Question about Braun Coffee Makers & Espresso Machines
I want to find replacement parts for the Braun coffee grinder AG 4045, specifically the canister which catches (?) the ground coffee. It is still in working order but has a few small chips out around the top lid.
2 Suggested Answers
  • 669 Answers
SOURCE: I cannot find a user manual for my Braun 4045
I dug in and found your manual at Braun. Take this link and select the second choice to print your 9 page manual. Let me know if further assistance is needed.
http://www.service.braun.com/product/search.asp?rg=NA&c=US&l=GB&typ=ui&frmTyp=s&sgrp=s&grp=HH01%3C%7C%3E&s=kmm30&subgrp=0
Posted on Oct 11, 2009
  • 13 Answers
SOURCE: Part for Braun 4045 coffee grinder
depends if ur DIY (do it yourself)type or u know someone who are..or last solution is to order from factory..
Posted on Sep 12, 2012
My Breville BDC600XL grinder appears to be clogged and would put ground coffee into the basket. The grinder also slows almost to a stop. How do I fix it?
if this isa bed-bath and beyond unit?! take it bak!. and try the Braun coffee grinder. I hav had mine for 10 years and nevr a problem.
Dec 31, 2014 | Breville Bdc600xl YouBrew Drip Coffee...
My grinder has been working fine until this morning I did the usual plugged it in and it did not work. could the engine be burnt out. it is my favorite appliance for coffee grinding. please help. I would...
if you ground for a long time...20-30 seconds, you may have burned out the thermal control protection that keeps it from catching fire. It is a guess without more history.
Apr 07, 2011 | Braun KSM 2 Electric Blades Grinder
Unit is about 6 years old . it takes loger now to grind. is there a part to replace? where to obtain and how to do it. Thanks
You can first try cleaning the burrs, but they are most likely worn and will need to be replaced.
Here is the number for Braun 1-800-816-0810
Mar 01, 2011 | Braun KMM 30 Electric Burr Grinder
How do I oil motor on coffee grinder
There is food grade oils for just your purposed, greases also. Aplliance parts stores carry it
Jul 13, 2009 | Braun KSM 2 Electric Blades Grinder
Braun KSM1 XXU coffee grinder stuck 'ON'
The little plastic piece is part of the spring tension for one motor brush. It has been re-installed. I no longer need any assistance.
Feb 20, 2008 | Braun KSM 2 Electric Blades Grinder
Blade replacemen braun grinder
Insert a small standard screwdriver in the slot in the center of the bottom. Turn the blade slowly until you feel the screwdriver catch in the slot. This holds the motor still so you can simply unscrew the blade counter-clockwise. Do the same to hold the motor from turning while you screw the new blade on clockwise.
Dec 16, 2007 | Braun KSM 2 Electric Blades Grinder
Coffee Makers & Espresso Machines Logo
215 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
steve morris
steve morris
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
