Question about Sanyo Televison & Video
I have a Sanyo 32 inch tv, model # DS31650, that has no sound
I have a Sanyo 32 inch tv, model # DS31650, that my neighbor was throwing away because there is no sound. The picture is fine, but even with the volume all the way up there is just a bit of a hum. Any help getting this fixed would be greatly appreciated, as I was hoping to use it for my PS2 instead of the 20 inch I am currently using.
  • moore0012 Mar 09, 2009
    Thanks guys, I moved every dial I could find on the board, then tried to get them all back in the exact position they were in before. Now the sound works, but only through the video link, not for cable TV. AND, the color is a little off. But at least I can hear the video game and that is what I really want it for. I am going to try to correct the color problem. Thanks again for the help
  • moore0012 Mar 15, 2009
    thanks for the help. turned out the color problem was from unsheilded speakers that I was using to replace the original ones in the TV. After getting the sound working, I replaced the original speakers and the color problem was gone.
    Scholar:
  • 170 Answers
Actually the coil doesnt need replaced. on two sides of T131 one side is a cap labeled 103 and the other is a small resister labeled grey red red. 8.2k ohm. I have one in the shop that i couldnt adjust the t131 to get the sound back so i just replaced the resister and cap and there was no adjustment needed on t131. the resister does not need to be a small one as i used a half watt in place of the quarter watt one. and the 103 cap can be found in old scrap electronics. make sure that the cap is labeled the same with no extra markings. should look exactly the same.
Posted on May 12, 2010
  • 74 Answers
My book says no audio, storm damage need to replace ic 3601 (CXA1279AS part number 409 279 3109) this is probley a surface mount ic on the bottom of board.
Posted on Mar 09, 2009
  • 39 Answers
There is an SIF coil (sound-intermediate-frequency) that goes bad on these units. it will be near the video jungle ic and marked sif on the board. since your sound is poor anyway you could try to adjust, in very small incremens at a time to see if audio picks up. sometimes dirty connections in the coil will cause poor conductivity, by turning this will move contact to new position mch
How can I fix a problem with my Sanyo standard CRT TV?
well,the last of the dinosaurs is in its death throws,a new picture tube is 500 bucks,a flat screen is 400,its up to you,do you replace the tube and pay to install it or buy a flat screen and not worry about it for a few years and save electricity
Jun 11, 2015 | Sanyo Televison & Video
My newstar remote do not activate with my sanyo led tv
One of these codes should work for Sanyo:
004, 013, 049, 108, 110, 180 or 209.
Apr 14, 2014 | Sanyo Televison & Video
NO POWER ON SANYO TV MD DS31650
Check and replace damaged component/s at its main power supply regulator stage [SMPS] circuit. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 14, 2014 | Televison & Video
I own an 32 inch RCA TV Model No. F32444 one day
The TV has burned out.......Don't switch it back on again unless you want to get electrocuted, or burn your house down
Jan 19, 2010 | RCA F32444 32" TV
Vertical line in center
If the line is "vertical" then the vertical circuit sounds OK. The problem would be in the horizontal deflection.
Check yoke connection and solder around horz defl circuit.
If the line is horizontal then I would suspect the vertical IC.
Apr 02, 2009 | Sanyo DS31520 31" TV
Sanyo DS20930
The problem with saying my TV is acting up, is you did not mention the model #, type of TV, tube type, projection, plasma, LCD. They all have different faults that can cause this. The first thing you do is to hook up signal to your video inputs if you have any and see if the signal works that way, if so then you probly have a bad tuner, or you cable box is bad.
Oct 26, 2008 | Sanyo DS20930 20" TV
No power with Sanyo TV
Why isn't the answer to Tom Gray's problem posted on this site?
Feb 03, 2008 | Televison & Video
Sanyo DS31650 31
If the set runs at all, your flyback and output transistor are good. If the set shuts down after a few seconds and the sides are wavy, it usually means that the main B+ in your power supply is too high and not regulating properly. I do not know what kind of power supply that model uses, but if has an old-style STR regulator (like the STR30130) then it is probably shorted, and if the set uses a switching power supply then look for an open or leaky electrolytic cap on the primary side. If the power supply is working correctly and the set shuts down, check for an open safety cap (the large 1.6 - 2Kv cap connected to the collector of the horizontal output transistor).
Aug 17, 2007 | Sanyo HT32744 32" TV
Televison & Video Logo
328 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
