Question about Dell Inspiron XPS M140 Notebook
"no boot sector on internal hard drive"
Hi, I have a Dell Vostro 1700. Unfortunately the HDD was damaged and I have replaced with a new HDD. The new HDD is being recognised by the laptop but it keeps displaying "no boot sector on internal hard drive".
Can you help.
Thanks,
Niall I tried to load XP on my new hard drive and it continues to give me the same error as mentioned above. I would like to load my OS but it won't let me. What now?
  • 4 more comments
  • sjc592003 Mar 09, 2009
    To clarify, no OS is installed yet. I am trying to do a brand new install of Windows XP on a brand new hard drive. One solution was to format the hard drive. How do I do that when it does not give me the chance to do anything? Just hoping to be able to load XP. Thanks.
    Thanks for your reply. I have tried that already and the result is still the same. The optical drive spins the disk for a little while then goes back to the same error. It's like it won't boot from the disk at all. I thought maybe the drive was toast so I swapped in a known working drive and the result was the same. I've installed XP to clean hard drives before and everything you've said has always worked. I have never had this problem. I am at a bit of a loss. Any other ideas? :)
    Thanks. I'll try the burning idea. I'm pretty sure the XP disk is bootable but not 100%. I kinda thought all XP disks were bootable. It is an authentic Microsoft product.
  • has the hard drive been formatted?
  • M N
    M N May 11, 2010
    Can you clarify "... I tried to load XP on my new hard..."
    You can't install windows XP to it?
    You can't load the installed XP from it?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Two things, is the new hard drive being recognized in the BIOS and also have you tried formatting the new hard drive?
  • 463 Answers
Fixboot c:\
fdisk /mbr
Posted on Mar 08, 2009
  • 1 more comment
  • Rob
    Rob Mar 09, 2009
    In the BIOS of your computer, set the Boot Order such that the machine tries to boot off your CD/DVD-ROM drive first.
    Insert XP install disk into CD/DVD-ROM drive.
    Reboot...
    When machine prompts for "Press Any Key To Boot From CD", press the space bar a couple of times such that the machine attempts to boot from CD.
    The XP install process will begin. At some point in the process, you will be asked where to install Windows? Choose "C:\WINDOWS". If it asks you how to format the Disc Drive, choose "NTFS - Quick". Follow the rest of the prompts and you're done.
  • Rob
    Rob Mar 09, 2009
    So you are saying in effect that the machine will NOT boot to the optical disk drive? correct? If that is the case, RE-Burn a copy of the CD you are trying to boot from, but burn it at 4X.
  • Rob
    Rob Mar 09, 2009
    And one other thing... This CD from which you are trying to insall WinXP.... is it, indeed, bootable?
2 Suggested Answers
  • 8 Answers
SOURCE: "no boot sector on internal hard drive"
i think you need to re-install your Operating System again since you got a new HDD wich is tottaly empty i assume so try to install your OS on the new HDD
let me know if it helped
greetings
Posted on Jan 02, 2009
Hdd not recognised when i boot up my laptop
If the hard drive doesn't detect in multiple systems that if generally accepted as an indication of drive failure (Especially if another drive is seen in both systems) Fortunately, replacement drives are pretty cheap
http://cgi.ebay.com/320GB-Dell-VOSTRO-1000-1310-1400-1500-1510-Hard-Drive_W0QQitemZ250576402713QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3a57847919#ht_5020wt_939
Feb 21, 2010 | Dell Vostro 1000
Dropped tea on my Vostro 1700, dried it with a hair drier, and left in the airing cupboard for 24 hours. When pressing the power button, it doesn't switch on, instead it goes into Dell Media direct mode,...
Don't see much hope there... the liquid probably left residue all over the electronics and may have shorted out some of the systems vitals.
You could try to disassemble the laptop and carefully clean it but... I'd take it to a service center and hope that my hdd was unharmed and my data is still intact.
Sorry and best of luck
Nov 13, 2009 | Dell Vostro 1700 Notebook
I could t download attachment even as small as 16kb.It takes ages and would not download at all.What can I do?It is frustrating ! I use a Dell Vostro 1700, with Intel Core duo 1.80Ghz running Windows Vista...
try to turn off security center and any other security software installed in your laptop. if fails. boot to safe mode with networking then try to download again the file. if fails check if other computer can download it successfully using the same connection, router and modem. just to isolate if a security in your router has been enabled.
Oct 10, 2009 | Dell Vostro 1700 Notebook
Bought used dell vostro 1700, wasnt told about the bios password.
Hi Jonnymac93,
the fastest way to clear a password would be to remove the cmos / bios battery. The manual for the Vostro 1700 can be found at the following link;
http://support.dell.com/support/edocs/systems/vos1700/en/OM/pdf/TT565A01MR.pdf
If you prefer the manual in htm, click this next link & choose htm format listed on the site;
http://support.dell.com/support/edocs/systems/vos1700/en/index.htm
Go to page 182 & 183 for instructions. The manual call this, Removing the Coin-Cell Battery.
Also here is notebooks driver site for the 1700;
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?~ck=ln&c=us&l=en&lnki=0&s=gen
Good luck Johnny!
Run into trouble, post back.
Mike
Mar 30, 2009 | Dell Vostro 1700 Notebook
Dell Vostro 1700 Microphone
got to start,my computer,device manager, hardware and make sure that your microphone is on. Probably on mute.
Jan 08, 2009 | Dell Vostro 1700 Notebook
I can't reinstall Windows Vista for Dell Vostro 1700
my e-mail address is ihab2009@live.se add me to your msn will take u throw et i have same problem
Jan 03, 2009 | Dell Vostro 1700 Notebook
greetings
Jan 02, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron XPS M140 Notebook Logo
2,505 people viewed this question
Alun Cox
