Question about Toshiba Satellite M45-S169 Notebook
Where are the 2 sockets for the RAM memory? - Toshiba Satellite M45-S169 Notebook
  • Toshiba Master
  • 2,404 Answers
On the bottom of the laptop where the black door is at, usually towards the middle, it will take a phillips head screwdriver to unscrew the screw to get the door off and then you'll see the sockets for where the memory is at.
Posted on Mar 08, 2009
Ram capasity in one slot
This motherboard supports up to 2Gb RAM, either one 2Gb ram module in memory socket 1 or two 1Gb RAM modules in each memory socket.
Feb 01, 2013 | Intel 845GE Motherboard
Ram memory ASUS G73SW
This is the RAM specification for your motherboard.
Memory
DDR3 1333 MHz SDRAM
• 4 x SO-DIMM socket for expansion up to 16 G SDRAM Quad Core
• 2 x SO-DIMM socket for expansion up to 8 G SDRAM Dual Core
Apr 13, 2012 | Computers & Internet
What kind of RAM memory uses this motherboard
Gigabyte GA-5SMM - motherboard - micro ATX - Socket 7 - SiS530 specifications
  • General
  • Product Type Motherboard - Micro ATX
  • Cache Memory L2 cache - 512.0 KB
  • Chipset Type SiS530/5595
  • Max Bus Speed 100.0 MHz
  • Processor Socket Socket 7
  • Compatible Processors 6X86 , Cyrix MII , WinChip 2 , WinChip C6 , K6-III
  • Memory
  • Max Supported Memory 256.0 MB
  • Supported RAM Technology SDRAM
  • Supported RAM Integrity Check ECC
  • Expansion / Connectivity
  • Expansion Slot(s) 1.0 x PCI - Socket 7 , 3.0 x Processor - DIMM 168-pin , 3.0 x ISA , 2.0 x Memory
  • Storage Interfaces ATA-66 - connector(s): 2 x 40pin IDC
  • hope this helps
Aug 13, 2011 | Gigabyte GA-5SMM Motherboard
Dont know the ram that it use. wat is the number on the battery
  • K8M800-M7A
  • Support DDR 333/400 MHz
  • 2 x DDR DIMM Memory Slot
  • Max. Supports up to 2GB Memory
  • the battery i dont no
  • hope it helps
  • Biostar K8M800-M7A - motherboard - micro ATX - Socket 754 - K8M800 specifications
    • General
    • Cache Memory None
    • Chipset Type VIA K8M800 / VIA VT8237R
    • Max Bus Speed 800.0 MHz
    • Processor Socket Socket 754
    • Max Processors Qty 1.0
    • Compatible Processors Athlon 64 , Sempron
    • Memory
    • Max Supported Memory 2.0 GB
    • Supported RAM Technology DDR SDRAM
    • Supported RAM Speed 400 MHz , 333 MHz , 266 MHz
    • Graphics
    • Graphics Controller VIA UniChrome Pro
    • Memory Allocation Technology Shared video memory (UMA)
  • Jul 20, 2011 | Biostar K8M800-M7A Motherboard
    Have asus p4s8x mob,when adding 3rd stick of memory (1gb) total of 3gb.computer hangs on startup 1long 3 short beeps. if i remove one old stick and leave new with old (2gigs total)it works fine,also works...
    The Asus Asus Motherboards P4S8X-MX uses PC-3200 type memory and usually ships from Asus with 0MB of RAM. The Asus Motherboards P4S8X-MX supports up to 2GB of RAM. Maximizing your system memory will allow your Asus Motherboards to operate as fast as possible and offer the most productive environment.
    RAM modules must be installed in special locations on the motherboard called Sockets. These memory sockets are what hold the RAM module in place and can range from 1 to 16 or more. Banks consist of a group of 1 or more sockets. A system can have 1 or more of these banks of sockets. If a system has more than 1 socket in a bank, a Kit must be purchased for that bank. A kit is simply more than one, usually 2 or 4, like RAM modules. All sockets in a bank must be filled, and for such systems we sell memory in a kit. Typically you will see 2x512MB or 2x256MB signifying you are purchasing 2 units of 512MB RAM modules or 2 units of 256MB RAM modules, respectively.
    The Asus Asus Motherboards P4S8X-MX has 1 bank(s) which have 2 socket(s) in each bank for a total of 2 memory socket(s). This means the Asus Motherboards P4S8X-MX can support up to 2 individual RAM modules.
