Question about Makita Planer Replacement Blade, 3 1/4"
FITTING DETAILS FOR MAKITA PLANER BLADES
HOW DO i SET UP AND FIT MAKITA PLANER BLADES
  • fatcats1 Mar 09, 2009
    Thanks rowdy45176.
    I want visual instructions to give to someone who has purchased my 1100 planer
  • 2,176 Answers
It depends on the planer blade set that you are using. If you are using the the 2 sided blades there is a guage that goes with it to set the blade depth before installing. I would strongly recommend that you go to Makitatools.com and type in your model number and download a copy of the owners manual for specific instructions. Let me know if you have any problems finding them
Posted on Mar 09, 2009
  • David Ford
    David Ford Mar 10, 2009
    Did you go to the website that I furnished and type in your model number. It has a downloadable user manual for this tool so you can have VISUAL instructions. Thanks for the rating
How do you remove the blades from a nu tool planer?
hi if you look at the drum where the blades fit you should see the screws holding the clamps on for the blades just slaken off screws and slide out blades.
Sep 15, 2013 | Makita 3-1/4" Planer Kit N1900B
How do you adjust the replacement blades in a Makita planer if you don't have to original gauge?
The blades, at thier highest point in rotation, need to be exactly the same height as the larger back plate. Any straight edge laid on the back plate and extending over the blades will let you know if they are set properly. The straight edge should not contact the blades when they are turned (by hand) and there should be as close to no gap between the straight edge and blades as you can get.
Mar 05, 2012 | Makita 3-1/4" Planer Kit N1900B
I need instructions on how to replace a new set of power planer blades for Makita 3 1/4 inch power planer
find your model number and go to "makitause.com" and you can download the operators manual with detailed instructions for this repair. REMEMBER to unplug tool before starting. If you give me the model number I will help but they had 2 different types of holders on the planers so I can't begin to help. Let me know.
Apr 09, 2011 | Makita Tools & Hardware - Others
I HAVE SHARPENED THE KNIFE BLADES HOW DO I SET THEM IN THE PLANNER
Planer blades can only go in one way, the set plate must go into the groove on the blade. If you sharpened them by hand, or even with a machine, you have to be absolutely sure both blades are EXACTLY identical and that the edges are true and straight. If not you are going to get some real interesting patterns on your wood. It's rarely advisable to sharpen planner blades and they are cheap enough to make it unnecessary.
Dec 23, 2010 | Makita 3-1/4" Planer Kit N1900B
How to fit New blades on my Makita Electric Planer 1125
go to Makitausa.com and download an users manual, they make guages depending on what blades you re trying to install. If you still have a problem let me know, I worked on them for quite a few years.
Jun 29, 2010 | Makita 1912B Electric Planers
How to install 3 1/4 planer blades into makita planer model 1900b
go to Makitausa.com and download an owners manual and it will have directions on how to do this. Let me know if you still have problems.
Jun 28, 2010 | Makita Planer Replacement Blade, 3 1/4"
How do I change the blades for my Makita N1900B handheld planer
http://www.makita.com/en-us/Assets/images/Products/N1900B/owners_manuals/N1900b.pdf
here is a link to the owners manual, see page 7
There's also a link to a parts listing if you need more replacement blades.
Feb 14, 2010 | Makita 3-1/4" Planer Kit N1900B
Putting Sanding paper on makita sander
A makita power planer is just what it says, a planer. It has blades that spin at high speed and remove a thin layer of wood with each pass. The orbital sanding sheets go on another tool called an orbital sander. Write back if you find the sander and can not figure out how the sheets go on it.
May 02, 2009 | Makita 9404 4'' x 24'' Belt Sander
Makita Planer Replacement Blade, 3 1/4" Logo
2,860 people viewed this question
Top Makita Crafts & Hobbies Experts
Tony Crow
Pieter Vleeshouwers
Pieter Vleeshouwers
FastHarley
FastHarley
Are you a Makita Craft and Hobby Expert? Answer questions, earn points and help others
