted on Jan 20, 2008
    Brigadier General:
  • 6,966 Answers
Hi, I would assume that you have tried the Fn +F keys to increase brightness, if yes then it is very likely that you have a problem with the backlight (or CCF) which provides the background illumination. This can be caused by either defective tube or inverter circuitry powering the same tube. If you can still see the images but very very faintly, it is still reasonably repairable. This would call for the opening of the display panel of your laptop and determining which of the two are defective and replacing them. Either is available by mailorder and normally should be relatively easy to replace since most design do not require any soldering but are connected by plug-in connectors. However, if you are not comfortable opening the display panel and or tinkering with electronic devices, you might be better off seeking the services of a qualified professional. Hope this be of some help to you and give you ideas. Pls post again how things turn up. Good luck and kind regards. PS This site have ads of firms dealing with laptop parts.
Posted on Aug 02, 2007
How to adjust contrast
Are you asking because the screen has gone dark?Darkness is a backlight issue,can be the screen backlight,inverter or the cable itself causing it.Screen too bright can be adjusted via personalization or often keyboard shortcuts that have what looks like a sun symbol on them,the left key darkens when pressed and the right brightens
Aug 06, 2014 | HEWLETT-PACKARD HP EliteBook Notebook
Dark screen when switched on
Try to adjust the screen brightness using your keyboard. If the brightness is at maximum, then you need to replace your screen because its backlight is dying.
Feb 14, 2014 | Packard Bell Computers & Internet
Computer screen to dark how do i get to brighten up
Hi
Inorder to brighten up the screen ,try to find the key present on keyboard like "Fn" and also one more which resembles like sun.
This Sun like key will be present in the Function key(F1, F2 Etc)
Press both of the button at same time and adjust the brightness as per you requirement.
And also you can change the same in the power options in the properties where we can change the screensaver
Aug 09, 2012 | Dell Latitude 110L Notebook
How do I turn up the brightness on a HP Probook 6550b?
PLEASE RATE ME!
go to the search icon under start. search brightness. it will tell you step by step what to do.
Every laptop is different, so adjusting the brightness or contrast on your laptop may vary from the steps provided on this page. However, understanding the process of how to adjust the brightness or contrast will help you change your settings.
Most laptops adjust their brightness and other settings using the function key in conjunction with another key. For example, pressing and holding the function key (abbreviated as "Fn") and pressing the up or down arrow keys as shown in the picture below, increases and decreases the brightness.
May 09, 2011 | HEWLETT-PACKARD HP ProBook 6550b Notebook
The screen on my laptop is very dark can u tell me what settinggs to brighten it up please ???
you have come to the right place. you will get anwsers to all your problems at fixya. if you want to brightening the screen of the laptop, the combination of the keys below will help you out.
Fn + F7 - Increase Brightness
Fn + F8 - Decrease Brightness
Feb 16, 2011 | Advent Netbook
How to change the brightness on packard bell notebook. please help me.
On most Packard Bell laptops the brightness adjust keys combinations are hold down Fn and press F8 to turn it up and F9 to turn it down.
If this is not the case on yours then look for 2 F keys with small blue circles with blue dots around them, they are the brightness controls.
Alternatively you can go to the control panel look for display options and adjust the brightness from there.
Regards.
Jul 10, 2010 | Computers & Internet
Screen darker than normal which buttons do I hit to brighten
Go to settings, go to display, and move the bar up or look for icons at the top of your keyboard that looks like the sun and press them.  If your screen is still dark, then you need a new bulb.
Nov 12, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
I can't adjust the monitor brightness
luk on the keyboard of ur laptop, u will be able to c a SUN shaped symbol on two keys, use them to increase or decrease brightness of ur screen
they are usually on either F3 and F4
or F6 and F7
this shld work
Nov 03, 2009 | Computers & Internet
Screen has darkened but computer runs as normal
Im sorry to tell you that the inverter its broken, you need to buy a new one and change it. Is not the display its the inverter, and also in some rare case you will need a new flex, try in ebay and buy it the piece that exactly much your notebook and take it to an expert to change it. I hope it serves
pd sorry my english,.
Apr 04, 2009 | Packard Bell Computers & Internet
Laptop's dark screen is pissing me off
Hi, i have an Acer 5100 and the screen is really dark... can only just make out the screen. I have tried the fn key trick with no luck. I have replaced the inverter and also the screen.... again no joy. Can someone help me please :)
Jul 28, 2008 | Acer Aspire 5100 Notebook
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
219 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
