Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Self cleaning oven won't lock
I have a Frigidaire Gallery Professional Series slide in ceramic top oven/range. When attempting to to self clean, the display shows door, beeps three times, then sits there with out locking. After a few seconds it will beep again, but the door will not lock and no error is displayed.
    Guru:
  • 462 Answers
Generally
There is a motor that lets the latch slide out and catch the door either this latch motor isn't getting power from the board or the motor is bad. You will have to need a volt meter and a wire diagram, and take the covers off to see the motor and board.
Always remove power until you get the item open and can see whats going on before reapplying power.
If you don't feel confident I recommend calling in a repair man.
Posted on Mar 13, 2009
  • Farley Redfield
    Farley Redfield Mar 13, 2009
    If this helped you would you please rate me accordingly and good luck.
Getting f10 on oven
Hi Dave, thank you for allowing me to assist you!
Typically error code F10 indicates that your Frigidaire range has detected an issue with the runaway temperature (overheating). Let's attempt reprogramming your range by either unplugging it or flipping the household circuit breaker off. It is best to wait roughly ten minutes and then turn on your range. Usually this will clear most false error codes. If issue persists, at this moment I would suggest contacting a professional to proceed further. Most likely the RTD Probe (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps! - Z
Aug 22, 2014 | Frigidaire 30 in. Electric Gallery Series...
Es510
Hello KC - You may try and reset the cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the lock symbol does not clear, then the unit more than likely may be experiencing an issue with the EOC (Electronic Oven Control), user interface board or a potential wiring failure. This is not a typicaly do it yourself job; please consult a professional or your manufacturer.
Apr 28, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
My frigidaire self cleaning oven says F90?
Lift top - there is a quater inch button on the black box behind the door lock - use screwdriver to press the button in - resets
Sep 17, 2012 | Frigidaire 27 in. Electric Gallery Pro...
I have a frigidaire gallery wall oven (2003). We set the self cleaning and then canceled. The door is now locked and the fan is running. I tried to reset breaker and it is still locked. How can I get the...
If tripping and turning the circuit breaker off for about 10 minutes does not work, contact Frigidaire. Sounds like the control board and/or door switch will need replacing.
Aug 07, 2012 | Frigidaire 30 in. Electric Gallery Series...
Self cleaning lock is in lock position and oven door is open.
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
The self-cleaning cycle on our oven stops mid-cycle
I would never use the self clean in the first place...it causes many problems. I see many problems on Fixya everyday because of this feature...
Check out this tip...
heatman101
Mar 27, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
The self cleaning instructions for my Frigidaire Gallery Pro Series Model FEB798WCCH do not inform how long to set timer. Any instructions would be helpful as I've never operated a self cleaning oven...
Hello- The function is automatic when clean button is pushed. Oven will lock, and turn on at full power for about 90 mins. This 'feature' can, and usually does eventually burn out circuits in the control board. Techs call this the 'self-destruct' option, cheerfully promoted by the salesman. Avoid using 'self clean'!  Scrape and clean with light soap/water. Turn on to 450deg. for about 30 min. This is about half the temp. of a 900deg. 'clean' cycle and a lot less expensive in the long run. Please acknowledge this post if info is helpful- have more if needed.- Thanks- Ed
Mar 19, 2010 | Frigidaire 30 in. Electric Gallery Series...
Cannot unlock oven frigidaire electrolux gallery series
Hello, what to do is to start another self clean cycle let the unit clean for about 3 minutes then push the cancel button.This should unlock the door if not a tech will have to come to advance the lock motor . good luck
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
314 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
