Question about Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet Sport Washer still making noise now it s leaking
The Whirpool Duet Washer Sport is still making the funny noise during the spin cycle, now it is leaking water out of the bottom, it is not all the water in the tub, but it is leaking . I have turned it to rinse & spin no leak, then to drain and spin, no leak, so I am like maybe it is something crazy. I do what someone suggested, and tapped the place at the top of the washer where the noise is coming from, not quite as bad, but it is still there now with a leak.......PLEASE HELP SOON
  • 2 more comments
  • mrszip0123 Mar 09, 2009
    Well the funny noise is gone, we removed the bottom cover and then cleaned some filter, there was a necklace, screws, bits, money and some other stuff. Now we just have to figure out the water thing
    No water spots on the back panel, took the front bottom cover off and you can see where water is leaking around the cement weight . I have checked the seal I can't see where it is torn or where it could be leaking from. Do you have any more suggestions?
  • mrszip0123 Mar 10, 2009
    I have cleaned and searched for a hole of some sort. Nothing. I
  • ben thomas May 11, 2010
    take the top panel off and the front bottom panel off and run the unit as normal this will give you a better look at what is happening and will see where the water is coming from make sure you dont see anything in the front seal area or any holes in the seal and make sure you dont see any water spots on back panel of washer
  • 40 Answers
Make sure to look really close all it takes is alittle whole in that seal anywhere to cause a leak try to look close while it is running but first dry everything you can and then run it. also make sure your door glass is clean if it is leaking down the front just alittle dirt or hair can cause a leak aswell
Posted on Mar 09, 2009
  • bady18 Feb 11, 2011
    Hi mrszip0123,
    The leak in my washer matches your description. water leaking around the cement. Have been able to find the cause? Do you have any suggestions?
My whirpool WFS1071BD front load washing machine leaking when spinning
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find.
Oct 14, 2012 | Whirlpool Duet GHW9150P Front Load Washer
We have a Whirlpool Duet Sport Front-Loading Automatic Washer and it makes a pretty loud noise when in the spin cycle. The volume is directly proportional as to how fast the washer is spinning. It's a...
The symptoms that you describe are caused by bearing failure. The water seal in the wash tub has failed, allowing water to leak into the bearing causing the bearings to rust. As the bearings start to rust, they will not roll properly and start to make a rumbling sound. The sound get louder the faster the bearing turns.
It a major job to repair since the washer has to be taken apart and the wash drum needs to be removed to replace the seal and bearings. Get a few estimates before deciding whether the washer is worth the cost to repair or replace. Sorry.
Oct 04, 2010 | Washing Machines
Funny noise in spin cycle
u will change the drum belt. ask service people to change ur belt.
Mar 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water coming out of the botton during spin cycle
Take the bottom panel off the waher, put water in the machine, and watch to see where it is leaking. If you don't see a leak during the regular cycle, put the machine in drain and spin mode, and watch for leaks there. You should find your leak during one of these cycles so you will know what part you need.
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front loader is making funny noises. It was
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
May 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer is making a funny noise
try removing the top cover to the unit, 3 screws across the back. after ermoving check to see exactly wehre noise is coming from. some times a solid "smack " witha screwdriver will quiet teh dispensor motor if needed
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet Sport Front Loading Washer is making a funny noise
open top cover (two or three screws on rear and slide back) and look at rear of tub checking clearance to rear panel and nothing touching belt or pulley. whirlpools tend to have a high pitch low volume whine anytime motor operates.
you really dont want to replace that bearing. part of tub assm. $400 part plus labor
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
608 people viewed this question
Dan Webster
Dan Webster
Sal De