    We recommend you purchase the largest capacity RAM module each time you purchase memory. The reason for this is if you decide to upgrade again later and all your memory sockets are filled, you will not need to discard the already installed lower capacity memory.
    Below is a visual representation of the memory bank(s) and socket(s) configuration for the Asus Asus Motherboards P4S8X-MX.
    Standard Memory Bank & Socket Configurationsocket_2.gif hope this helps John
    Jul 01, 2011 | ASUS P4S8X Motherboard
    How many slots for dram chipsets? For AZ11/ AZ31 motherboard? Thanks!
    FIC AZ11 (First International Computer {Inc}
    3 Ram Memory slots.
    Supports SDR Sdram at 100MegaHertz, or 133MHz. (PC100, and PC133 respectively)
    Maximum Total Amount is 1.5GB
    Maximum Amount for EACH ram memory slot is 512MB. (1/2GB.)
    Uses the VIA KT133 motherboard chipset,
    (Northbridge - VIA VT8363
    Southbridge - VIA VT82C686A/B)
    http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
    Socket A processor socket for AMD processors. (Also referred to as Socket 462)
    http://www.xbitlabs.com/articles/mainboards/display/fic-az11.html#
    FIC AZ31
    3 Ram Memory slots
    Same type of ram memory as above, same total amount, and amount for each ram memory slot.
    Uses the VIA KT133A motherboard chipset.
    (Northbridge - VT8363A
    Southbridge - VT82C686B
    Socket A processor socket.
    http://en.wikipedia.org/wiki/Socket_A
    http://www.baber.com/baber/411/fic_az31.htm
    Oct 30, 2010 | FIC AZ 11E Motherboard
    My Dell Dimension 9150 is unstable. The Dell Diagnostic indicates memory failure in DIMM socket 3. I reversed the modules in the DIMM sockets and Dimm socket 3 failed again. Motherboard?? My motherboard...
    Yes you can. Your best is to use the largest and best ram in the number one slot. I would remove ALL the ram and start with the 2 gig in the first slot - then add others until you get the error message - remove that one and keep the rest.
    Mar 31, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
    Pentium 4 motherbord socket 7 edo ram memory
    P-IV system boards probably don't come in socket 7..
    if however so, it may b a hybrid-board..
    normally socket-7 is for P-II's..
    well, wat do wanna know..??..
    seek professional advise of ur system admin/vendor....
    Nov 18, 2009 | Computers & Internet
    Wheres the ram?
    RAM modules must be installed in special locations on the motherboard called Sockets. These memory sockets are what hold the RAM module in place and can range from 1 to 16 or more. Banks consist of a group of 1 or more sockets. A system can have 1 or more of these banks of sockets. If a system has more than 1 socket in a bank, a Kit must be purchased for that bank. A kit is simply more than one, usually 2 or 4, like RAM modules. All sockets in a bank must be filled. Typically you will see 2x512MB or 2x256MB signifying you get 2 units of 512MB RAM modules or 2 units of 256MB RAM modules, respectively.
    The Toshiba Satellite A40-S270 has 2 bank(s) which have 1 socket(s) in each bank for a total of 2 memory socket(s). This means the Satellite A40-S270 can support up to 2 individual RAM modules.
    Below is a visual representation of the memory bank(s) and socket(s) configuration for the Toshiba Satellite A40-S270.
    socket_1.gifsocket_1.gif This graphical representation above details what the memory configuration would look like with the maximum memory installed and does not necessarily model your system memory configuration. This graphical representation is not drawn to scale and should only be used as a general reference. Please consult your system’s user manual for your actual memory configuration.
    May 11, 2009 | Computers & Internet
    SAMSUNG 1GB RAM 400MHZ PC3200
    RAM has to be
    Four 184-pin DDR DIMM sockets
    Supports PC3200 (400 MHz) /PC2700 (333 MHz) / PC2100 (266 MHz) DDR DIMM type
    Maximum HP/Compaq approved memory module is 1 GB
    Maximum HP/Compaq approved memory is 4 GB
    It has to be the same.
    • If you are replacing a memory module, put the
    new memory module in the same memory slot
    from which the old memory was removed.
    Or
    • If you are adding a memory module, install the
    new module into the socket nearest the
    preinstalled module, and install additional
    modules in the next available sockets
    Jan 14, 2008 | Computers & Internet
    Toshiba Satellite M45-S169 Notebook Logo
    54 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
