When this first started happening I knew there was something wrong with it so I left it alone for more then a year not having money to fix it.I recently tried it again with no problem and sewed a whole outfit. After that project was done I put it away for a couple of days until I needed to mend some clothes and yet again its not coming on.
This what i have found,,try this link. Fixing common sewing machine problems Service Support Brother Sewing and... ..
when you go to this page you will see this..
Sewing machine manual.
Should you encounter a problem with your sewing machine, it's best to refer to the instruction manual supplied with your machine. This will contain details of the correct settings for your machine and may contain a trouble shooting guide.
If you don't have this most Brother sewing machine manuals can be found here ..
where it is saying,(can be found here) just click that.on the next page you just pick your model and you should be able to trouble shoot your problem from the manual..
or you could also go to this link and see if it helps you out.
My computerized Brother sewing machine won come on Google Search
SOURCE: I have a Brother 98-Stitch
I dropped my feed dogs and when I pushed the button to bring them back up, it wouldn't work. I did discover that when you put the button back to the up position and start sewing, the dogs come back up automatically.
SOURCE: my sewing machine is sewing in reverse Kenmore 385-1960180
Hopefully this is only a mechanical problem that can be fixed with oil. If not it is either a stepper motor or circuit board. If you are not comfortable with removing covers and oiling then it needs to go to the shop.
SOURCE: A brother sewing machine LS-1217
Go to
http://welcome.solutions.brother.com/bsc/public/us/us_ot/en/doc/manual_index.html?reg=us&c=us_ot&lang=en&prod=hf_ls1217eus&type2=-1&flang=all&dlid=
to download the manual and the quick reference guide.
Please make sure to rate this solution. Thanks.
SOURCE: I need the owner's manual
Hi, Justmanuals.com has the manual that you need. They do charge $11.77 for each manual. If you're interested, just follow the link below. Hope this helps! Hal
http://www.justmanuals.com/sewing-machines-c-353.html
SOURCE: Shirring fabric?
When putting your shirring elastic on the bobbin, don't thread the elastic through the bobbin holder,adjust the stitch length longer,and loosen the tension, other wise if you want to put it through the bobbin holder you have to loosen the tension screw on the bobbin holder, and then you have to adjust it back for ordinary sewing,
