Question about Whirlpool Dryers
Whirlpool dryer model LEB6000PQ0 its not heating up anymore''it starts it turns but the clothes dont dry its only 2 yrs old.
  • 163 Answers
Check your breaker first.A dryer will run on 110 but wont heat.if not breaker it could be your thermal fuse or element.the thermal fuse is located on element cage,unplug machine and test for continuity to your thermal cut off fuse which will be the top one on cage and check continuity to element.
Posted on Mar 08, 2009
Electric Whirlpool dryer m11036334, dryer will not always heat
Sounds like a limit switch has broken. Doesn't sound too expensive to fix.
Nov 14, 2016 | Whirlpool Dryers
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
I have a whirlpool dryer Model # LEB6000PQ0 It seems to be heating sometimes, but not all the time. Could that be a heating element, or something else? We have to dry a load several times...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 24, 2011 | Whirlpool Dryers
My LER463rJQ1 dryer is only about 4-5 yrs old and it doesn't seem to be heating as well anymore. I don't know where to start...thermostat? heating element? or what.. What do you suggest.
I assume you mean the clothes are not drying as well or as quickly as they use to.? If so I would start with the Vent system ,85% of extended dry times are vent issues. Start by running the unit and going outside to the dryer vent and check for a good flow of warm air,if very little air is coming out of the vent you need to clean or have the entire exhaust system cleaned out.. With out good airflow you will just end up with warm moist clothing the airflow helps remove the moisture.. If not a airflow problem it may have a thermostat issue not letting it get hot enough or not staying hot long enough,,Hope this helps GOOD LUCK
Aug 27, 2010 | Whirlpool LER4634J Electric Dryer
Model LEB6000PQ0 has quit heating. What is best
your heating element has possibly burnt out. If you are proffecient in repairs this heater core is located in the bottom of the dryer casing. You will need to remove the backing of the dryer and look at either the left or right section at the bottom and you will see ther heater coil. Take model and serial number to an appliance parts house for replacement. If you need a repair and aren't able to do it yourself a appliance tech can do it for a minimal fee. It really shouldn't cost an arm and a leg to repair this
Hope this helped
Dave
Feb 10, 2010 | Dryers
LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Aug 25, 2009 | LG DLE3733 Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryer heats up but clothes won't dry
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
Dryer won't dry
There are three possible parts that can cause this.
1. Thermal fuse
2. Thermostat
3. Flame sensor
https://www.repairclinic.com/Shop-For-Parts/a8b6d600503/Model-11072212100-Kenmore-Dryer-Parts
You can check the first two with a meter to see if they are ok. If they are then you should replace the flame sensor.
Mar 25, 2017 | Dryers
Dryers Logo
678 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
