Can't view connected Dell Inspiron 9400 computer on Toshiba 37 AV52U TV
  • tobneden Mar 08, 2009
    Still nothing and the TV reads unsupported video signal.
    Both the Dell computer and the Toshiba TV have 15 pin, VGA cable ends (both male). My menu with PC setting is still gray indicating not a proper connection. Some folks talked about hitting Fn and another to fix it?
  • 19,396 Answers
You need to change your computer display settings following your TV user manual.
Here follow the compatible display settings as on page 57-chapter 9 on manual.
Put resolution 640x480 and frequency 59,940Htz.
Here the user manual where you can find the same information on chapter 9.
See How to change display settings: screen resolution, screen
refresh
Do not forget to evaluate the solution.
Many thanks.
Posted on Mar 09, 2009
  • 13,433 Answers
The resolution on the 2nd monitor is too high for the television please lower it.
Posted on Mar 08, 2009
  • Ekse Mar 08, 2009
    The refresh rate may also be too high, I will have to check the spesifications of your tv.
  • Ekse Mar 08, 2009
    The max resolution seems to be 1280x720. you may have a resolution that has higher height, for example 768. You need to use a resolution that is either under 720 or exactly 720. you can create custom resolutions on computer video card settings.
    I need to know how you are hooking this up to the tv.
    here is a guide for Nvidia on how to create a custom resolution, note that it will most likely look diffrent on your computer. To get to nvidia control panel, right click on your desktop and select nvidia control panel or properties, and from properties go to settings and from settings advanced. and from there nvidia.
    here is the guide
    http://www.nvidia.com/object/custom_reso...
    it will look diffrent as nvidia has updated their control panel. but it will be basicly the same process.
  • 10,594 Answers
Please enable second monitor in your laptop to have computer screen in Toshiba LCD.
Go too deck top, right click on deck top, properties, settings, monitor, enable 2nd monitor.
Thanks.
  • Shahid Electronics
    Shahid Electronics Mar 08, 2009
    humm, maybe you are hooking TV with wrong cable.
    Please check TV Menu options to select auto or multiple computer signal.
    Please check Ekse suggestions about lowering display resolution of laptop so TV will get proper and supported signal.
    Brigadier General:
  • 8,619 Answers
Hi
Please right click on your desktop then go to graphic properties and from there set the screen resolution to 1280 x 768 and then press CTRL+ALT+F1 Key.
Thanks
Rylee
Charging light is flashing
There are two possible causes for this issue:
1) Your dell 9400 charger is malfunction
2) Your laptop dc power jack is loose or dead
Possible troubleshooting step:
1) Borrow a compatible dell charger to plug in your laptop, if it works without any issue, it means your dell inspiron 9400 adapter need to be replaced.
2) If the compatible dell 9400 charger won't work normally, the problem may lie in your dc power jack.
Hope this will help.
Jan 07, 2013 | Dell Inspiron 9400 Notebook
Usb2.0 laptop tv tuner driver
http://www.inetbridge.net/forum/download/file.php?id=2295&sid=432f7c52d98676c2400b20b83f88c355
Dell Emuzed Angel USB TV Tuner Driver v.1.0.2.32 A00 Windows XP.
Supported Models: Inspiron 6000, Inspiron 9400/E1705, XPS/Inspiron XPS Gen 2, Inspiron 9300, XPS/Inspiron M170, XPS M1710.
Driver : Dell Emuzed Angel USB TV Tuner Driver v.1.0.2.32
Mar 01, 2011 | Computers & Internet
Diagram how to connect dell inspiron laptop 9400 and record tv programs
If you have the right Hardware (Digital TV tuner card) it will have come with the software needed.
If you dont yet have tv tuner card, thats what you need
Jul 18, 2010 | Dell Inspiron E1705, Intel Core 2 Duo...
My Dell inspiron 9400 wont charged my battery. Both the charger and battery are new
try to charge the battery while the computer is off for 3 hours. if that does not work, remove the battery from the computer and turn on the computer using only the ac adapter. if the computer is working fine using only the ac adapter, call your computer manufacturer for possible battery replacement
Jun 11, 2010 | Dell Inspiron 9400 Notebook
Bios Password dell inspiron 9400
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-9400-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
May 14, 2010 | Dell Inspiron 9400 Notebook
Dell inspiron 9400- constant clicking noise like a mouse click locks computer
Probably a loose connection. Disassemble, check components, the reassemble.
Mar 12, 2010 | Dell Inspiron 9400 Notebook
Can't activate wifi key on inspiron 9400. fn f2
Try to uninstall then re-install the Dell Quickset from the Drivers and utilities disc.
Oct 29, 2009 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 display
you may have damaged the screen in which case theres not much more you can do then replace it.if its a new labtop it may be still under warrenty in which case get back to dell.
Mar 22, 2009 | Dell Inspiron 9400 Notebook
How do I add a dell external monitor to a dell inspiron 9400
Simply use the external video port. It may require an adapter depending on the monitor you plan to use.
Nov 18, 2008 | Dell Inspiron 9400 Notebook
Screen flicker when typing
What you have to do is reduce your hardware acceleration according to dell. go to Start> control panel> displays(in classic view)> settings> advanced> trouble shooting then just lower the slider a notch or two.
Jun 27, 2007 | Dell Inspiron 9400 Notebook
Computers & Internet Logo
192 people viewed this question
David Payne
David Payne
