Question about Razor MX350 DIRT ROCKET - BLUE
Razor 350- Does not run
It has been sitting for quite a while and does not run. The battery appears to charge, the red light is on first and then it turns to green. The light aqt the throttle also says full charge. When you turn the power on you can here a click inside so it appears to be getting juice, but when you hit the throttle it does not go anywhere. I pulled thefront piece apart to make sure all the connections were okay and check the fuse, that all looked good. Any suggestions?
  • Matt Sehenuk
    Matt Sehenuk Apr 06, 2009
    have the same problem. solution found yet??
    New Friend:
We were having the exact same problem bought this machine a year ago it ran one time and not again. it would click but nothing else would happen the battery tested god we disconnected the brakes and it works! hope this helps you!!!! yayyyyy
Posted on May 09, 2013
I am having the exact same problem.... Mine is 1 month old talked to razor they are sending me a new charger... I know that is not the problem because I have two chargers and and both show green. I need help as well.
Posted on Jan 04, 2011
Hi there,My girls Razor E300 is a year old wont fully charge...
My guess is the batteries have gone bad. They only last about a year before they need to be replaced. You can buy them fairly cheap off of Ebay.
Jan 04, 2013 | Razor E300 Scooter
How will i know if its my batt or motor on off switch lites up red but nothing happens
Lift the rear wheel up off the ground and apply the throttle, while watching the throttle lights. If the throttle light goes from green to yellow or red it shows that the battery voltage is dropping under a light load because the batteries are low in capcity - not holding much charge. Most battery places will load test the batteries free of charge to confirm this.
Have a look at the trouble shooting guide here
http://www.razorama.com/razor-installation-guides.html
and the wiring diagram here
http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
Jul 30, 2012 | Razor MX350 DIRT ROCKET - BLUE
Razor Bistro scooter won't take charge - light stays red
i had the same problem with mine and it ended up being that one of the batteries was bad, there are two 12v batteries wired in series under the seat, usually you can tell which one is bad by looking at them, one of the batteries will be swelled up
May 09, 2012 | Razor Pocket Mod-bistro Retro Scooter
I have an e100 that appears to be fully charged. The red light on the on/off switch is on but the scooter goes nowhere? I checked the batteries for output and goes 12.85 volts. The motor doesn't even...
If thats the voltage from the 2 batteries joined together then the voltage is far too low to run an E100, sounds like one of the cells has died, must have a 24v combined output.
Jun 28, 2011 | Razor E100 Electric Scooter
Have an e100 razor electric scooter. it has not been used for a couple of years. I got a new e100 charger and tried to charge but i noticed that the green light stays on and the red light charging does not...
The batteries are dead. The battery in these scooter need to be kept charged or if not in use for a long time charged every 3months. Otherwise, like what to you, they will go dead. The chemicals in the battery have deteriorated to the point where it won't hold a charge. Replacement batteies are available at:
razor.com
Jul 20, 2010 | Razor E100 Electric Scooter
2006 Bonneville America electrical failure
To start with, your battery was probably already low. You have to be at about 4000 rpm for the charging system to kick in and put out 14v or so. So if you just sit and idle, you will eventually run the battery down. If it is already low, you may have run it down below where there are enough amps to start it again. I know my 2002 BA started having what appears to be charging or regulating problems and the batteries won't stay charged. Try charging the battery with a good trickle charger to begin with. Then, when it is fully charged, run the bike and see if the charging system is keeping things up.
Mike
Feb 22, 2010 | 2006 Triumph Triumph Bonneville
Razor E100 reset button and no charge
Hi... My son hasnt used his Razor E100 for nearly a year as couldnt find the charger.. I finally found it and as soon as I plugged it in the plug was showing green light as that it was fully charged... When we turn the unit on it lights up but its dead... Where can I get the cheapest battery (and does it have 1 or 2)? Or you mention a reset button? Many Thanks...
Jan 24, 2010 | Razor E100 Electric Scooter
I no longer have the owners manual. What does it
According to the manual, the red light comes on while charging when the battery does not yet have enough charge to sustain a 3-5 minute shave. The green light stays on steady while the razor is charging, and blinks when it is fully charged. If your battery life is short, they might need to be changed.
Jul 14, 2009 | Norelco Rechargeable Cordless Men's Razor...
Razor e200 runs slow
This could be a sign of a dying battery, although it charges and lights the green light it cannot maintain enough juice to power the machine when it has weight on it.
Dec 07, 2008 | Razor E200/300 Electric Scooter Battery
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Razor MX350 DIRT ROCKET - BLUE Logo
1,329 people viewed this question
Top Razor Cycling Experts
Ted Maxwell
ray gallant
wayne-m
Are you a Razor Cycling Expert? Answer questions, earn points and help others
