SOURCE: pioneer vsx d512
All you have to do is connect the coaxial out from pc to any audio i/p at the back of vsx d512.but ensure you select the right channel to play the audio ( eg. tape i/p select tape at front control, aux i/p select the aux at front control )
SOURCE: I just bought a vsx-1019ah receiver. I connected
Check if your KuroLink is on or off. There are a lot of problems that users have been having with the KuroLink on. Since you have a Pioneer display, KuroLink might help in switching both the receiver and the display on and off together, but my advice to you would be play around with the settings (in your case, especially KuroLink). Also remember, the KuroLink is on by default i.e. if you've never changed this setting, it probably is on.
Hope this solution works, else check out the Official Thread on Pioneer VSX 1019 AH-K on avsforum. There are a lot of helpful people out there.
SOURCE: I have a motorolla DSR505 sattelite receiver that
The DVI output usually transmits only video (I'm almost 90% sure about this). It would be better if you did not use the DVI to HDMI cable. Receivers and displays can be very picky when it comes to using HDMI. Your Motorola DSR505 has other output options on its rear. I would suggest using the Component out for video (the 3 outputs colored green, blue and red) and either an optical or coaxial for the audio. The Pioneer VSX 1019 AH-K has the required inputs. Of course, you would require new component and coaxial/optical cables to do the job.
Hope this helps. If you're still in a tangle, you can consult the Official Thread on the Pioneer VSX 1019 AH-K on avsforum. There are a lot of helpful people out there.
SOURCE: Pioneer works with cable box but not with new blue
HDMI version is 1.3 in your receiver.The current version is 1.3b. I would suggest calling Pioneer cust assistance and see if there is a firmware update. Your unit has a 2 year parts & labor warranty. Their # is 1-800-421-1404 It sounds like a CODEC issue. Hope this helps
SOURCE: Pioneer vsx-819H: MCACC setup won't display on tv
Its because the pioneer does not display menu options through hdmi. You have to hook up basic yellow composite to monitor out.
