Question about Dryers
My dryer is approximately 16 years old. I have just moved into a condo, and found that the dryer takes a lot longer to dry than the one I had in my last condo. It is a Westinghouse stack type dryer. Do you think it is worth getting a repair person to look at it? Thank you in advance for your help. **** & Julie
    Problem Solver:
  • 17 Answers
It may not be your heating element. Your dryer lint vent pipe out the back of the machine or maybe out the side may be plugged. You have to pull the machine out and clear that pipe or rebuild it out to a soffit vent or static vent if it is in the attic, or out through your crawl space. This will make a huge difference. If that hot air and moisture doesn't get out of the machine it just goes back into your clothes.
Good luck!!
Posted on Mar 25, 2009
JLTDC01 Dryer not collecting water in the tank
ck your vent hose,there may be a block vent not allowing air to move around clothes , causeing long drying times.if vent hose is ran long way.more then 4ft say 15 or longer,it should be cleaned once a year or replaced.this in my opinion is the most main problem when having dryer issues.
Feb 25, 2013 | Dryers
My Dryer not that old, takes all day to dry a small load.
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Aug 31, 2009 | Whirlpool LER5636P Electric Dryer
My dryer takes 2 to 3 cycles to dry my clothes.
Check the following areas to combat this issue. in most cases, this will be a Venting issue.
1. Venting
2. Thermostat
3. Heating element
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Takes too long to dry
Check the following ares carefully to combat this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
3. Heating element
Jun 18, 2009 | Kenmore 63942 Dryer
Clothes won't dry
Check the following to address this issue.
1. Venting
2. Thermostat
3. Heating element
Jun 01, 2009 | Whirlpool ET8CHEXSQ Dryer
Did you resolve your dryer / noise?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
7687t
Apr 14, 2009 | LG DLG5932W Gas Dryer
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
Dryers Logo
62 people viewed this question
Top Dryers Experts
