Question about Dell ATI Radeon, (32 MB) Graphic Card
My computer is hooked up to my tv(sanyo ds27425) thru S-video from my radeon 7500 family graphics card, it works well for awhile then the screen goes blue! sound still works and downloads still come in from internet but scenn is blue!! help!!
  • 50 Answers
Personally I never liked s-video, especially when you have component available. But I think that the pins in the cable on one end is either real dirty, or possibly bent. There could also be foreign debris in the input/output ( TV/PC ) of the adapters. Or the cable you have just is no good. Hopefully it's not the video card itself. Try hooking up a VGA monitor and run it the same amount of time you do with the TV connected.If that's OK, try canned air in the input/output ( TV/PC ) ,and replace the S-Video cable. Good Luck!!
Posted on Mar 11, 2009
Monitor goes blank when trying to use radeon HD 2400 Pro graphics card
Well Michael,
it can be your monitor thats broke u can test it on a other system and see if the monitor works or not,if it works than u know its your graphic card thats broke and u should replace it
May 09, 2014 | ATI RADEON HD 2400 PRO Graphic Card
I just inserted my new radeon 7500 pci card and nothing comes up on either monitor . help please!!!
I read the reviews on your card and they are mixed, some good, some bad. Out of four, 2 could not make the card work. It is not supported past Windows Vista, altough one of the reviews said it wouldn't work past XP. Anyway, I don't know what system ao version of windows you are running but, if you are trying to upgrade and older system, you may want to choose a card with more recent support. The card is PCI so make sure you install in PCI slot, usually white. If you have on board graphics, make sure it's enabled to start. You want to make sure you have the card hooked up before restarting your system. It comes with s-video to composite cable, which will work fine if you have a composite set up on your monitor or TV. You can also use VGA or DVI outputs. If you have on board graphics and you get a picture using that, look in device manager under display adaptors and make sure card is recognized. You click on the box on the right side of "display adaptors". If you see Radeon, ATI, etc., right click on that and in the kist you should see "disable". If you see "enable" click on that and exit. If you have on board graphics, you should get a picture regardless of whether the card is installed or not. Make sure all your connections are good and that you have no warnings in device manager. If the card cannot be recognized, you could try to designate you PCI slot through BIOS.
May 09, 2011 | Diablotek VIDEO CARD - RADEON 7500 - PCI -...
RADEON 7500 AGP Graphic Card: just reformatted my old dell optiplex gx260 and i ...
You can try reinstalling the firmware for the video card, but if that doesn't work your video card is probably dead and you'll need a new video card. The firmware is what controls the video card, so if the computer shut off while the firmware was in the process of being rewritten, there's a good chance some of the code needed to run the card got erased or scrambled.
May 17, 2010 | Dell RADEON 7500 AGP Graphic Card
My Sanyo DS27425 went off and will not turn on. When I push the start button I hear a clicking sound. NO sound or picture.
There are couple of reasons for this problem:
1. The power supply of it is busted and needs to be replace.
2. Your TV is overheated and needs to be check by a qualified technician.
Dec 17, 2009 | Dell ATI Radeon, (32 MB) Graphic Card
Cant utilize extended monitor function in XP w/ onboard chipset as other VGA out
You cannot use both the onboard video and a separate card at the same time. Are you trying to use multiple monitors? Your video card must support that if you are, and the Radeon 7500 does not mention that it does. If it does, the ATI Catalyst drivers will have the option.
Jun 02, 2009 | ATI RADEON 7500 (64 MB) PCI Graphic Card
Blank screen after Bios solved ?
There is a conflict between this card and something else in the computer. It could be with other integrated video card present in the motherboard. If there are other cards of any type installed in your computer you should remove them first and try the ATI alone. Otherwise you might have a damaged ATI card, or a trully non compatible motherboard.
Jun 05, 2008 | ATI RADEON 7500 (64 MB) PCI Graphic Card
I need drivers
Just download the driver for it, which can be found here.
If this solution was helpful please rate me to let me know!
Apr 08, 2008 | ATI RADEON 7500 (64 MB) PCI Graphic Card
Ati radeon 9600 video card
what you have the ATI card hooked up can you see the boot screen? If you can see that you might want to try going into safe mode and making sure your graphics settings aren't set beyond the capability of your monitor. If you can't see the boot screen then your card might be dead.
Apr 28, 2007 | ATI Radeon 9600 Pro 256MB DVI+CRT+TV 8X...
Computers & Internet Logo
189 people viewed this question
Alun Cox
