Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
Pops out of lock under a heavy load
When kneading bread or pizza dough at no more than Speed 2 setting, motor section "bucks" and soon unlocks itself.
This bucking has caused the thumb screw to unscrew allowing both it and the cap hub to fall into the mixer bowl during the mixing process. As a result, the plastic part of the thumb screw has cracked and no longer stays screwed in (I have it taped on with blue painter's tape in order to keep debris out of the attachment hole).
Is there something that I can tighten or adjust to remedy this problem? Can I get a replacement for the thumb screw?
Thanks in advance
  • susanvera Mar 10, 2009
    Mixing smaller batches of dough is not a solution. This machine, only 3 years old, used to handle a 2-loaf batch of dough with no problem, so if anyone else has a clue as to how to diagnose the machine's problem so it can be fixed, we sure would appreciate it.
  • susanvera Mar 19, 2009
    Thanks for your input, RicardoK45. I managed to mend the thumb screw using an amazing adhesive called BondWel (Yes, one L).
    Thanks for the explanation about the hinges loosening. Is that something a do-it-yourselfer might be able to fix?
    I went with Kitchenaid after trying a Sunbeam (now there's a piece of junk! It broke on the first use) upon the recommendation of a friend who bakes bread weekly, another friend who's used hers for 20 years and the positive Consumer Reports rating. I'll bookmark consumeraffairs.com for future reference. Thanks for the link. That oil leak business that so many have experiences is concerning.
  • 135 Answers
Hi Susan. There is no worse feeling than the feeling you get when you find that you've been seperated from your hard-earned money by a company that markets a product with glowing phrases of what their product can do...And then doesn't deliver on it's promises. Kitchenaid mixers can make short work of bread dough NOT! My Kitchenaid HD Pro (475 watts) self destructed after only 30 uses of making my Sourdough Bread. The problem? A cheap piece of plastic that takes the stresses of two important shafts in the mixer. Cheap, shoddy parts in a mixer you paid top dollar for. Kitchenaid shows no shame in doing so.
What is happening with your mixer as it tries to mix your dough is that the head unit is thrust back and forth and side to side (bucking). Eventually hinges become loose and sloppy. Kitchenaid's behaviour is legal and beyond reproach, so make your next mixer purchase an informed one.
Goto www.consumeraffairs.com and do a search for your Kitchenaid model. You'll notice that you're not alone in your mixer troubles.
I solved my mixer problems by buying a used Hobart 20qt. Commercial mixer (A200) and rebuilt it. When mixing heavy dough you should only use about 60% of the bowl capacity. less, if your mixer is agonizing with the amount of food in the bowl..
You will be able to replace the thumb screw. Be prepared to wait for at least a month for the part to arrive once ordered.
If this solution has assisted you, please rate it. Good luck! ricardok45
Posted on Mar 19, 2009
  • Rick Belanger
    Rick Belanger Mar 19, 2009
    Hi again Susan. Take your mixer to an authorized repair center. Tell them about your problem. Ask if they can fix it. If they say "we can try", just walk away and start looking for another mixer. If they say they can fix it, get a firm quote from them and ask how long their warranty is on parts and labour. If they are "Iffy" on the subject, walk away.
    Your Sunbeam, if it lasted long enough, would have done the same thing. My Sunbeam did, which is why I bought a Kitchenaid based on their "Good Old Brand Name" and their marketing Lit. They lied about how much flour it could handle. I believe that All the manufacturers lie about their products, simply because they can get away with it. There are no watchdogs for the consumer's rights.
    I don't think that your mixer can be repaired, I think that the hard mounting points for the hinge and lock have been forever re-shaped by the constant pounding of the bucking motion.
