Question about Sony XPLOD CDX-GT200 CD Player
I want to know what the color of the wires mean on this sony xplodcar stereo model no.CDX-GT200 i am hooking it up to 2001 kia sportage jimmer
  • 8,197 Answers
Sony XPLOD CDX-GT200 CD Player keeps going back to demo mode
This is happeneing because the stereo does not have a battery power connections. The yellow wire is for a constant 12 volt connection. This connection is for the stereo's memory.
Aug 28, 2012 | Sony XPLOD CDX-GT200 CD Player
I dnt know how to hook my sony explode cdx gt 200 to my honda civic hatchback 94
The Honda Civic requires a dash adaptor you need this wiring harness to install the stereo it dont seem a dash adaptor is required for the 94 model you use the cage/sleeve to install the sony in your car you will also need this removal tool and either wire nuts, heat shrink tubing, crimp caps and crimp tool or the common solder and wrap in electrical tape method to connect the wiring harness for the honda to the wiring harness for the stereo
Oct 14, 2010 | Sony XPLOD CDX-GT200 CD Player
Sony CDX GT200 does not work... is there a fuse in this radio? I cannot turn on the unit now. I just got my car back from the repair shop and they replaced my battery and alternator, but now my radio...
There is a fuse in the back of the stereo unit. Also trace the red wire from the stereo to where it's connected, and check the fuse for the circuit that the stereo is connected to.
May 22, 2010 | Sony XPLOD CDX-GT200 CD Player
SONY CDX 5090 - E 04 error message.
I have a Sony cdx 5090 car stereo, I don't have the manual for it. I need to know the wiring color codes for it to hook it up.
Aug 22, 2009 | Sony CDX-5090 CD Changer
Sony CDX-GT200 wiring query
The ariel switch is for a power antenna to make it rise when you turn your stereo on. The orange wire is for your dimmer when you turn on your car lights. You do not need to hook either of these up.
Aug 09, 2009 | Car Audio & Video
I need a color code for a Sony Xplod CDX-GT23W.
Guessing that you don't still have the owners/install manual.
On the back of the head unit there should be a group of unused/unconnected wires (with any luck they will be marked), one or more might be an amp turn-on or power antenna lead, so I suggest (with the unit turned on) testing each wire with a DC voltage tester so as to identify and separate any leads supplying 12+ volts. the remaining group will consist of speaker leads. Trial and error testing will determine the proper L & R rear speaker leads.
Good luck
Aduz
Mar 30, 2009 | Sony XPLOD CDX-GT200 CD Player
Wiring color meaning
did you buy a factory radio connector to connect the old harness to the new radio wiring if not you can get one at wall mart for 20 dollars and it will be color coded
Mar 08, 2009 | Sony XPLOD CDX-GT200 CD Player
SONY CDX-M8800 STEREO
Red (accessory wire)- goes to hot wire that can be turned off.
Yellow (constant wire) goes to your cigarette lighter
Blue/white is your amplifier remote turn-on wire.
Probably have green and green/white- brown and brown/white-white and white/black, and another color for speaker wires.
You can hook one pair up to your cd player and find out if it's hooked up to the right speaker channel.
Orange (remote antenna) wire.
Apr 20, 2008 | Sony CDX-M8800 CD Player
1989 crown victoria stereo wiring diagram
Speaker wires are usually a figure 8. Which means they are stuck together and are usually grey, and grey with a black trace on the sheeth.
Feb 13, 2008 | Sony XPLOD CDX-GT200 CD Player
Sony XPLOD CDX-GT200 CD Player Logo
374 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
