Question about Maytag Neptune MAH5500B Front Load Washer
Not spinning? Displays LR on reasdout
Unit stopped near end of cycle. Tripped GFI. Reset GGI and washer displyed came on. It appears to go through whole wash cycle but does not seem to spin
  • 15,935 Answers
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" - the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason.
By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing.
The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down.
You don't mention in your question if the LR code occurs every load or once a week.
Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down.
This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes.
At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source...
"Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 I'd call it a 3.5.
If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job.
It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear.
Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer.
The instructions don't ask you to, but I would remove the brace on the left to make life easier.
This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board.
My wrench was too big to get to the bolt to remove the harness from the motor.
All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor.
As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft.
The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together.
There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish.
Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question &$^YHG
Posted on Oct 01, 2010
Kenmore 110-88752793 washer dryer. Tub filled up for the rinse cycle and then stopped. Tried turning on the dryer and that has no power either. Cycled the circuit breaker. Still nothing. Any ideas?
The circuit that supplies your washer and dryer may also have an in-line GFI outlet which may have tripped. Even though you have cycled the circuit breaker you would also have to reset the GFI outlet as well. Good luck.
Nov 26, 2016 | Kenmore Washing Machines
REFRIGERATOR HAS STOPPED WORKING , NOTHING RUNS, NO LIGHTS NOTHING
If everything is dead the first thing you have to establish is that the unit is receiving electrical power. It is far fetched for every component to go bad at the same time!!!!!!
Jun 25, 2015 | LG LSC27910ST Side by Side Refrigerator,...
Error codeLr?
The LR code means "locked rotor" which is just a way of saying the control is not seeing the motor turning.
Usually when the LR code is displayed the motor has stopped turning for some reason. By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing. The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down. You don't mention in your question if the LR code occurs every load or once a week.
More information on when the error is occurring would be helpful resolving this problem. Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down. This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes. At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Feb 14, 2012 | Maytag Washing Machines
My washer stops in the middle of the cycle and displays F-1 and after I have to set it on the rinse / drain cycle to complete. Today for the first time it also displayed 5d at the end of the cycle.
5d or Sd means too much detergent was used. Try the following
Run the unit through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
Jun 29, 2010 | Kenmore HE2 Plus Front Load Washer
My maytag neptune runs its cycle and at the end displays Lr
From another source..."Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 (ten being hardest) I'd call it a 3.5. If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job. It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
The instructions are pretty clear. Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer. The instructions don't ask you to, but I would remove the brace on the left to make life easier. This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board. My wrench was too big to get to the bolt to remove the harness from the motor. All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor. As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft. The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together. There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish. Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%YG
Mar 31, 2010 | Maytag Neptune MAH5500B Front Load Washer
Code lr appears on washer
use normal cycle instead of clean just follow say instructions ..lr is code for remove clothes from tub for clean cycle problem even with no clothes they still show code ..it's a program problem that whirpool is aware of last i heard they were working on solution but instructing cust to just use normal cycle instead
Nov 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 80 - in mid spin cycle the machine tripped GFI
check your pump ,,, sounds like you gotten something in it putting a strain on the motor to overload your breaker
Nov 17, 2008 | Kenmore 24032\24036 Top Load Washer
Getting error code#06 Lr Locked Rotor
I too had the Lr problem on my Maytag MAH5500B. We had it fixed once when it was still under warranty but when it appeared again this summer, I was told that it would cost at least $500 to repair -- in other words, get a new one.
With nothing to lose, I simply unplugged the unit, opened the front and reset (as in pull out and re-insert) the jumpers to the control unit on the bottom right. It's been working fine since and I run it at least twice a week. I noticed that the Lr error would appear when I interrupt the wash cycle once it begins. When the error message appears, I simply unplug it, wait a few minutes and start it up again.
It is after all, a computer...and all computer could use a reset once in a while.
Feb 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
69 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