    I think that if you're going to make bread, you're going to have to invest in a good quality commercial mixer. The only one I can recommend is Hobart, and not a new one either. Hobart was sold to ITW around 2000. The Kitchenaid line was sold to Whirlpool Corp. about the same time. The new "Legacy" Line from Hobart is not of the same overall quality as the old ones. The older Hobart's can be found on eBay, or through a local used restaurant equipment Supply place locally. Parts are readily available for the newer machines. There is not enough space here to educate you on all of the things to look for when buying a used Hobart, but I'll give you one important one. Look for a used Hobart mixer that has a round black knob on the gearshift lever, this will indicate a somewhat newer model that may not have it's insides worn out yet. If possible try the mixer out in all gears. Be sure to turn off the mixer before attempting to shift gears.
    If you find a good candidate for your next mixer, it may be worth your while to hire a Hobart tech to take a look at it and give you an asessment on it's condition. If the current owner will allow it. Have the tech take off the two dust covers on the transmission housing and take a look for the amount and quality of the grease inside. Very low grease = excessive wear on the upper gears. Excessive oil=grease worn out, must be replaced. Check the nut on the planetary, if oil drops are present that means that the seals will have to be replaced. Hobart's tech. labour is approx. $100.00 per hr. and parts aren't cheap. Ideally, if you could find an A200 (20 qt. mixer) or an N50 5qt. from a school that would be the peach, as these mixers aren't run hard and all of them have been on a service contract and have not been worn out. I have it on good authority that all schools are upgrading their kitchens. So check out your local schools first. You could get real lucky. Even with a 20qt. bowl you can only load it up to 60% of the bowl's capacity (for heavy bread dough). If it does not come with an "ED" dough hook get one, as it will do all the kneading right there in the bowl. Finally! Good luck! You're going to need it. ricardok45
  • Rick Belanger
    Hi Susan. Re: the oil. Kitchenaid recommends that you turn on your mixer once a week to keep the oil in suspension in the grease. Over time all greases will separate. If you find a mixer that suits your needs, I'd suggest re-greasing it with Chevron FM ALC EP-2 grease. This product has a Mineral Oil base and is rated as a food grade grease, meaning that a few drops in the bowl are OK. Not so with other greases which are petroleum based. Seals on mixers are designed to hold back grease no oil, so the presence of oil means servicing is necessary. Hope this helps. ricarok45
  • 125 Answers
Kitchenaid parts on line, try mixing smaller batches of dough
Posted on Mar 09, 2009
Mixer arms shake when kneading bread
You have not supplied a model number and the bowl lift models are not all the same. A couple of items you could check, make sure that the bowl retaining clip that engages with the dimple on the pedestal side of the bowl is not broken. Make sure any bolts/screws holding the pedestal to the base or the pedestal to the motor are tight. Even if you supply a model number I can't think of anything else to look at unless the handle is not lifting the bowl up tight enough. I think on some models the arm holds the carrier up with some pressure which would help stop the wobbles.
Jul 13, 2017 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
What can you use for a hobart h600
The Hobart H600 is a 2 horse power, 60 quart mixer, it can be used for many things in the kitchen. It can be used to make about any kind of food that needs mixed, wiped or kneaded. It works well in a pizzeria for all facets of making pizza from the dough, to shredding the cheese with an attachment, to a restaurant that makes mashed potatoes and fresh bread, to a full service bakery.
However, the biggest thing that you need to know is the capacity of the machine. As overloading the machine can cause damage that may be costly and take a technician to fix. I do not know what attachments you currently have so I will go over a few of them.
The main attachments are a Wire whip, Flat beater, and Dough hook. There are three different types a "D" wire whip (has many wires and is evenly spaced) this is used to whip egg whites, whipping whip cream, etc. The "C Wing" (has six tines in it) is used for items that are heavy for the D wire whip, like whipping potatoes or icing. The last is the "I" whip is similar to the D wire whip just with less tines. The flat beater is used to mashing or mixing examples are mashed potatoes before they are whipped, cake mixes that do not require whipping, batters and icing. The Dough hook is used for kneading dough examples are pizza dough, bread dough, etc.
The biggest thing when using your mixer is to know its capacity for the material that you are mixing. All though this is one of the bigger machines it still has limits. You should refer to this the following link for the capacity of your machine:
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F-7701.pdf
There are also a few attachments that can be put on to the No. 12 attachment hub. A few of these are a vegetable slicer-grater and meat grinder.
