Question about Kenwood Audio Players & Recorders
Kenwood stereo system made in 1990 which had a711 tuner, dp711 cd player, x711 cassette player. we are trying to find a manual on this?
2 Suggested Answers
SOURCE: I have an old kenwood shelf system, with the
Thanks for your concern. I was badly in need of a manual and luckily enough I got across a friend who had one in Uganda. So that solved my problem.
Posted on Jan 02, 2010
What type of connection wires do I need to connect a sansui au 9900a intergrated amplifier,and the tu9900 stereo turner to a kenwood multi cd player and a JVC td- w 5th double cassette.
You need cable called RCA. What goes out of one unit goes in to another. Get the owner manual and read it. It will show you how to connect the wires to the components.
Connect the RCA jack to to tuner input in back. CD player to the aux in back.
Try this:
http://stereobarn.com/how-to-connect-a-stereo-system1/
Sep 29, 2014 | Sansui Vintage Tu-9900 Legendary Amazing...
I just got a Kenwood system, i would like to know how to hook it up, it has, Kenwood power amplifier km207, kenwood stereo control amplifier kc 207, disc player dp-m 97, cassette deck ky-77 cw, stereo...
That's a pretty standard setup. RCA cables from the KM207 to the preamp (KC207), and RCA cables from all of the other components into the KC207. Speakers connect into the KM207
Nov 01, 2012 | Master DE Kenwood with Housing...
I´ve forgotten in what order I should connect my old (80´s) separate modul hifi system´s remote cables. It shuts down imadiatly when you try to start it with the remote. If I disconnect the...
I would have thought that it should go from the amp to the tuner,then the tape deck and finally the CD deck.
I'm suspecting that your tuner is faulty and thats whats causing the system to shut down
Aug 27, 2010 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Kenwood Stereo
I presume you realize none of these things produces speaker amplification. A receiver would do that and facilitate graceful and simultaneous interconnections. But it's not a necessity for selective interconnective between them, just not all at the same time.
I can't find any details on anything you named except the Tuner.
Typically, the tuner would use an RCA pair to go to a receiver AUX, TUNER or other Line Level input for source selection and amplification. Lacking a receiver, run it to the Tape Deck inputs for recording.
Ditto for the CD changer, but you'll probably have to disconnect the tuner.
Jan 26, 2010 | Audio Players & Recorders
I have an old kenwood shelf system, with the following components:kenwood stereo power amplifier B-A9 100v 125w, kenwood C-A9 digital pre-amplifier/tuner, kenwood stereo cassette deck x-A9 plus a cd...
Jan 01, 2010 | Kenwood XD-A55 CD Shelf System
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
Stereo cassette receiver--hums
There could be an open filter capacitor in the power supply.
Jul 13, 2017 | Kenwood Audio Players & Recorders
Kenwood KA-72B Stereo Receiver HELP NEEDED.
Why not plug the cassette directly into the CD recorder? Are they trying to achieve some eqalization change? If not, then this should work. It's all analog at tape level.
Mar 02, 2008 | Audio Players & Recorders
Kenwood KRC-394 Cassette Stereo with CD CHanger
I have the same problem all of a sudden...it only shows as AUX when on CD mode.
The manual says to change the O-N switch to the 'N' side...however I dont know wherer the )-N switch is?!
Jan 29, 2008 | Kenwood KRC-394 Cassette Player
384 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
