Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
I have a coleman evcon dagto7obdd fan keeps running i changed the limit switches fan keeps running and 4 blinking lights means limit open
    Guru:
  • 462 Answers
Check for continuity through all your switches. Check voltage where these switches hook up to your control ignition box.if you see voltage there the problem is either the wiring or one of your switches is open. If you read no voltage there check again from "C" to the same wires a readign then indicates a bad board. Then check "R" to there a reading here indicates a bad thermostat (which is probably not your trouble due to the code and your legend of the code 4)
Hope this is cleaR and helps Please grade am accordingly and good luck.
Posted on Mar 11, 2009
I HAVE A BAND NEW KFA80DGD MODEL. I USED DEISEL, IT LIGHTS AND FAN BLOWS BUT AFTER A FEW MINUTES THE FLAME GOES OUT AND IT SHUTS OFF. THE INDICATOR LIGHT BLINKS...
there are two different viscosity rates and two different calorific values here
if it worked well on kerosene keep it on that
if you want to use diesel then have a technician come and set it up for diesel
Jan 04, 2017 | Heating & Cooling
My Coleman furnace 4322/729 model lights the pilot but won't cut in . What could be problem ? Cleared lines Complete
Gas valve not opening? Does it have the exhaust blower that pulls vacuum switch allowing burner to light?
(1) Thermostat not working? Has to complete the circuit in or gas valve to open.
(2)Can be a stuck or bad gas valve. Try tapping the side of the gas valve body while thermostat is calling for heat. Tapping,not pounding. Like lightly,yannow? don-ohio (:^)
Jan 03, 2017 | Coleman Heating & Cooling
How to bypass the relay on a Reddy M100D
Best change the switch ,than bypass it .
Jan 03, 2017 | Reddy Heating & Cooling
Only recently my portable heller air conditioner is oosing out buckets of water each night. does it mean it finished and needs replacement,
Portable air conditioners cool the air, and in so doing, dehumidify the air. The "buckets" of water are coming from the humid air in your environment, so you need to do things that will reduce humidity, of be prepared to empty the condensate receptacle fairly often.
Using a small room, closing doors and windows to the room you want cooled, avoiding cooking or heating water, reducing the frequency of people walking into/out of the room and limiting the number of people in the room will all help in reducing, and keeping low, the ambient humidity.
Jan 03, 2015 | Heating & Cooling
Electric Furnace stopped running
You have one of two problems. Either the capacitor for the motor has failed or the motor has failed. I would turn off the power to the unit and see if you can locate the capacitor and remove it. An ac supply or electrical supply house can match up the capacitor. This is relatively inexpensive. Otherwise you will need a new motor.
Nov 11, 2014 | Heating & Cooling
I have a Coleman Evcon electric furnace, the blower fan runs constantly and I have to shut the breaker off inside the front cover to turn it off. The switch is on auto and it runs even when the thermostat...
It could be a thermostat problem. Also it will seem to run constantly as it tries to heat and one of the elements are working which could be a sequencer problem.
Nov 28, 2013 | Heating & Cooling
Heating & Cooling Logo
189 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
