Question about Frigidaire FEC32C4 Electric Cooktop
Is the FEC32C4 32 in. electric cook top 110 volt or 220 volt?
  • 8,197 Answers
220
Posted on Mar 08, 2009
Model # 79094320300 the clock and oven does not work on my Kenmove flattop stove, what can I do about it?
The clock runs on 110 volts and the oven at 220 volts. If the cook top is on, the issue is in the stove. Best left to a qualified technician.
If the cooktop is also not functioning, check the breaker.
Jun 19, 2014 | Kenmore 30 in. 42701 / 42702 / 42709...
I have a 4 burner Jenn-Air JED8430ADB electric radiant heat stove that has recently stopped working. It has been installed for many years (came with the house) and worked fine until now. When I turn one...
The cook top is connected to 220 volts. In the house wiring there are two legs each 115 volts. Usually they connect with a red wire, black wire and the third a neutral. It is likely that at the connection to the unit or at the electrical box a connection has failed or the 220 volt circuit breaker has failed on one leg. A qualified electrician needs to do the repair!
project1-nbbnxwvnfadegsi2zsme4jri-2-2.jpg Hope this helps?
May 04, 2017 | Jenn-Air JED8430 Electric Cooktop
My daughter wants to replace an old electric cooktop with a slide in range, taking out the cabinets underneath. Is that hard? She also wants to take out an old electric wall oven and put shelves in that...
Hello. The good news is that the power is already there for the old cook top. What she will find however is that the old cook top may be hardwired where as the new slide in range will require a receptacle mounted to the wall. This is 220 volt electricity so my recommendation is to have an electrician do this part of the job. That said, if you get back to me I will talk you through any and all parts of this job safely. Typically, depending upon your locale, the cost of having an electrician do this work is in the 100-250 range depending on how many trips are required to get it all done. Regarding the wall oven, once again, you are dealing with 220 volts. Be sure to turn off the circuit breaker, or remove the correct fuse, before doing any work.
Dec 01, 2009 | Jenn-Air JED8230 Electric Cooktop
Amps
60 amps and 220 volts
Jun 17, 2009 | Miele 30 in. KM443 Electric Cooktop
I took out an old cooktop which only has the black, white and ground wires. The jennair cooktop with 5 electric elements has black, red, white and ground. how do i connect these together.
sounds like the old one is 110 volts , and the new one is 220 volts. incompatable, as the 220 ones would work, but at half power if you didnt use the red wire. might work fine. omit the red wire and wee what happens
Jun 14, 2009 | Jenn-Air JEC9530 Electric Cooktop
My jenn air cooktop only gets warm and only has 110 volts?
how old is the cooktop? may have a broken or disconnected wire in it.
Oct 26, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn air jed 8430 electric cooktop control switch for rear burner
The cook top is attached to the wood frame by brackets, just remove the screws and the electric connection, make sure the power is off from the main box, it's a 220 volt wiring and then just lift the top off. to remove the glass, look around the edges and you should see some small screws, just remove them and the glass should lift off.
Eddie Rentas
Tupper Lake NY
Jul 07, 2008 | Jenn-Air JED8430 Electric Cooktop
COOK TOP WIRING
 You have Red and Black HOT wires and a Green Neutral - That is 220 volts. From the wall - Black is Normally HOT and White is Neutral. That is 110 volts. If that is a typical household outlet, is will only supply a demand at about 15 amps while running at 110 volts. Your Cooktop will most likely demand somewhere around 50 amps at 220 volts. - Short Answer - You will need to have a 220 volt supply line ran to the cooktop from the breaker. Easy to do but dangerous if you are unfamiliar with high voltage.
Apr 30, 2008 | Jenn-Air JED8430 Electric Cooktop
Electrical hookup
no its 220 red to one 110 line blk to the other 110 line white to neutral should be a solid metel wire to take that to ground
Jan 26, 2008 | Jenn-Air JED8430 Electric Cooktop
Frigidaire FEC32C4 Electric Cooktop Logo
312 people viewed this question
Top Frigidaire Cooktops Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
