Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
Troy-Bilt Trimmer won't start
I bought the trimmer last year and have followed the recommended guidance for winter storage. Got it out, filled it with the proper mix, followed the cold start instructions - Nothing. Consulted the manual, appears to be getting fuel flow, so I replaced the sparkplug - nothing. That cycles it back to a fuel flow problem and my preliminary inspection doesn't give me much visibility into the lines. Any ideas? Product is less than a year old........Thanks.
  • 40 Answers
Try taking the carb off and you should find 2 adjustment screws on it. turn those in until they stop, do not force tight. while doing this be sure to keep and eye on how far you turn them in. they likely wiil be set at 1 1/2 turns. now that you have done this unsrew them all the way out and get some carb cleaner to spray in there and rinse any old or dried up gas out. then replace the screws at the same setting they were before you took them out. this should take care of it.
Posted on Mar 11, 2009
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How do i fix my flooded TB32 EC troy bilt weed eater?
be sure fuel filter is on the primary fuel line in the tank.check primer bulb and fuel lines.also check fuel tank cap.vented cap may be stopped up
Sep 10, 2012 | M T D Southwest Inc Troy-Bilt TB32EC...
Cannot restring Troy-Bilt weed trimmer
On the directions below tells you how to restring the spool.
If you can not read it you can click on the link below to download the manual.
http://manuals.mtdproducts.com/mtd/GetFile.do?filename=769-04481.pdf
If you have any questions please ask befor you rate.
Good Luck
Jun 27, 2010 | Troy Bilt Tb70ss Gas Trimmer
Troy-bilt trimmer TB 490 BC
Turn the bump knob clockwise to loosen on my tb490bc.
May 29, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I have a Troy weekwacker, and after sitting this winter, it WILL not stay running. The only way to even get it to start is to load the thing with starting fluid, and then it only runs til it eats up all...
Have you changed the spark plug on this unit? If all else has failed, this is more then likely the problem. Please let me no if it takes care of the problem.
Sincerely, Shastalaker7
Apr 14, 2010 | Troy Bilt Tb70ss Gas Trimmer
My troy-bilt 70ss trimmer head and or attachments stopped spinning. This is the third troy-bilt trimmer with this problem I have already exchanged two other trimmers within the first 30 days of purchase....
Considering your experience, if I was in your position I would locate the cause of the persistent failure and contact the manufacturer who might be suitably grateful.
I did that once with an inspection light that was bought in from China and brand engineered, as many goods are today, and I received a voucher and the company stopped buying that model. While it didn't help me much it would have helped others.
I am not familiar with the Troy-bilt brand which must be an exclusively US brand. I have used a MAC-60A for 30 years without many problems, a model reckoned by repairers to be a short-lived cheap consumer model.
Dec 01, 2017 | Troy Bilt Tb70ss Gas Trimmer
Trimmer will not start after winter how can I repair it.
Get rid of all that crappy fuel from last season and give your carb a good cleaning and then start from square one.
Apr 07, 2010 | Troy Bilt Tb70ss Gas Trimmer
Troy-bilt TBP6040 4-cycle stalls out after about 10 minutes. Started doing this the 2nd time I used it. After it stalls out it will not start until it completely cools off. Fresh fuel in it. Arrestor...
I have the same model from Troy-Bilt. I have only had it about 4 or 5 months. Mine has started using a LOT of oil. I noticed a significant increase in temperature compared to my old Husqvarna 2 cycle. Mine does not completely stall, but it does start to sputter when it gets hot. I am going to take mine back to Lowe's where I bought it. So far I am VERY unhappy with the TBP6040.
Aug 24, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Trimmer won't start after following instructions
Might need a new spark plug if it's more than a year old. I had mine a year and after the winter couldn't get it to start. Replaced the spark plug and it's good as new.
Jun 20, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
2,817 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
