Question about Dell Computers & Internet
"Router settings are OK What do I do on the computer to set up wireless" network at home,I've gone into control panel and connections and it has 'Broadband' saying not connected and below 'Lan or high speed internet'connected Currenly using Ethernet cable.I used to have an aerial icon in the task bar showing If I was connected and the strength of signal.System did crash so could hard drive have lost drivers ? this is where I get totaly lost Many Thanks in Advance !
  • 2 more comments
  • jaegerdwp
    jaegerdwp Mar 08, 2009
    Hi, its a Dell Dimension 3100 Desk top.The router is a Billion 7202G & has worked fine wirelessly 3 months ago before the crash(I had to reinstall the OS & Drivers)
  • jaegerdwp
    jaegerdwp Mar 10, 2009
    Hi just wondering why Signal strength Icon is not showing in task bar,I've disabled firewall for LAN but still says Firewalled faintly next to LAN setting picture,just want to make sure before I disconnect Ethernet cable ? Regards David
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Sorry I meant whats the Operating System?
  • Ben Wabnick
    What kind of computer are you trying to setup the network on?
  • 1,602 Answers
NEED TO CHECK AND CHANGE THE SETTINGS IN THE WINDOWS DEFENDER,
WINDOWS FIREWALL
THE FIREWALL IS NOT ALLOWING THE NETWORK AND THE COMPUTER TO COMMUNICATE WITH EACH OTHER
CHECK THE FOLLOWING AREA IN THE CONTROL PANEL:
DEVICE MANAGE
SECURITY CENTER
SYNC CENTER
PROBLEMS AND REPORTS
NETWORKING AND SHARING
THANK YOU RODGANDYSR
Posted on Mar 09, 2009
I cannot connect. I keep getting a message "authentication Failed"
Do you connect your PC to router in an administrator role using web browser? Or do you connect some device to Wi-Fi network?
  1. Administrator role: You need to have correct login name and password for admin access. Search in manual or ask Google for default login name and password of your router type. If non-default password is set in the router then you must reset router setting and erase its settings to default (factory) status. You will lose all router configuration but default password is back.
  2. Wi-Fi client role: There are more possibilities why authentication fails in wireless communication. Mentioned error message describes what kind of problem occurred.
    (a) A password you put to client device does not match the wireless network password which is set in router. Your computer, tablet or smartphone WI-Fi interface must have exactly same password as WI-Fi network which is transmitted from router. Check and compare passwords on both sides, in client device and in router.
    (b) Client Wi-Fi interface security (encryption) mode differs from Wi-Fi network encryption used in router. But the same mode must be set on both sides (client and router) for successful connection.
Encryption modes are
  • WPA2 Enterpise
  • WPA2 PSK ("home")
  • WPA Enterprise
  • WPA PSK
  • WEP
  • No encryption (open)
Higher position - better security. Enterprise Wi-Fi modes require security devices like authentication servers, certification authorities etc. They are not used in home networks usually.
Jan 21, 2016 | Computers & Internet
Tip
How to set up internet on Samsung Jet
Ensure that you have the appropriate network key code needed to enable you to access a secure Wi-Fi network.
If you are connecting to a secure Wi-Fi network with MAC address restrictions, you will require pre-authorisation for the router. You will need to find your Samsung Jet's MAC (Media Access Control) address. This is a 12-character code which may be needed by the network controller to enable the phone to connect. See Getting the Samsung Jet's MAC address below.
You can get to the Wi-Fi application either via the main menu or using a homescreen Wi-Fi Widget.
  1. To get to the Wi-Fi application via the main menu, press the MENU button (either on the home screen or the hexagonal button beneath)
  2. In the main menu, swipe your finger sideways to go through the menu pages until you see the Wi-Fi icon. Press to select.
  3. The Wi-Fi application opens.
  4. Alternatively, to use the Wi-Fi Widget, from standby, press the home screen. The Widget toolbar opens up.
  5. Scroll down to find the Wi-Fi Widget icon. Press the Wi-Fi Widget. The Wi-Fi Widget will pop up on the main screen.
  6. Press the Wi-Fi Widget on the main part of the display to launch the Wi-Fi application. The Wi-Fi application opens.
  7. Once in the Wi-Fi screen, press the large Wi-Fi button in the middle of the screen to turn it on. Wi-Fi is activated and the button turns blue.
  8. Press SEARCH Nearby Wi-Fi access points (APs) will appear as small circles on the display, with their names next to them.
  9. Press the circle representing the Wi-Fi Netowrk you want to connect to. An options panel appears.
  10. You can press CONNECT to connect to the network or press ADD if you want to add it to a list of preferred networks for easy access later.
