Question about Whirlpool LSB6200KQ Top Load Washer
Roper washer stops at rinse circle
My roper washer stops at the rinse circle and you cant wash with cold water anymore. What can I do to fix it?
  • 2 more comments
  • Anonymous Mar 10, 2009
    how do I replace the clutch plate
  • Trilsbeck Mar 27, 2009
    Just wondering if the proposed solution actually worked? Was the cold water blocked off and did cleaning the filter get the rinse cycle working again?
    I am having the same issue with my roper washer (made by whirlpool) - the wash cycle works fine, it spins, but then seems to stall on rinse (regardless of cycle type, i.e. normal, delicate, etc). I can hear an electric hum from the machine when it goes to rinse, but nothing else happens.
  • cokertracey Apr 07, 2009
    cold water cycle just trickles...
  • Anonymous Mar 24, 2014
    no cold water
  • Whirlpool Master
  • 3,361 Answers
Turn off your water to the washer.
Remove the hoses from the valve at the rear of the washer and clean the trash out of the filter screen.
You have a cold fill rinse washer.
If it can't get water it stops advancing the timer.
Posted on Mar 08, 2009
My Roper heavy duty 8 cycle 2 speed combination washer does not fill up on rinse cycle
when in rinse washers use just cold water so clothes don't wrinkle,try this,set the washer to just cold,start it and see if it fills or fills slowly if so you have a bad water valve on washer or no cold water going to washer.
Dec 04, 2017 | Roper Washing Machines
My roper washer stop during after the rinse cycle. Is their a reset button.
remove plug from wall is master reset. but its most likely a sensor or controller issue? get a service manual first.
Aug 21, 2015 | Roper Washing Machines
I just moved into a new place and hooked up my Roper 111-07 washing machine. I have notice that no matter what temperature I select for the rinse cycle, hot water is the only thing that comes out. I only...
Hello Stephanie Wells,
Since it is the "new place" that changed...
I would FIRST look to the COLD WATER supply
to make sure cold water INDEED comes out of the
MACHINE END of the hose.
Then move on to the cold water valve...
>> Take PICTURES before disassembly.
Not terribly expensive... Pretty easy to change.
(you may get your NEW PART as differently
connected than your old (PRESS FIT couplings
are replacing the OLD threaded type...
ALERT: PRESS collar in to release tubing)
HELPFUL VIDEOS:
Check these (USA) parts suppliers to
find your specific water valve
(even available through AMAZON)...
Let price/reputation be your guide...
ALL these folks peddle the same parts (opinion)
appliancepartspros
Search Over 2 1 Million Appliance Parts
AMAZON: Roper
285805 Roper Washer Washing Machine Inlet Water Valve Replacement
partselect
PartSelect Appliance Parts and Repair Help
repairclinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Good luck
Carnac the Magnificent
May 08, 2017 | Roper Washing Machines
My Roper washer will run through wash cycle then stops. Nothing will work for 40 minutes then I can put it on rinse then the cycle will complete. What could cause the stopping with nothing working then...
It could be that the machine is trying to heat the water in the drum, but is not able to for some reason. The timer is waiting for the water to reach temperature before advancing. Posssibly a broken heating element. This can happen even on a cold cycle as most machines prefer to heat all soaping water to about 30C regardless of the temperature setting.
Sep 13, 2013 | Roper Washing Machines
Roper washer fills and washes then will not fill on rinse cycle but goes into washing dry
Run the machine with hot only, and then cold only. Post back your results.
Nov 11, 2012 | Roper Washing Machines
ROPER RAS6233KQO T.L.W.-Won't fill/rinse with cold water
Most washers have a small screen at the water inlet valve. They can be accessed simply by revoving the hose from the back side of the washer, using a small screw driver you can carefully remove the screens and clean them out under a faucet.That may be all that is wrong.
Oct 27, 2007 | Roper RAS8445KQ Top Load Washer
Whirlpool LSB6200KQ Top Load Washer Logo
253 people viewed this question
Dan Webster
Dan Webster
Sal De
