I CANNOT GET TUNER TO WORK ON THE DMR WHEN CONNECTED VIA HDMI TO A VIETA TH-42PX80A
  • 1 more comment
  • jaydebe47 Mar 08, 2009
    I was intending to bring in TV signal through DMR so that I could record TV programs, TV will play DVD's, but I cannot record from any TV programs.
    I am trying to be able to use DMR-EX75 to record TV programs, as per Manual I am unable to set up DVD Auto-Setup to program channel numbers, or to set time.
    The TV is a Plasma TH-42Px80A and is connected via HDMI cable, my aerial is connected in through back of DMR.
    I can play dvd's from DMR.
    Connecting via another port has not changed situation.
    When using control, and pushing DVD button, all that appears is three 000 flashing.
    I have changed from HDMi 2 to HDMI1 - no difference.
    Top Expert:
  • Televison & ... Master
  • 77,169 Answers
Do u have the proper menu slection made for HDMI connections, u have to choose this in the set up menu under audio/video
Posted on Mar 08, 2009
  • 19,396 Answers
Try a different hdmi por. Always power off devices when unplugging HDMI cable.
  • 10,594 Answers
What do you mean by Tuner? Tuner does not need ant TV to listen stations.
If you are talking about Home Theater System then please make sure that TV have recognize it via HDMI
When TV will recognize home theater then communication link will be established in both units and you will get picture of DVD.
Need further info, please post back in comments.
  • Shahid Electronics
    Shahid Electronics Mar 08, 2009
    OK,
    Normally TV does not have output on HDMI port.You need to hook DMR through Video-Audio RCA cable at TV OUT terminals in TV.
    Alright, Please go to DMR menu settings and start channel scan.
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
Dec 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Hi, I am in Melbourne Australia. Can I receive gem hd channel thru my dmr-ez48v. I haven't tried but I do have a hd monitor screen that I can plug the unit into. Also what does the hdmi on the unit do....
HDMI means high definition multimedia interface.
When connected to an HDMI compatible unit, an uncompressed digital audio and video signal is transmitted, enabling you to enjoy high quality digital video and audio with just one cable. When connecting to an HDMIcompatible HDTV, the output can be switched to 1080p, 1080i or 720p HD video.
Panasonic uses Viera link option between their video products.
When connecting with a Panasonic TV (VIERA) or a receiver equipped with 'HDAVI Control' function, linked operations are possible. [Linked Operations with the TV (VIERA LinkTM HDAVI ControlTM)]
Please use HIGH SPEED HDMI cables that have the HDMI logo (as shown on the cover).
It is recommended that you use Panasonic's HDMI cable.
Recommended part number: RP-CDHG10 (1.0 m/3.3 ft.), RP-CDHG15 (1.5 m/4.9 ft.), RP-CDHG20
(2.0 m/6.6 ft.), RP-CDHG30 (3.0 m/9.8 ft.), RP-CDHG50 (5.0 m/16.4 ft.), etc.
Non-HDMI-compliant cables cannot be used.
(the above is from the owner's manual of this model - page 40 tells you about linked operation using HDMI HDAVI control and how to set it up)
As for Gem HD, this unit has an SD (standard definition) digital tuner - it will not decode/receive HD channels. I should point out that 7mate also is a HD channel but is not specified as such in any menu or even their website. (I found this out by accident when I tried to record on timer 7mate one day and all I got was 'unable to decode HD channel' banner at the bottom of a blank screen)
Channel 11 is a SD channel - so this will work with your DMR-EZ48 as will all the other relevant main free to air channels (ABC/7/9/10/SBS). GO! is also a SD channel.
To be able to record HD to this combo unit you will need a HD set top box connected via its AV inputs. HDMI simply means you will get HD video quality from the combo to the TV, you will not receive HD channels from your HDTV to your DMR-EZ48 unit via this method.
Mar 26, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-BS750EB recording Help needed
I also have the DMR-BS750EB its connected to a panasonic plasma via an hdmi cable and also scart lead so that i can use the tv freeview tuner to record as well and it works just fine if you still have the user manual check the advanced record features for external link or down load the user guide from panasonic. I have had mine since november and had no real issues ... except the ones ive caused from mis interpreting the instructions cheers Alex.
Feb 17, 2010 | Panasonic Televison & Video
Panasonic DMR-EX75 has stopped receiving digital signal
Panasonic DMR-EX75 has stoped receiving digital signa
Aug 01, 2009 | Panasonic Televison & Video
Panasonic plasma vieta
I just bought a Panasonic TH-42PZ800U and had the same problem. 10 blinks and the TV would not start. Then after some trial and error I solved the problem!
Here is my (apparent) observation and solution:
I had only one input into the TV, which was my HTPC connected via a DVI-to-HDMI cable plugged into the Panny's HDMI 1 slot. *IF* the HTPC was already on, then the Panny would have the blink of death. *BUT* if the HTPC was off, the Panny booted fine (assuming I cleared the blink of death first by powering off the HTPC, unplugging the TV, and replugging the TV back in with the HTPC still off).
My solution was to move the HDMI cable from slot 1 to slot 3. After making this one change, everything worked as it should. No more 10 blinks of death. I could even leave the HTPC on and turn on the TV last, and it still worked. Tried this 10 times, worked 10 times.
I don't know if this will solve other people's problems, but I hope it at least provides some clues. I wonder if this is a fundamental circuit design flaw on the part of Panasonic, rather than a "bad batch of parts" problem.
Thoughts? Feedback? Send to gcpien at hotmail dotcom
Jun 07, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Hdmi connection
you need to connect to your tv via scart untill you have been into the setup and enabled hdmi
Dec 29, 2007 | Panasonic DMR-E80H DVD Recorder
HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
this is a good one i had the same problem about a year a go on my brothers we tried every thing nout worked i said put the video leads in and do it it worked a treat but i have herd it don't work for all so it sounds like an amplifier my be needed hope any of this can help you. sorry if it don't only trying to help
Oct 11, 2007 | Akai LCT2785TA 27 in. LCD Television
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