  11. You are taken into a settings menu for the Wi-Fi access point. If the Wi-Fi access point requires a network key code, scroll down to the Network Key panel. Press to select.
  12. The numberpad appears. Type in the network key code and press DONE. You are returned to the previous settings screen. Press SAVE
  13. A list of connections appears. Press the back arrow button
  14. If you initially pressed CONNECT, the phone will connect to the selected Wi-Fi network and a confirmation message will appear. The display now shows the new connection, illustrated by blue dots linking the circles onscreen (Figure 15).
  15. If you initially pressed ADD, you will be returned to the Wi-Fi screen. Press the circle representing the Wi-Fi network you want to connect to. A pop up panel appears.
  16. Press CONNECT. You will be connected and the connection illustrated onscreen.
Press the back button to return to the home screen.
  1. From the home screen press MENU to enter the main menu (Figure 1).
  2. In the main menu, press INTERNET
  3. Choose which browser option you want (Home, Enter URL, Bookmarks, etc.) (Figure 18) and press to select. If you press Home you will be taken to the pre-loaded home page.
  4. If required, use the numberpad to type in an URL or scroll a list to select bookmarks. When an URL is completed press GO. Alternatively press the bookmark you wish to access. You will taken to the web page requested.
  1. Activate Wi-Fi and press SEARCH, as before.
  2. When the Wi-Fi access point you want to connect to appears on the display (Figure 8), press it to select.
  3. A pop up options panel appears (Figure 9). Press DETAILS
  4. Details of the Wi-Fi access point appear onscreen.
  5. Scroll down by dragging your finger up the screen. Towards the bottom of the settings list, DEVICE MAC appears, with a string of 12 charactesr beneath (Figure 21). Each handset has an individual MAC address, and this panel will display your Samsung Jet's unique Mac address.
Make a note of the MAC address. You will need it if you want to use the Samsung Jet's Wi-Fi to access a secure Wi-Fi network using MAC address restrictions. This can be added into the wireless router settings access list.
on Apr 17, 2010 | Samsung Jet S8000 Cell Phone
When i connect my samsung galaxy express to wi-fi my computer's wi-fi stops working
Hello Ricardo.
How are You? I Guess you need to
1- Check your wi-fi router model.
2- Check your wi-fi settings.
also please check how many devices are connected to your wi-fi at same time. because some routers can only support upto 5 device. you can check this in the settings and also routers manual.
Please let me know, once you done with it.
Regards
Nov 22, 2013 | Samsung Cell Phones
What does need a data connection mean
To use Google maps or some other programs (like games), you need to be connected to a Wi-Fi network, not the cellular network. You will need to be in an area with an open wi-fi network or have a wireless router in your home. Find your password for the router's wi-fi network (it should be password-protected) and the SSID; you also need the encryption type (WAP, WEP, etc.).
Press Apps on the Home Screen. Then press Settings and then Wi-Fi. Select Scan to locate available networks. While on the Wi-Fi tab, press Add Network. Enter the SSID with the keyboard, then touch Security type to select the encryption for your router. Then enter the password and finally press Save. (Some wi-fi routers will want the MAC address before you can add a device to the network. Go to the Menu - Advanced from the Wi-fi tab to get the information.)
If the wi-fi network has been set up on the Tab, press Apps on the Home Screen. Then press Settings and look for the Wi-Fi On/Off icon. Toggle this to on. (You can also access this by touching the time on the Home Screen. Then touch Wi-fi on the Quick Settings list.)
I hope this helps.
Jan 16, 2013 | Samsung Galaxy Tab 2 7.0
Cannot connect smartphone to my computer via wi-fy
The smart phone should work fine on any wireless router. Try going to wireless settings on the phone and if it has your network remember click and hold on your network and select forget network. This should clear out any thing cached about your network. Once that is done try re-connecting to your network and enter any password you may have.
Dec 03, 2012 | Computers & Internet
How to enable wireless connection on dell latitude e4300
I have had this issue on DSL troubles.The most common issue is the settings for the IP address.A computer in a business location will often be set for a static IP.You can change it,but don't forget to write down the static IP settings(as soon as you click on the "bullet" for "obtain IP address automatically" ,the static info is GONE,and there's no way to retrieve it.Go to control panel/network connections,right click on the NIC or Wi-Fi connection being used,click properties,highlight Internet Protocol TCP/IP,click properties.This will show auto or static IP.
May 31, 2012 | NetGear WGR614 Wireless Router
Can you hook the ps3 up to the internet wirelessly
Yes you can connect wirelessly to the internet with your ps3.
