Question about Kenmore Washing Machines
Can heat motor , washer will not spin or agitate
Can hear motor running will not agitate or spin
  • 22 Answers
If this washer is belt driven, the belt could have slipped off or broke. To check this you can tilt the washer forward and look under it. If you can't see it there it maybe covered and you will have to take the front off. If this is the case it will cost a lot less to fix it yourself. And it is pretty easy.
Posted on Mar 08, 2009
My washing machine beeps if I switch it on.it doesnt wash or spin. I think there is water inside any hidden tank because I can hear water moving when I move the machine.
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Mar 26, 2015 | Washing Machines
My washer will not spin or drain, i hear it sensing but it does not go any further
Jul 05, 2014 | Whirlpool Washing Machines
AGITATOR WILL NOT SPIN, WATER WILL DRAIN BUT NO SPIN
Does your motor sound like it is running in the agitate or spin cycle or is it quite? If the motor makes no sound, then you need to replace the lid switch with this part.
If you hear the motor running in the agitate or spin cycle but you don't see any action, then replace the motor coupler with this part.
Dec 25, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
The washer will not agitate or spin out. the washer will fill and empty the water.
The most likely cause is the motor coupling, one on the motor and one on the transmission. UNPLUG POWER FROM WASHER. If it is broken your washer will fill and you will hear the motor running but nothing will happen, no agitation or spin. You will need to loosen the console, remove the cabinet drain pump and motor, then the motor coupling can be replaced on the motor and transmission. Part comes as a kit. Part number 285753a. Please rate this post.
Dec 14, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
The washer is not spinning and clothes are extermely wet top load 3.5
Hi, Well try to set the washer on the regular cycle, large load and let it fill. After the washer fills to the selected level, the motor should start and the agitator should start agitating.
If you hear the motor running, but the agitator doesn't move at all, do the following:-
Stop the washer and set the timer on the spin cycle and let it run.
If the washer motor runs and the washer empties the water from the tank, but it won't spin, that is an indication that the motor coupler is not turning the transmission at all.
The motor coupler is made of two pieces of plastic called fingers and a hard rubber piece that goes in between the two fingers. One of the fingers is attached to the motor and the other finger is attached to the transmission. The had rubber round piece goes between the two fingers. When one of the plastic fingers breaks, the motor is no longer coupled to the transmission and the washer will not agitate or spin dry the clothes. The reason that the motor coupler breaks before it should, it is that the user overloads the washer. People stuff the washer with too much clothes, big comforters, small placer rugs, snickers, etc.
Another reason is that the washer is used every day; normally the washer is used 3 times a week. So if you have a washer that is 5 years old and you use it every day, it has the wear and tear of a washer that is 10 years old.
Replacing the motor coupler is not hard to do, once you see how the repair is done. You will save at least $100 by replacing the motor coupler yourself.
Thanks!
mannu_rakesh
Aug 21, 2009 | Washing Machines
Will not spin
The problem is a broken motor coupler.
Set the washer on the regular cycle, large load and let it fill. After the washer fills to the selected level, the motor should start and the agitator should start agitating.
If you hear the motor running, but the agitator doesn't move at all, do the following. Stop the washer and set the timer on the spin cycle and let it run.
The motor coupler is made of two pieces of plastic called fingers and a hard rubber piece that goes in between the two fingers. One of the fingers is attached to the motor and the other finger is attached to the transmission. They had rubber round piece goes between the two fingers. When one of the plastic fingers breaks, the motor is no longer coupled to the transmission and the washer will not agitate or spin dry the clothes. The reason that the motor coupler breaks before it should, it is that the user overloads the washer. People stuff the washer with too much clothes, big comforters, small placer rugs, snickers, etc.
Thank You for contacting Fixya.com
Aug 01, 2009 | Whirlpool Washing Machines
Washer no longer spins.
with the washer set for spin and turned on...raise and lower the lid.
If it spins replace the timer.
If it does not spin...replace the direct drive coupling on the motor.
Mar 11, 2009 | Whirlpool LSQ9600L Top Load Washer
Kemore 90 Serieswashing machine fills and spins but won't agitate
Remove the agitator and see if the agitator shaft moves during agitate. If it moves then the agitator spline is worn or the agitator dogs are worn and the top half of the agitator will not work. If no results then the gearcase would have to be replaced
Dec 30, 2008 | Kenmore 24032\24036 Top Load Washer
Roper(whirlpool) washer will not spin model # ras7133kq1
check the motor coupler between the motor and the transmission
Mar 17, 2008 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
63 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
