Question about Symphonic ST420FF 20" TV
Need part I need a BL3700F01011-2 circuit board for my ST420FF TV.
Tv is green
Check and replace damaged component/s at the video output section circuit.
Mar 04, 2013 | Symphonic ST420FF 20" TV
Samsung tv no led indicatior glow.. voltage regulator 3s125r have a primary voltage and secondary no voltage
if no secondary voltage at the regulator that was mean the regulator is bad which need replacement.the output supply will not pass through to the other circuit which turn on the tv.
Aug 17, 2012 | Symphonic ST420FF 20" TV
Who makes symphonic tvs
A company called "Funai" makes them. Both Funai and Symphonic have same circuit and settings.
Jun 05, 2012 | Symphonic ST420FF 20" TV
My original remote is not working. I bought a universal remote and it doesn't work either. Can't get a remote to work on the tv
Hello
The remote sensor inside the circuit board of your TV is faulty. It is the component that receives the infrared signals of the remote control. If this component go faulty, no remote control will go with the TV. This component can be located on the front panel board of the TV just behind the infrared sensor window at the front. You have to open your TV to locate this component. It is a three terminal component, look brownish black in colour. The sample picture of it has attached here. It is very cheap to buy, and can be bought from most of the electronic sparepart shops at your town. If you have a concept of soldering and resoldering, you can replace this component yourself at home OK.
Oct 02, 2011 | Symphonic ST420FF 20" TV
Tv picture is getting too big for the screen. Can the picture size be reduced?
Hi, well this is most likely a Aspect Ratio issue, this can be set via the TV's Menu. You simply need to adjust this aspect ratio, to suit you viewing requirements.
It is all explained how to do this in your user manual, link provided below. http://www.devicemanuals.com/guide/Television/Symphonic/Symphonic-ST420FF-20-TV-Owner's-Manual-T0RVek16az.html
Sep 29, 2010 | Symphonic ST420FF 20" TV
I need a code for hooking up a polaroid dvd player
You need the right tv remote code. Try to ger the code here
polaroid tv codes
May 25, 2010 | Symphonic ST420FF 20" TV
Trying to get the remote to work on my symphonic
Change batteries?Take it aparts,clean it with Q Tips
with some rubbing alcahols in the rubbers knobs and
clean the films between the circuits board.Don't work after this.Buy a new remote at this website.1-800-remotes Factory Original.Yes,universal remotes it cheaper,but causes univeral codes,more headaches later.
Oct 21, 2009 | Symphonic ST420FF 20" TV
Need to know code for t.v
What kind of code do you need? If remote control and tv , tell us the brand and model of TV as well as Remote control
Sep 12, 2009 | Symphonic ST420FF 20" TV
Symphonic ST420FF 20" TV Logo
65 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