Mar 04, 2011 | Hobart H600 Stand Mixer
Hi, We have a 3phase Hobart D300 Mixer onboard and the cooks are complaining that there is not enough grunt. I have checked the 3 speeds and they are working finee however when dough is being mixed it...
Hello Veelec,
As the machine is mixing dough it seems that it is getting sluggish. This is caused by the machine being over loaded. Although it is a 30 qt mixer that is for liquid filled capacity. I do not know what kind of dough you are mixing so I will give you a light to medium dough and then the heavy dough capacity. Also on this machine all dough should be mixed in speed 1 or low to keep from damaging the machine.
You will need to know the Absorption Rate (AR) of you dough, to find this you take the weight of the water divide the weight of the water and multiply by 100.
AR = Water Weight / Flour Weight x 100%
The higher the percent the higher the capacity the lower the percent the lower the capacity. Also the temperature of the water will have to be considered as the colder the water the harder the dough it is to mix the dough the batch should be reduced by 15% to 20% for water temperature between 65-75 degrees.
For a Light to Medium dough with a 60% AR the unit capacity is 45 pounds in first speed.
For a Heavy dough at 55% the units capacity is 30 pounds in first speed.
The above capacities are for bread doughs, if you are doing pizza dough, dough nut dough or wheat dough please post back to this thread and I will help you to find the capacities.
I hope that I have helped you with your problem and would like to thank you for using FixYa to find a solution to your problem.
Mar 02, 2011 | Hobart D300 Stand Mixer
Is 300 w mixer powerful enough to mix bread dough?
Your mixer is easily able to handle the kneading of bread dough. Please advise:
9 cups of all purpose white flour, maximum.
6 cups of specialty flour, maximum. This is any flour besides all purpose white.
Bread doughs are only to be needed on speed 2, and never for longer than 7 minutes.
This is all stated in the Use and Care guide for the mixer itself. If these guidelines are not followed, it may lead to a product failure.
Jul 02, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Used the bread kneading hook, after 10 minutes, smoking
The mixer motor has probably overheated, as proper use and care was not being followed with the stand mixer.
Bread doughs are recommended to be mixed on speed 2 only and never for longer than 7 minutes. With the resistance of a bread dough that is provided against the beater, mixing for over 7 minutes may overheat mixer and cause smoking.
Please consult your use and care guide to refresh your memory about how to properly use your mixer for making bread doughs.
Jun 07, 2009 | KitchenAid K45SS Classic Stand Mixer
Bread dough hook slips when mixing
This is not a solution but I think you have a serious problem you might have sheared some gear teeth whent the mixer jammed and it only manifests itself under a heavy load, I would take it to a repair guy, those mixers are expensive and it would be worth it.
Mar 28, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Bread dough
IT NEEDS TO PROOF LONGER
Dec 10, 2008 | Hobart N50 Stand Mixer
Hobart a200 mixer won't mix
The bowl holds 20 quarts--are you overloading the mix?This mixer is not made for medium/heavy pizza dough.Depending on the pounds of dough,water and other ingredients will affect the mixer in some way.
Nov 09, 2008 | Hobart A200 Stand Mixer
KitchenAid 325 Heavy Duty Stand Mixer runs with low power & clicking noise
well there is a couple of things to try
1. see if kitchenaid sells the motor or
2. if a local appliance parts store can get the motor
this is the only thing you can do about the motor , the wires in the motor are shot and it will need reconstructing in the wireing, that is why it won't run fast and strong , because the wires have been heated up to much and now they can't create a strong enough magnetic field
but to replace the motor shouldn't be to hard just a little patience
if you need any more help just let me know!
electech
Oct 22, 2008 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Dough Hook Stops moveing under heavy load
Does the mixer work in any other speeds?Are you mixing pizza dough and in what speed?I service these mixers alot--i work for hobart.It sounds to me like you have a sheared key on one of the shafts.The mixer doesnt have a clutch.
Feb 21, 2008 | Hobart H600 Stand Mixer
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
828 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