Minimum Requirements
  • PlayStation®3 computer entertainment system
    Note: PlayStation 3 40GB / 60GB / 80GB / 160GB models ONLY (20GB model does not have built-in Wi-Fi connectivity)
  • SIXAXIS™ wireless controller (and USB cable)
  • AC power cord
  • A high-speed Internet account (cable or DSL) with an Internet Service Provider (ISP)
  • Router
    • Wireless router compatible with 802.11b or 802.11g Wi-Fi standards
    • Or an Ethernet (wired) router with a Wireless Access Point (WAP)
      You may need to open firewall port numberson your router to connect to the Internet.
      The PlayStation 3 will not connect to the Internet through the USB ports.
  • Updated system software installed on your PlayStation 3
    Visit PlayStation 3 System Software Update to download and install the most recent version.
  • Your Wireless Network Settings
    • SSID
      You will need to know the Service Set Identifier (SSID) of your wireless network. Also make sure the WAP or wireless router is set to broadcast the SSID; otherwise, the SSID will NOT appear on the PlayStation 3 scan results.
      If you do not know this information, speak to the person who configured your home network (i.e., wireless router) settings.
    • WEP or WPA Security Key
      If your wireless network access is security-enabled (encrypted) from open access, you will need to know your WEP (Wired Equivalent Privacy) and WPA (Wi-Fi Protected Access) security key or password
      If you do not know this information, speak to the person who configured your home network settings.
    • MAC address
      You may need to enter the Media Access Control address (MAC address) of your PlayStation 3 into your WAP if it is required by your network settings.
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
How do i do a wireless connection between computer and a kodac 5100 all in one printer
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/5100AiOPrinterUG_EN-US.pdf
follow this manual ...
  1. Check the Wi-Fi Status Indicator on the front of the printer:
  2. Status: Do the following: Off
    1. Select Menu (or Home)>Network Settings and press OK.
    2. Select Turn Wi-Fi Radio On and press OK.
    3. Select Wi-Fi Setup Wizard and press OK.
    4. Select the SSID (name) for your router.
    5. If you have your network secured, you must also enter your password.
    Blinking
    2. Select Wi-Fi Setup Wizard and press OK.
    3. Select the SSID (name) for your router.
    4. If you have your network secured, you must also enter your password.
    5. NOTE: If the message Your printer is already configured for Wi-Fi network appears, your printer cannot find your router.
    6. If this occurs, check that the router is turned on and located within 100 ft (approximately 30 m) of the printer.
    On The WiFi Status Indicator could be on, but you could be connected to the wrong router if you used the manufacturer's default SSID and password when you set up your router. If this is the case:
  3. Select Menu (or Home) from the printer control panel on the front of your printer.
  4. Select Network Settings and press OK.
  5. Select View Network Configuration and press OK.
Place the KODAK All-in-One Printer Software CD into the CD-ROM drive on your computer.
Follow the on-screen instructions. Do one of the following depending on the version of KODAK All-in-One Home Center Software:
  • When the KODAK Printer Setup Utility screen appears, select how you want your printer to be connected:
    • USB cable
    • Wireless Wi-Fi® connection
    • Ethernet cable
Oct 12, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
I have forgotten my dlink user password for my home network Help?
First connect your router to computer with ethernet cable.
Then you can access it with following link
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then go to wi fi security check your WEP code it is your password to connect wi fi network.
Let me know if you need more assistanse.
Thanks
Sep 13, 2009 | D-Link DIR-625 (790069292637) Wireless...
Cant automatically detect IP
First, connect your computer via an ethernet cable to the router to eliminate any problems with your wi-fi setup.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
  1. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Power on the computer.
  2. Open the Control panel and the Network Connections applet.
  3. You should see something called "Local Area Connection".
  4. Double-click on it and click the Properties button.
  5. Double-click on "Internet Protocol (TCP/IP)" and make sure both radio buttons are set to "Obtain...automatically".
  6. Close all Windows by clicking "OK". (The second one takes a moment, because it applies the settings.)
  7. In the open window choose the Support tab and you should see your IP address, your Default Gateway (192.168.1.1) and your DHCP server (192.168.1.1)
For your wi-fi setup, repeat step 2 through 7. In step 3 you should see your "Wireless Network Connection". Use this one and repeat the remaining steps.
If this did not fix it for you, you have to come back and give more information on:
  1. Which router model are you using?
  2. What computer do you have?
  3. Which operating system (Windows, Linux, Mac)?
Let me know how this worked for you and I'm happy to assist further.
Jan 14, 2009 | Compaq Presario C700T Notebook
Computers & Internet Logo
96 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
Computer Links
