Question about Dishwashers
Quiet partner 1 will not drain or run
I have a Whrlpl Quiet Partner 1, it will not drain or run. However, when it is closed, and I turn the knob. I can hear it click as I turn the knob. I found to little black plastic items in the bottom of the dishwasher. They kind of look like the iron things boot makers use to put boots or shoes on when doing repairs.
  • 22 Answers
It sounds like it ain't getting any power since all your hearing is the clicking from the timer. If it does have power I would take the front panel off and see if everything looks ok and make sure there ain't any loose wires. But start with checking the wires coming in for power. Hope this helps.
Posted on Mar 08, 2009
Whirlpool Quiet partner V Dishwasher will not start no lights ,,,nothing
Try unlatched door and hit heated dry, normal, heated dry, normal all within 3 seconds of each ither. Close dior, latch and try again.
Mar 02, 2015 | Whirlpool Gold Series Quiet Partner Iv...
Whirlpool quiet partner II stops running or won't complete it's was cycle, sometimes is will wash for a few minutes and stop or it will stop before the water even starts to flow.
I had the same problem with my dishwasher. After hearing that the motherboard was the problem I decided to take a closer look. There were two capacitors (1000 microfarads, 6.3 volts) that looked a little suspect. The tops of capacitors should be flat...these looked like soda cans that had been left in the freezer. Got on eBay, located the capacitors for roughly $3 and $4 shipping, for approx total of $10. Soldered the two new capacitors into the motherboard and put it back together. As soon as I closed the door, the dishwasher started draining the water. When I ran a Normal cycle it completed successfully. Saved myself over $120!
Aug 02, 2013 | Whirlpool Gold Dishwasher with Quiet...
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner III Will not drain at the
It sounds like the control unit has gone bad and you will have to replace it...the replacement is not very hard, just make sure to mark the wires so you get them back were they belong on the new unit.
How to Buy Appliance Parts Online
heatman101
Sep 18, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Quiet partner III taking over 4 hrs to complete normal wash cycle
ok check how fast the water is draining,,might be a bit slow...onthejob
Jan 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
134 people viewed this question
Top Dishwashers Experts
