Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
The washer will not fill with water. When you pull the knob you can hear the motor running but no water.
    Genius:
  • 2,120 Answers
Bad fill valve solenoid, available at any appliance parts store, could be the connector is loose or off.
Posted on Mar 08, 2009
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
My washer buzzes when knob is pulled but it will spin just not fill or agitate
sounds to me like either the water faucet at the wall is shut off or their is some sort of restriction to the pipes not allowing the washer to fill
some on here may say that the buzzing will be the motor but since it spins i say bully to them the motor only knows to go to spin or agitate rotation based on on what the timer/control tells it to do if it will turn one direction it would turn the other direction as well. So definently check the water supply to the washer
Oh the buzzing is the solonoid on the valve opening the valve yet since no water coming in you hear the buzzing while you wouldnt hear it since it would be drowned out by the sound of the water coming in
Jul 19, 2011 | Washing Machines
Hello, my washer will fill with water and I hear a relay click when I pull the knob (not just the knob clicking). I also hear a buzzing sound from the washer itself when I pull the knob out but it won't...
PRESS AND HOLD IN POWER BUTTON FOR 15 SECONDS SO THAT ANY INTERNAL ERROR CODES CLEAR THE SYSTEM. MAKE NOTE OF THE LIGHTS THAT FLASH. ATTEMPT TO USE THE SYSTEM NOW.
Jan 26, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Water plumb are not working. Does it worth to fix? Thanks.
IF THE WASHER IS NOT PUMPING THE WATER THROUGH YOUR DRAIN, AND YOU HEAR THE PUMP RUNNING, YOUR DRAIN LINE FROM THE WASHER TO THE SINK DRAIN IS CLOGGED. DISCONNECT HOSE FROM SINK DRAIN AND VACCUM OUT, OR RUN A WIRE OR SOMETHING SMALL BUT STIFF TO LOOSEN THE CLOGGED HOSE. NOW RUN THE WASHER AND ALLOW SOME WATER TO BUILD UP IN THE WASHER, IF WATER ALREADY EXISTS THEN TURN KNOB ON WASHER TO DRAIN. MAKE SURE YOU HEAR WATER DRAINING IN SINK AND PROBLEM SOLVED. IF THE PUMP MOTOR IS NOT TURNING AT ALL , BUT YOU CAN HEAR IT ENGAGE, THEN TURN WASHER OFF, TAKE FRONT BOTTOM PANELS OFF, LOOK FOR THE MOTOR AND TAKE YOUR HAND AND ROTATE THE MOTOR CLOCKWISE A FEW TURNS AND THEN COUNTER-CLOCKWISE A FEW TURNS, IT WILL FEEL LIKE A DISC IN THE FRONT OF THE MOTOR. IF YOU DON'T FEEL A DISC AT THE FRONT OF THE MOTOR, THEN LOOK AT THE BACK OF THE MOTOR AND YOU SHOULD SEE WHAT LOOKS LIKE SOME BLADES. NOW TAKE A SCREWDRIVER AND ROTATE IT CLOCKWISE AND THEN COUNTER-CLOCKWISE. MAKE SURE YOU GET SOME ROTATATION WITH EITHER METHOD THAT YOU HAVE TO USE. YOU WILL FILL RESISTANCE AT FIRST, BUT KEEP TRYING TO TURN THE MOTOR. AFTER GETTING IT TO MOVE, TURN THE WASHER ON NORMAL CYCLE AND ALLOW TO RUN. IT SHOULD DRAIN WITH NO PROBLEMS. REMEMBER THIS IS JUST BUILD-UP INSIDE THE WASHER AROUND THE INSIDE OF THE PUMP AREA. ALL YOU HAVE TO DO IS BREAK IT LOOSE. IT MAY SOUND LIKE A HARD TASK , BUT IT IS QUITE EASY. YES IT IS WORTH FIXING, BECAUSE IT WILL COST YOU NOTHING. IT TOOK LONGER FOR ME TO TYPE THIS THAN TO FIX YOUR PROBLEM. TO KEEP THIS PROBLEM FROM COMING BACK, OR COMING BACK MORE OFTEN, ALWAYS SCRAPE EXCESS FOOD IN TRASHCAN AND RINSE THE DISHES OFF WITH WATER BEFORE PUTTING THEM IN THE WASHER. ALSO PULL THE BOTTOM RACK OF THE WASHER ALL THE WAY OUT AND CHECK THE FILTER SCREEN TO SEE IF IT IS CLOGGED. IF IT IS UNCLOG IT . THIS TAKES APPROXIMATELY 30 TO 45 MINUTES, AND SAVES YOU $$$$.
Apr 13, 2010 | Bosch SHU9915UC Dishwasher
The washer fill but no program would start
**WARNING!!! Unplug appliances before beginning repairs!!!!
You need a new programmer (Controller). The motor is jammed or not running. Very common. Controllers cost $75 to $300 dollars US. Find out the price before you order it!
Getting the knob off the controller can be hard. I suggest a new knob with the controller if it will not pull off or unscrew backwards. Special tools may be required.
Most controllers are easy to change inside as they plug in.
Mar 20, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Water will not run into the tub
Have you tried disconnecting the water inlet hose and cleaning out he screans in the back of the washer?
Jan 18, 2009 | Kenmore 24032\24036 Top Load Washer
When I pulll the knob on the washing machine, their is no water not running out
Can you hear it "clicking" when you pull the knob (not the knob sound itself, but the water solenoid itself)?
If you can hear it, then make sure the machine has a water supply (hot / cold). You would be surprised at how many people accidentally turn off the water supply and forget about it.
Try changing the wash settings to cold/cold, etc (the opposite of whichever one you're using now) and see if it will fill.
Let me know the results, and I can help you further.
Jan 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
My maytag washer just stopped working...
Manually open the timer switch component rotate the knob forward and it will work. / rotate inline w/water fill full keep near the timer you can hear the timer running or not / if not the small motor of timer need to replace availqble in appliance service center,.
Dec 16, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
