Question about Uniden DCT7585-3 Phone
I have a Uniden telephone Model DCT7585 and on the base unit the number pads 1,4,7 and the menu, set and memo pads do not work. How can I get them to work?
  • Linda Fidell Mar 30, 2009
    My 4 and 7 recently stopped working. I'll take it apart as suggested. Thanks for posting.
  • 463 Answers
Take unit apart and reseat ribbon connector going from keypad unit to control board(s). Also, whilst in there, check to make sure someone hasn't spilled sticky gumbo on the keypad, and it has foiled the little pressure pads under there.
Posted on Mar 08, 2009
How do you set up voicemail; on a uniden dect 6.0?
Which exact model Uniden DECT phone do you have? There are a number of models. Some require you to set up the answering machine from a handset. Other models have a Menu button on the base station, as well. The entire list of DECT phone manuals are here: http://www.uniden.com/scat/dectphones_mnl . They are listed in alphabetical and numerical order. Ignore any digits after the dash in the model number, that indicates the number of handsets in the original package. My experience with Uniden DECT phones includes systems where the menu is accessed from the base like the D3588, http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D3588om.pdf .
The following directions work for the Uniden systems that I have used to set up the . First make sure that the answering system is on at the base station and the phone is in standby. Next press the Menu/Select button and use the Up/Down arrows to navigate to Answering Setup. Press Menu/Select to enter the submenu. Then navigate to the different options in this menu and press Menu/Select to enter them.
To record a greeting message, navigate to Record Greeting. Press Select and wait for the "Record Greeting" response. Speak your greeting clearly (between 2 and 30 seconds) and press Select to Stop the recording. You'll hear the greeting repeated. Press End (on the handset) or Stop/Cancel on the base to interrupt the playback.
Next press the Phone Book button to go back up to the Answer Setup menu. Select Greeting Options to switch greetings (if your model has a default greeting). Use Select to switch between greetings. (Arrow keys to swap; Select to confirm.) Use the Ring Time option to select how many rings before the unit picks up. If you wish to use the answering system when you are away, make sure to set up a Security code and press Select to confirm the code. Make a note of the code. Press End to exit the menu system.
Note: if you have Voicemail from your telephone provider, you will need to ensure that your Uniden phone picks up before the Voicemail service.
I hope this helps.
Aug 11, 2014 | Uniden DECT 6.0 Cordless Phone
Tip
Uniden DCT7585 Manual Download Models: DCT758 / DCT7585 / DCT7085 ...
Have you misplaced your Uniden DCT7585 Cordless Phone Owners Manual?
Would you like a digital, searchable, pdf version of the Uniden DCT7585 Base Station Users Guide?
Follow this link
to download a pdf version of the operations manual.
I hope that helps.
on Apr 23, 2010 | Lands Phones
Uniden phone stuck at searching, not getting a dial tone
One thing to try is deregestering your phone and registering it with the base again.
Hole the # and 'End' key on the handset until the next menu appears (about 5 seconds). Select deregister phone (use the 'Menu' button). Do it again, but select "base unavailable". After that, set them in the base (not the handset charger) and they should register with the base.
This works on most Uniden model phones.
Jan 29, 2013 | Uniden DECT 6.0 Cordless Telephone...
How to set time on phone
Which Uniden DECT 6.0 phone do you have? There are many.
Some Uniden phones will set the time automatically if you have Caller ID from your telephone provider.
To manually set the time on the Uniden D2280, press Menu on the handset when it is in standby. (It's the center of the wheel with the up/down arrows.) Go down to the Date and Time submenu and press Menu again. Enter the time and day using the keypad (press CID to advance past a character without changing it). Then select AM or PM. Press Menu to save. Press the phonebook key to go back to a previous menu or End to exit.
For the DECT1580, you set the date and time similarly. However, you start by pressing Menu on the base when the phone and handsets are not in use. (Have the handsets within range of the base.) Use the up/down arrows to select the day of the week. Then use the keypad to enter the current time.
The manuals for most Uniden DECT phones are here: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . They are listed in numerical and alphabetical order. Ignore the number after the dash in the model number, that merely indicates the number of handsets in the original package. One manual will cover units sold with different number of handsets.
I hope this helps.
Aug 25, 2011 | Uniden DECT 6.0 Cordless Phone ID
Unit...DCT7585-3..how do I get caller id numbers removed? Alos I need the book to explain all other functions how do I get another one?
You can download the manual from the manufacturer's web site at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DCT7585om.pdf
Jun 14, 2011 | Uniden DCT7585-3 Phone
I have (3) Uniden telephones in the house. We went on holidays for (2) weeks and switched off (2) of them. We switched them all on when we returned but now only one unit fully functions. The other two will...
Sounds like you need to re-register the 2 handsets that are not working properly. Sometimes the handsets must first be de-registered then re-registered to the base unit. Send a comment with the model number of the base unit and handsets if they are not original handsets and I will give specific information for your phone. I have included a link where you can download the manual for your Uniden cordless phone by model number.
http://www.uniden.com/index/manuals_results.cfm?cat=1
Mar 28, 2011 | Uniden Lands Phones
How do you retrieve messages on the Uniden DCT7585-3? Where can I find an online manual?
Press the play/stop button(to the right of on/off button) on the base unit. The unit will announce the number of new and old messages. The unit will give the message number, play the message, then give the time and date the message was recorded.
Press the select key(right button below the screen) on the handset. Press the 2 key on the dialpad to play messages. After playing message date and time is announced.
This link will take you to a site that has the manual to download. You will need to enter a valid email address to complete the download of your manual.
http://www.retrevo.com/d/ds/progress?doc=2e937b7fdaf136396efe79ae624a7b17&rk=0.5466390328323742
Dec 12, 2010 | Uniden DCT7585-3 Phone
Only two rings before answering machine I want
You can set the number of rings through the base unit's menu. See the manual for details. Lost it? Go to www.uniden.com and download one.
Aug 11, 2010 | Uniden DECT 6.0 Cordless Telephone...
Uniden 5.8ghz cordless W/2handsets has no dial tone cannot call out or recieve calls
There can be a lot of different things that could cause this. The first thing I would do is disconnect the telephone cord from the Uniden phon eand connect it to another telephone and see if you get a dial tone from it. If you do then we know that the telephon eline and the cord are OK so we go back to the Uniden telephone. Next, does the unit light up when you plug it in? are you sure that the telephone is getting AC Power? Are the displays on the handsets working? Does the handset display show "Handset XX" or does it show "Searching"? If it shows "Handset XX" then the base unit is getting power, if not the base unit may not be getting power.
If the base unit is getting power and the handsets are working and the power cord and jack were proven good by conecting another phone to them, then you would need to call uniden Customer Service for further trouble shooting or repair/replacement. the number is 1-800-297-1026
Jan 26, 2010 | Uniden Cordless Phone
Uniden DCT7585-3 Phone Logo
269 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
