Question about JVC Televison & Video
TV: bright line across black screen for several hours.
Bright horizontal line across middle of black screen.
After a while, a jumpy picture.
Then, after several hours, picture is fine.
Have had this problem for about a year, each time tv is turned on.
JVC 20" color TV bought in 1995
  • 75 Answers
Vertical problem need to check for bad solder joints on vertical ic would be helpfull if we had the model number o f yur set. also could be bad capasistors in vertical section.
Posted on Mar 09, 2009
  • 39 Answers
Vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Re: bevbreaux posted Mar 8 '09--thank you, for solutions from
dogey & mchelec--not yet tried. Dogey said it would be helpful to have model number, which is: JVC AV 20-CM 5.
Problem is bright horizontal line across black screen.
Posted on Mar 29, 2009
SOURCE:
Toshiba 36HF12 TV has a horizontal bright line across no picture
Failure of vertical scan output circuit. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Nov 11, 2015 | Toshiba Televison & Video
JVC AV-27730: horizontal bright line across screen in the
it could be an electrolytic capacitor or the vertical output I.C. in the vertical circuitry,if you remove the rear cover tap on the board in different places and see if the picture fills out or atleast jitters like it might fill out,then it could be just a cold solder joint,then remove the main board and resolder all joints and this should repair the condition you have
Nov 18, 2009 | JVC AV-27730 27" TV
Rca 32 inch tv
this is a frame fault
the fact that you can still see the line when the tv is off is because you have been watching with the line and it has burnt into the crt.
time to buy a new tv
Sep 04, 2009 | Sanyo DS24205 24" TV
Bright horizontal line across black tv screen
Hi There,
If your picture has collapsed to just a horizontal line across the center of the screen, this indicates that your Vertical Output circuit is bad and needs to be serviced by a qualified technician. I hope this helps and thank you for using FixYa!
Mar 29, 2009 | JVC Televison & Video
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
It sounds to me like you're describing the re-trace of the unit. It is repairable, and more so the sooner you get it to the repair facility.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-27FS120 27" TV
A bright line on the screen
A line running across the screen like that and then returning to a picture I would guess is the vertical IC has some poor solder joints. The vertical IC in that unit IC401 is an LA78041 a seven pin IC that is mounted to a metal heat sink. On the foil or under side of the board take a careful look at the pins of that IC and any that look suspicious carefully re-flow some solder over.. Careful not to keep your iron on the pin too long.. And if have to re-solder several take some time between them to allow the IC to cool so you don't damage it.. Good Luck Bill
Jun 10, 2007 | Toshiba 27AF41 27" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Televison & Video Logo
918 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
